Old 02-01-2012, 09:26 AM   #31
jaumev
jaumev's Avatar
Oddometer: 1,501
Originally Posted by woody's wheel works View Post
thanks for the feedback mates!!
FYI #1,,lacing up an 18 is simple for me,,,,as long as you do your math and tell me the 14/80 or 90 x18 tires will clear everything,,,,i'm sure they 'll raise th ass end up circa an inch,,the 21'' front will definitely raise the front an inch too,,,then you'll essentially be back at oem steering geometry,,,,the other question has to do with rim width..2.5 is more dirt oriented and a 3.5 would be better for carrying heavier loads //not going as fast off-road and a little better on the slab...have it your way....OBTW if ya don't air down an duse rim-locks ,,we could seal for tubeless $99 or show ya the post if ya wan tto tackle that yourself.
FYI #2,,,juust doing the 21'' front will increase trail and make th bike a bit more stable at speed ,,,many dual sport riders like that,,,just tossing in a few tidbits to mull over
FYI #3,,,just orderered 25 sets of adapter plates,left/right and center spacers for y Superlite II hubs...now these disc adapter are sot hat you can keep your oem disc rotors....the other alternative is that i make a spacer plate for use with my SuperliteI hub,,this hub was designed to create the lightest possible front wheel /disc/hub assembly for the HP-2s.
this was accomplished partly by using Galfer wavy/floating rotors for an even greater saving in un-sprung weight...will do a little weighing when i get a bike in the shop....
FYI #4,,,i get it that most of you favor keeping your TC/ABS capabilities,,,
once i get the final $$$ numbers for creating a complete oem hub/abs/TC unit for you to just bolt on your bike ,,i'll weigh making a custom hub that'll integrate the ABS/TC ring in the exact location as the oem unit,,,it's all in motion though,,,,that's for the front hub,,,my gut tells me that the rear wheel/hub may be a bit more expensive,,hence may stick with the oem hub for the time being..
so Greg,,,what color rims,hub,brake adapter do ya want for Superlite -ST wheel set #001
holler,,we're getting ready to drop the hammer,,the 6061-T6 plate has been ordered yesterday....
will keep you all posted and see if i can post a pic or two to whet your whistles.
GREAT!!
Tomorrow i'll have my new S10, si I wait for the end of this story with great interest.
jaumev is offline   Reply With Quote
Old 02-01-2012, 03:39 PM   #32
obe01
Wannabe Adventurer
obe01's Avatar
Oddometer: 1,269
21" / 18" for me mate...
I am as excited as a kid in a candy shop....
Like you said Woody, the 21" front will definately settle down the S10' front end. Hodgo and I were doing comparison rides yesterday afternoon (on 950's) and this is one thing that was quite noticable between bikes.
Greg seems to think the combination of 21" / 18" is the path to take. I am in definately in for this. The ground clearance will be great with this combo.
Cheers Woody,
Johnnie
SUPER TENERE'
obe01 is offline   Reply With Quote
Old 02-01-2012, 09:25 PM   #33
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
18 '' rear clearance
FYI,,just got finished skyping with greg
he's doing a few double cheks on the clearance issues with going 18''
FYI #2= if you tell me the OA diameter of whatever you have and then tell me the clearance between that tire measurement and your swingarm,,,then i cna figure out what BWOE a 140/80x18 rally-raid tire mounted on a 2.5x18 or 3.5x18 rim will end up...it's simple math,,,
my dilemna is their are so few guinea pigs to do the measuring on
and with your assistance we can get this project moving in the right direction...
gotta get some zzzzs
w
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 02-02-2012, 04:44 AM   #34
Wasp
Supa10 pilot
Oddometer: 1,062
w
All the info and pics are on your pewter Woody.
Move your arse mate - You dont have any spare time for rest...
You'll be dead one day - You can get all the rest you want then..
Greg.
The original WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=595933
The NEW "Long Term" WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=778809
Wasp is offline   Reply With Quote
Old 02-02-2012, 05:19 AM   #35
Built to Last
Oddometer: 3,426
tire sizes and clearance on the Tenere ST
Greg.
hi greg what a hoot chatting with ya mate.,,.am taking the liberty of sharing your home-work with the troopies,,,,i'm also adding a few extra tire dimensions based on my actual measurements and feedback of others,,,soooo,,,thanks to you/all of you:
''Just checking out tyres for the 21 front and 18 rear on the S10.
*Rear currently 150/70-17 = theoretical 641.8mm or 320.9mm rad
= 25.26'' OD
*Heidenau K60 '' = 25.75''
*Metzler Karoo '' = 25.125''
*Mefo Explorer 140/80-18 = theoretical 681.2mm or 340.6mm rad =
26.82''
*Mefo Explorer 130/80-18 = theoretical 665.2mm or 332.6mm rad =
26.2''
*Dunlop Rally Raid 140/80-18 = 26.75'' or 26 3/4''
*Dunlop 606 130/80 x18 = 26.625'' or 26 5/8''
Swing arm clearance is approx 342.9mm =
13.5''...i'm sure greg is measuring center of axle to inside of swingarm
*Front currently 110/80-19 = theoretical 658.6mm or 329.3mm rad
Mefo Explorer 90/90-21 = theoretical 695.4mm or 347.7mm rad
*My suggestion is 140/80-18 rear (should clear ok) and 90/90-21 front (space the guard or make high guard)
you're reading my mind
I am ok with single disc front but would prefer to keep the balance (and save messing around with M/Cyls) of twin discs.
For the time being it would save some time,,,the big deal is getting the 21 up there...we can fine tune the single disc reality separately.
Would probably look at Galfers to save some weight..
we're already looking into that,,to see if they have em for the stock/oem hub as well as the galfer green pads for oem calipers ,,we know they have em for the ktm 950[the bolt pattern i copied for my Superlite-I hubs.....Folks,,,IMHO,,,based on the feedback from satisfied customers,,,there are no better mods for the brakes to convert to ss braided lines and the galfer wavy/floating rotors sporting their green pads especially off-road....the sensitivity,,feel and power are amazing
Do you recon that encoder plate could be machined into the front hub?
it'll definitely be incorporated into a new Superlite ST hub were i too design it
Or would it be better to just re-rim and re-spoke the OEM hubs?
this is the easiest least expensive way of going about it,,,that'is if you send me you're hub/wheel assy and/or i send you a Superlace kit and you lace n true it or have someone down there do it for you...if we do it all well then i will warranty my handiwork for a year
Just thinking about the masss and what they may desire This would be far and away the most sought after mod I think.
well i have 3 orders for ''option b'' ie re-spoke with my Monzter kits and new rim
Regards,
GregBrown'' quote
PS: and for the curious,,here's a link to a tire fitment chart on my website:
http://www.woodyswheelworks.com/rim_and_tire.htm
please note the lower the tire profile the wider the rim ya need a wider rim to support the lower sidewalls,,this of course is counter=productive when going fast in the rough...lower tire profiles and hard objects is good for me but not for you
woody
woody's wheel works screwed with this post 02-03-2012 at 08:49 AM
Old 02-02-2012, 01:53 PM   #36
Built to Last
Oddometer: 3,426
the most miseable news...no Tenere ST wheel parts available anywhere in usa
'nuff said,,i'll post part #s shortly,,no parts anywhere,,no due date anytime
w
so here's the parts list of all that's needed for front wheel..Note there are no sub-assemblies hence ya have to order everything individually
for some reason cannot paste parts diagram
the parts list in usa $$$..i'll highlight the components needed for sure ..ie without totally dismanteling your OEM wheel assy,,,essentially swapping the wheel with easily removable/recyclable assemblies...thus minimally $410 for the hub assy...complete
Tag Part # Description Price Qty
1 23P-25111-00-00 HUB, FRONT $323.87
2 23P-25117-00-00 SPACER, BEARING $12.84
3 93306-07208-00 BEARING $17.75
4 93106-28043-00 OIL SEAL $5.80
5 2S3-2517G-00-00 ROTOR, SENSOR $26.59
6 90149-05030-00 SCREW updated part # [6feb '12]
Call Us
7 94425-19003-00 RIM (2.50-19) $509.20
8 23P-25104-00-00 SPOKE SET, FRONT $77.08
9 94111-19020-00 TIRE (110/80R19 M/C 59V) | UR BRIDGESTONE $174.48
10 23P-25398-00-00 BALANCER, WHEEL | UN $2.56
11 93900-00030-00 VALVE, RIM (TR412) | TAIHEIYO $7.47
12 23P-25186-00-00 COLLAR, WHEEL $11.40
13 23P-2517A-00-00 HOUSING, SENSOR FRONT $67.80
14 23P-25183-00-00 COLLAR, WHEEL $13.80
15 93210-26668-00 O-RING $2.86
16 4XV-25181-10-00 AXLE, WHEEL $41.95
woody's wheel works screwed with this post 02-06-2012 at 12:04 PM
Old 02-03-2012, 12:58 AM   #37
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,574
Geeze, with a 21" and 18" on these bikes I might even buy one.
PM Obe01 the part numbers or post them and We can see if they are available in Australia.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 02-03-2012, 04:47 AM   #38
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,312
I concur that 13.25" to maybe 13.4" for swing arm clearance, 13.5" might be zero clearance, plus center stand crossbar also comes into play about the same distance.
The 18 rear would raise the gearing a bit also.
K60 Scout makes a 150/70/18 which is about 26.27" OD.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker screwed with this post 02-03-2012 at 05:18 AM
llamapacker is offline   Reply With Quote
Old 02-03-2012, 08:56 AM   #39
Built to Last
Oddometer: 3,426
attaboy for bringing center-stand cross-bar into the mix!
good job mate,,,'tis often overlooked[not really]...and i'm glad you brought the subject up..
FYI,,we usually can gain a bit of clearance on the swing arm by just warming the contact point with a torch and giving a few wacks with a mallet..simple effective and doesn't hurt the integrity/strength of your swingarm.
thanks for participating
woody
Old 02-03-2012, 09:20 AM   #40
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Part numbers
Since you will be changing the whole wheel, the part numbers needed (without the rim and spokes) are the following:
23P-25111-00 HUB, FRONT (1)
23P-25117-00 SPACER, BEARING (1)
93306-07208 BEARING (2)
93106-28043 OIL SEAL (2)
2S3-2517G-00 ROTOR, SENSOR (1)
90149-05029 SCREW (5)
The following may not be needed when changing wheels:
23P-25186-00 COLLAR, WHEEL (1)
23P-2517A-00 HOUSING, SENSOR FRONT (1)
23P-25183-00 COLLAR, WHEEL (1)
93210-26668 O-RING (1)
4XV-25181-10 AXLE, WHEEL (1)
We should also include the front brake discs unless you want to swap them every time you change wheels (unless WWW supplies the discs for our OEM calipers:
23P-2581T-00 DISK BRAKE ASSY (2)
90149-06043 SCREW (10)
The rear end is as follows:
23P-25311-00 HUB, REAR (1)
93306-27212 BEARING (1)
93306-07208 BEARING (1)
93106-28043 OIL SEAL (1)
23P-25317-00 SPACER, BEARING (1)
The following can be not considered if you wish:
23P-25366-00 CLUTCH, HUB (1)
93306-00521 BEARING (1)
23P-25377-00 COLLAR, WHEEL (1)
5JW-25319-00 SEAL, HUB DUST (1)
23P-25381-00 AXLE, WHEEL (1)
90201-22014 WASHER, PLATE (1)
90201-18013 WASHER, PLATE (1)
90185-18009 NUT, SELF-LOCKING (1)
23P-2537A-00 HOUSING, SENSOR REAR (1)
And the rear brake:
23P-2582W-00 DISK, REAR BRAKE 2 (1)
90149-08024 SCREW (6)
23P-2581A-00 PLATE, DISC (1)
Cheers,
Thagua
'Let's go adventuring'
Thagua screwed with this post 02-03-2012 at 09:22 AM Reason: Mispelling
Thagua is offline   Reply With Quote
Old 02-04-2012, 10:41 AM   #41
protondecay123
protondecay123's Avatar
Oddometer: 466
Agreed..
The best solution (IMHO) is 21" and 18" with the big lace kits on the factory hubs...
That would make me very happy in my underpants
Greg.
Subscribed. Though I would be more interested in 21", 18" wheel set with your hubs, discs,etc, if can keep the TCS and ABS.
Sometimes the Lights are all Shinin' on Me
Other times I can barely see
Lately It Occurs to Me
What a Long, Strange Trip it's Been!
protondecay123 is offline   Reply With Quote
Old 02-04-2012, 05:47 PM   #42
Bill 310
Poser Emeritus
Bill 310's Avatar
Oddometer: 3,173
Woody, check your PM's
w
Canada "It's a rough place, son. In fact, you have to puke twice and show your razor just to get in. Better grow some whiskers if you wanna go to Canada." Ronnie Hawkins when asking Levon Helm to join his band and play in Canada.
Bill 310 is offline   Reply With Quote
Old 02-06-2012, 02:53 AM   #43
obe01
Wannabe Adventurer
obe01's Avatar
Oddometer: 1,269
How ya going Woody...
How we going Woody I hope you have had no sleep yet. Greg will be greatly disappointed if you have....
Are we making progress matey or is it the OEM parts that is the issue.
Good work so far matey,
Johnnie
SUPER TENERE'
Old 02-06-2012, 02:56 AM   #44
jaumev
jaumev's Avatar
Oddometer: 1,501
Hi guys. Im still concern about how the changes of both wheels can affect the ABS and TC.
Even if we keep the original hubs, I assume these systems are programmed with the original wheels diameter so, if we increased 2 the front wheel and only 1 the rear I supposed the systems ad to be reprogrammed or they will work wrong???
Old 02-06-2012, 03:22 AM   #45
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 309
ABS and TC are some of this bikes' greatest features, and lets admit, we all paid a lot for them when purchasing the bike, so it's of best interest to keep them.
Also, both sistems are quite sensible to their imputs. This ABS can work on and off road, knowing how to behave only by recurring to speed sensors. I think it's more than probable that a different wheel diameter will screw it to some degree.
Ze_zaskar is offline   Reply With Quote
Times are GMT -7.   It's 09:46 AM.
