Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 795 votes, 4.98 average. Display Modes
Old 03-11-2013, 09:49 AM   #6436
janeuner
Get Some
Oddometer: 1,473
Naturally a page break. Funny how the good stuff is always at the bottom of the last page.
Originally Posted by Geek View Post
XVM - First Time Install.
For reference, here is the official XVM website in English:
http://www.modxvm.com/en/
I have seen some of you guys in TS struggling with your XVM install so I thought I'd take a minute to give the steps.
If you have never installed XVM before - you MUST do all of these steps.
You can NOT just copy Brian's folder. You can NOT just click on Dave's link to "XVM Updater".
(unless you are really lucky and happen to have all of the components pre-installed; but it is unlikely for most users).
**CLOSE WORLD OF TANKS** before you start
1) .NET Framework:
You must have the microsoft .NET framework on your machine - chances are that you do have it, so we'll skip how to get it. If you do all these steps and it doesn't work you are missing .NET.... let me know and I'll help you get it.
Here is a little application that will allow you to check your .NET version if you want to:
http://www.tmgdevelopment.co.uk/versioncheck.zip
You need version 3.5
2) Dokan Library:
You must have the Dokan Library Installed. You most likely do NOT have this library installed. to Install it:
http://dokan-dev.net/en/download/#dokan
You want the file:
Dokan library
dokan-0.6.0 2011/01/10
Here is the direct link to download the file you need:
http://dokan-dev.net/wp-content/uplo...tall_0.6.0.exe
Just run that exe and follow the steps to install it (all default is good). AFTER you have the Dokan Library installed - you then want to download XVM Stat.
3) XVM Stat
Here is a directly link to the XVM Stat file:
http://www.curse.com/wot-mods/worldo...-full/download
This will save a file (zip) on your hard drive.
Put that file in your World of Tanks GAME FOLDER (usually: C:\Games\World_of_Tanks and NOT your mods folder) and then extract it in THAT folder. This will put two files in your game folder: xvm-stat.exe and xvm-stat.exe.config.
THESE are the files required to run XVM. NOT the xvmconf file.
You can delete the three .txt files that came with the zip if you like.
4) How to Start XVM and WoT
To play with XVM running you now run world of tanks via the xvm-stat.exe file - NOT the world of tanks icon you have used in the past. What I do is right click on this Icon, click "create shortcut" and then I can move/use this shortcut to where ever I like to launch world of tanks (i.e to my Task Bar in Windows 7).
5) XVM Config
Now that XVM is installed - we can talk about the Config file. Everything that XVM does is configured by a Text file called: XVM.xvmconf
It is located in your "World of Tanks\res_mods\[game version]\gui\flash\" folder.
The graphic user interface that has been linked to before - is actually a GUI that is simply editing this TXT file for you so you don't have to do it.
Right now you do not have a XVM.xvmconf
You can make one using this GUI:
http://www.modxvm.com/en/xvm-xvm-xvm...ration-editor/
Where at the end you would click SAVE and then put that file in your:
C:\Games\World_of_Tanks\res_mods\0.8.4\gui\flash
If you want to see what the contents of that file look like here is an example:
https://code.google.com/p/wot-xvm/so...svn1189&r=1189
Another thing you can do is download OTHER user's configurations - they are usually named after the user - like TopGeek's XVM config - basically people who have taken the time to customize that TXT file to a cool way they like and they've shared with the world - there are LOTS of them out there:
http://www.koreanrandom.com/forum/fo...onfigurations/
...but chances are at this point you just want to play and don't understand what all of those features are - so you just need a sample XVM.xvmconf file to get you started... I'd give you mine but it has been modified extensively for 2560x1600 resolution (PM me if you run that resolution and want to try it).
So lets make a quick/simple XVM.xvmconf file:
Go to the GUI editor:
and click SAVE (in the flash window) - it will open your My Documents most likely and default to the file name XVM.XVMconf. Change to your C:\Games\World_of_Tanks\res_mods\0.8.4\gui\flash folder and save that XVM.XVMconf file there - IN THE FLASH FOLDER.
That's it. You now have XVM installed.
LAUNCH XVM with the SHORTCUT we made earlier - NOT with your WORLD OF TANKS ICON!
Now that it is installed you can start tweaking the GUI with the editor - saving the XVM.xvmconf file each time and updating it on your PC to see the results.
**you must restart World of Tanks between every XVM change**
Some popular XVM configs:
Engiands: http://www.curse.com/wot-mods/worldo...nds-xvm-config
Grandpas KISS (which ironically it is not simple): http://www.curse.com/wot-mods/worldo...-interface-xvm
Roughnecks: http://www.curse.com/wot-mods/worldo...m-test-7-5beta
I hope this helps - good luck!
And before someone puts up another post ... let's keep these links together!
Originally Posted by MN_Smurf View Post
Found the battle statistics mod updated for 8.4....link here. It does fix the text readout for the British TD's.
Gonna bookmark that for reference. Great post.
'06 Suzuki Boulevard C50
'92 Suzuki GS500E (sold)
janeuner is offline   Reply With Quote
Old 03-11-2013, 10:25 AM   #6437
Ebein
Ebein's Avatar
Oddometer: 411
Nathan, Papalobster and I have a fun run on Abbey
Ebein Nathan Papa 2xSU-100 + Chaffee
http://www.youtube.com/watch?v=nGNet4Vj-yU
Ebein : WoT Completed T110E3,T110E4,T110E5,T57 Heavy,JagPZE100,WT-E100,E100,Maus,E50M,IS4,IS7, Obj268,FV215B 183,BatChat 25t 29 Tanks to go.
Ebein is offline   Reply With Quote
Old 03-11-2013, 10:48 AM   #6438
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 11,203
be nice to sticky all these useful links and downloads you guys are putting up
vwboomer is offline   Reply With Quote
Old 03-11-2013, 11:00 AM   #6439
janeuner
Get Some
Oddometer: 1,473
The T-34 killed himself? Funny stuff right there!
TDs need to move immediately after firing in the open. You were a sitting duck for the arty up on that hill.
Old 03-11-2013, 11:22 AM   #6440
Gizmata
Oddometer: 1
Question Interested in joining
Hello, I play on the US servers and mostly play the German TD's. I am mainly looking for others to platoon with on a regular basis.
It was suggested I ask about joining to make it easier to find platoons.
Thanks,
Gizmata
Gizmata is offline   Reply With Quote
Old 03-11-2013, 12:01 PM   #6441
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,766
Gizmata is a coworker of mine (yes, another one)...... I'll forward the TS info and clan invite.
'09 Kawi Versys
"A life is like a garden. Perfect moments can be had, but not preserved, except in memory. LLAP" - Leonard Nimoy
MN_Smurf is online now   Reply With Quote
Old 03-11-2013, 12:14 PM   #6442
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 11,203
been doing pretty well in my M4 today. But when I jump into a bigger heavy tank...not so much.
Old 03-11-2013, 01:42 PM   #6443
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 8,463
The M4 special ends today, right? Need to move the crew back to the Super Pershing and sell it.
Proprietor of The Tidewater Forge Hot iron is my passion. Fire is my mistress. Let's dance.
35 Years of Scouting Blog for Bushcrafting and Boy Scouting experiences.
Smithy is offline   Reply With Quote
Old 03-11-2013, 04:11 PM   #6444
Geek
oot & aboot
Geek's Avatar
Oddometer: 32,065
If any of you hosers are playing the new Sim City - drop me a PM and we can be neighbors
Old 03-11-2013, 04:31 PM   #6445
Bodwick
Odd Bod
Bodwick's Avatar
Oddometer: 1,267
I'm tempted....
Is there a biker gang clubhouse plug-in?
You have just begun reading the sentence you just finished reading.
Bodwick is offline   Reply With Quote
Old 03-11-2013, 07:26 PM   #6446
AKjeff
AKjeff's Avatar
Oddometer: 5,473
Would the OP mind adding them to the first post? Make it real easy to find everything that way.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 03-11-2013, 08:25 PM   #6447
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,870
They change too much to make it worth throwing up there.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-11-2013, 08:32 PM   #6448
Dysco
Puppy wrangler
Dysco's Avatar
Oddometer: 16,629
Dysco screwed with this post 03-11-2013 at 08:38 PM
Dysco is offline   Reply With Quote
Old 03-11-2013, 09:34 PM   #6449
Dysco
Puppy wrangler
Dysco's Avatar
Oddometer: 16,629
Still downloading...
Old 03-11-2013, 09:36 PM   #6450
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,870
Originally Posted by Dysco View Post
The curse links and korean links will be updated with each patch is what I meant. That, and there are plenty of other informational links recently posted that will also change with each WoT update.
For a while now not much has changed as to where you place files and folders, but even they have changed over the course of the game.
their motorcycles
RyanR
Thread Tools
Times are GMT -7.   It's 09:34 AM.
