Thread Tools Rating: Thread Rating: 745 votes, 4.98 average. Display Modes
Old 08-24-2013, 09:35 AM   #11221
See-Double-You
See-Double-You's Avatar
Oddometer: 1,674
Originally Posted by janeuner View Post
Wherein my LTP shall Getsome ELC AMX, KV-1S, and SU-100, before finally succumbing to French cheater orb tank.
This might be my greatest ever performance in World of Tanks.
http://wotreplays.com/site/310439
LOL worthy:
Bounced off
Bounced off
We just dinged him
Bounced off
Ricochet
We just dinged him
Ricochet
Bounced off
Critical hit
Ricochet
Bounced off
Ricochet
Hit
Penetration
We just dinged him
Ricochet
Bounced off
Got 'cha
CW
" Suggest you stick with failure analysis of Pork Chops " - -Benesesso
See-Double-You is offline   Reply With Quote
Old 08-24-2013, 09:38 AM   #11222
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
Take an E75 into a Tier 8 battle (it is a Tier 7 tank with a Tier 6 gun) and you get well acquainted with those sounds
Old 08-24-2013, 10:32 AM   #11223
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 8,377
You mean E25... the 75 is the T9 Heavy.
Proprietor of The Tidewater Forge Hot iron is my passion. Fire is my mistress. Let's dance.
35 Years of Scouting Blog for Bushcrafting and Boy Scouting experiences.
Smithy is online now   Reply With Quote
Old 08-24-2013, 12:07 PM   #11224
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
Oops yup. The little tiny one.
Old 08-24-2013, 12:13 PM   #11225
DomEOD
'murica
DomEOD's Avatar
Oddometer: 2,466
I think I'm finally learning how to use the T34... Hide & snipe.
'14 F800GS
Initial Success or Total Failure.
DomEOD is offline   Reply With Quote
Old 08-24-2013, 12:22 PM   #11226
Theaty Hannington
Oddometer: 1,361
Great work!
Also, try and play hull down, exposing only the front of your turret to the enemy. Your turret is strong. Hop into TS when you want. A lot of us have that tank and can help you out a bit.
Two Noobs Tour NW Brews: http://advrider.com/forums/showthread.php?t=722008
"Everyone who isn't playing your tank in that round knows how to play it better." - Morgue
Theaty Hannington screwed with this post 08-24-2013 at 12:29 PM
Theaty Hannington is online now   Reply With Quote
Old 08-24-2013, 12:37 PM   #11227
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
Norm: here's the final build. Rides great!
Old 08-24-2013, 12:53 PM   #11228
Smithy
Smithy's Avatar
Oddometer: 8,377
That looks like it's going to work out fine.
Until you hit one good bump at speed.
The leverage that's going to put on your rear sub-frame and luggage plate seems incredible to me. Maybe KTM's are built of tougher stuff, but... wow.
Old 08-24-2013, 12:58 PM   #11229
James Adams
A few crayons short.
James Adams's Avatar
Oddometer: 10,222
But we all know that Ed neither goes fast nor ever would hit any bumps.
505 XC-F DUKE 690
James Adams is offline   Reply With Quote
Old 08-24-2013, 12:58 PM   #11230
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
You'd be amazed how light the entire thing is Smithy - the bike is all carbon fiber and weighs 28lbs with the dropper post ready to ride. The 8020 aluminum structure is the 15LS series -super light (but strong). I put 200 lbs on the end of the bar and all it did was squat the suspension (no flex at all).
The bike is designed for a passenger and full up touring luggage (which would be 300+ lbs behind the rider?). I suppose I could get out the calculator and figure out the moment of inertia.. but that is too much like work
I am thinking about triangulating the rear to the side racks.. we will see
That said, I will keep close tabs on everything.
p.s. what Ian said
Geek screwed with this post 08-24-2013 at 01:03 PM
Old 08-24-2013, 01:10 PM   #11231
Smithy
Smithy's Avatar
Oddometer: 8,377
Clearly you've thought it through - but will the bicycle withstand it? Will the bolts?
I'd have mounted it sideways, so all the weight was above the plate, and taken off both wheels. I've seen that done before to good effect, and a frame alone shouldn't wipe out the car next to you.
Like I said, good luck.
Old 08-24-2013, 01:57 PM   #11232
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,729
At the very least, I think I'd slide the frame the bike is on forward so it overhangs the rear seat a bit and center up the load on your trunk plate......
'09 Kawi Versys
"A life is like a garden. Perfect moments can be had, but not preserved, except in memory. LLAP" - Leonard Nimoy
MN_Smurf is offline   Reply With Quote
Old 08-24-2013, 01:59 PM   #11233
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,729
Little touchy with those early spots - I probably wouldn't have tried those, especially since the Indien was proxy spotting you at the time. Nice flank around the Indien. I'd have loaded APCR for the second clip against the IS-6, but it wasn't necessary because he nicely showed you his rear. Nice roll with the SP fire at the end.
I knew that position was iffy, but you only live once....you notice I pulled back and looked to the flank at the first near miss. Funny thing is, I thought I loaded Premium shells for the third clip at the IS-6, until I looked at the vid.
As far as the SP fire goes, yeah that was nice. Made up for the lack of a 5th shot....
'09 Kawi Versys
Old 08-24-2013, 02:02 PM   #11234
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
We are going to Crested Butte on the 950s for a multi day camping/mtn bike riding trip.
I am keeping the seat behind me clear for the camping gear.
I didn't stay at a holiday inn last night.. but I do have an engineering degree.
If it was of concern I'd do the math. As I mentioned.. I may triangulate a bit.
I appreciate the input gents
Geek screwed with this post 08-24-2013 at 02:09 PM
Old 08-24-2013, 02:19 PM   #11235
Big Bird 928
Oddometer: 2,653
due to the price of replacing the bike, will your insurance cover it in the case of an accident or damage of some type while attached?
Didn't take me long to sort out the derpapotomous tactic again.
Big Bird 928 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:59 PM.
