02-13-2012, 05:11 PM
#61 | |
Built to Last
Oddometer: 3,087
18" rim swingarm clearance with big knobbies???
check this post for tire sizes we think may work,,, http://www.advrider.com/forums/showp...7&postcount=35 Greg n i,,, after a bunch of discussion settled on using a 140/80 x18 knobby ,,the lower profile works better with a 3.5x 18 rim,,,it's 3/4'' narrower than the 4.25x17 rim used for the 150/70 x17 tires...notice that the lower the aspect ratio the wider the rims that are called for. this tire rim combo falls into what i call a great ''all-around'' tire/rim size ie: the 50-50 setup.. if you're mainly interested in offroad..than the 2.5 x18 and a 140/90 knobby may prove better...sidewalls pulled in ,,more rim protection,,,, woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
02-14-2012, 12:15 AM
#62 | |
Oddometer: 916
02-15-2012, 03:36 PM
#63 | ||||||||||||||
Built to Last
Oddometer: 3,087
so here's a little more eye candy...
just got some photos shot....
here's the Superlite II hub with Super Tenere kit . It includes: 12 ST disc adapters 2 ea outer spacers 4 ea 6906-2RS bearings repacked with waterproof,grease 1 ea inner spacer
here's another teaser,,,SUPER-DUTY SS SPOKES sporting machined SS nipples!!!, no more rusting,,no more corrosion,,,no more snapping,,,no more loosening [comes with set screws],,,and no more having 3-4 spoke threads show up at the nipple,,, ![]()
![]() left to right: a.. new 4mm bmw WWW super-duty ss spoke with longer ss nipple b..3.5mm oem bmw ss spoke with new WWW longer ss nipple c..3.5mm oem bmw with powder-coated steel nipple [post '98] d.. 3.5mm oem bmw painted nipple [pre '98] so here's a pic showing the oem size galvanized spoke and nipple and our new Super-Duty 6g x.175 ss spoke and it's ss nipple for your Super Teneres,,,..the four BMW nipples to right were explained in the previous caption/pic ,,,,did a little measuring /weighing with what was readily available 1,,SUPERDUTY ss n ss spoke n nipple kit =2 lbs -11oz 2,,,1.6 x21 Excel double sig = =========3lbs 7.5oz or,,, 1.85x21 Excel ============== 3,,,complete hub assy with 11.75'' Galfer disc= 7 lbs 7.5 oz 4,,hence the wheel should weigh in at 13lbs 10oz as is ,,,,,i cant imagine adding more than for the slightly wider rim and 12.2'' discs FYI,,a 90/90x21 Rally Raid with inner tube and rim band weigh 8lbs 10oz When i get more data,,,i'll edit it all again,,,several of my troopies are out so i didn't have access to the other data w
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 02-21-2012 at 06:36 PM |
02-15-2012, 03:50 PM
#64 |
Creaks When Walks...
Oddometer: 1,131
Pure SEX!!!
Jay-Sus, Woody! Those things are *GORGEOUS*!!! ![]() Any more word on getting those to work with the stock ABS/TCS? And will they be available to lace to some stronger, tubeless rims in the stock 19" front and 17" rear sizes? Thanks! Dallara ~
~ You never see a motorcycle parked outside a psychiatrist's office ~
02-16-2012, 12:23 AM
#65 |
Supa10 pilot
![]() Thanks to Power Girl AND WOODY.... ....It still works! Greg.
The original WaspWorks S10 detail & evolution thread: http://www.advrider.com/forums/showthread.php?t=595933 The NEW "Long Term" WaspWorks S10 detail & evolution thread: http://www.advrider.com/forums/showthread.php?t=778809 |
02-16-2012, 06:34 AM
#66 |
Oddometer: 916
Whow!!
02-16-2012, 09:00 AM
#67 | |
Built to Last
Oddometer: 3,087
more Q&As regarding the ST wheels...
02-19-2012, 05:58 AM
#68 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Built to Last
Oddometer: 3,087
hooray we found a 310mm wavy/floating rotor!!!
good news mates,,,yesterday afternoon Zach my numero uno Super-lacer stumbled upon an OEM KTM 310mm rotor,,,don't remember off-hand the model it's used on,,you just have to know it's gorgeous[[probably because it's made by Galfer and or Braking[who used to be part of Galfer from what i'm told] weighs 2lbs 7oz or 1105.6grams and is 5mm x310mm
![]() they list @ $310 ea that's $10 less than Galfer's price for the 320mm rotor,,,pics will follow,,, FYI i ordered 5 ea ![]() here's your lagniappe for the day..your very own oz to gram conversion table 1 Ounce = 28.3495231 Grams To convert ounces to grams for any other values, or between gram to ounce conversion, please go to Weight Conversions Ounce To Gram Chart
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 02-20-2012 at 01:37 PM |
02-20-2012, 01:55 PM
#69 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Built to Last
Oddometer: 3,087
![]() they list @ $310 ea that's $10 less than Galfer's price for the 320mm rotor,,, FYI i ordered 5 ea ![]() here's your lagniappe for the day..your very own oz to gram conversion table 1 Ounce = 28.3495231 Grams To convert ounces to grams for any other values, or between gram to ounce conversion, please go to Weight Conversions Ounce To Gram Chart
02-21-2012, 03:50 PM
#70 |
Let's go adventuring...
Oddometer: 251
Fender extension
Hi Woody ... just to let you know that this week I'll have my front fender raised 30 mm as you can see below ... will have to extend the brake line that goes from one caliper to the other in another 30 mm ... give me your thoughts
![]() ![]() ![]() ![]() ![]() ![]() How is my black 21" rim and spokes doing? Cheers, Thagua
'Let's go adventuring' |
02-21-2012, 04:43 PM
#71 |
Built to Last
Oddometer: 3,087
Here's Some Color Choices
Some possible color options,,,hopethat gold matches Greg's fork sliders
![]() from amerika with lovexxxxx
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 02-21-2012 at 06:29 PM |
02-21-2012, 07:31 PM
#72 | |
Built to Last
Oddometer: 3,087
Thagua's brake restructuring dilemna etc
w
02-22-2012, 07:00 AM
#73 |
Oddometer: 251
OEM vs Superlite
Howdy Woody ... excellent if you could make that brake lines coming independently from the junction to each caliper ... the guide used on the left side can be used also on the right side.
Trust what Wasp makes (I'm his loyal follower) and ... what would be the difference between the OEM hubs and the Superlite double discs ordered by Wasp? ... will I need new calipers for the Galfer rotors? ... much difference in price? Keep your lady happy taking her out to dinner. Cheers, Thagua
02-22-2012, 11:45 PM
#74 |
TWIN Cylinder ADV
Shit Hot
Lookin Good.
Hovering around waiting to see what happens.
Hodgo RD07 Africa Twin, KTM 950 Super Enduro www.facebook.com/KTM950SE Retired.. CR500E XRV750W,XTZ750,XLV750R,XR600R,CM250M,CB250T,CR125R,YZ100H |
02-23-2012, 03:36 AM
#75 | |
Wannabe Adventurer
Oddometer: 1,270
.Hey Woody is it wrong to be arroused by your piccies and work....mate..
SUPER TENERE' ![]() |
