Old 09-02-2013, 02:43 PM   #121
I Am Murphy OP
Vagabond Sportster
I Am Murphy's Avatar
Oddometer: 111
2/3's done with the inner ring...so tired of this thing!
I Am Murphy is offline   Reply With Quote
Old 09-02-2013, 04:50 PM   #122
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Cool2
...bandwidth at photobucket should reset on the 6th...
Old 09-02-2013, 04:56 PM   #123
Dirt Road Cowboy
Treasure Hunter
Dirt Road Cowboy's Avatar
Oddometer: 447
I use Image Shack http://imageshack.us/
They seem to work a lot better than Photobucket.
Of course, there's always SmugMug!
Originally Posted by Ginger Beard View Post
Motorcycling has become something where a bunch of terrified cunts wont so much as ride to the corner store without wearing a Storm Trooper helmet and covering themselves in dayglow Nancy suits.
Dirt Road Cowboy is online now   Reply With Quote
Old 09-02-2013, 05:21 PM   #124
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,648
I got a free terabyte of space on both my flickr accounts.2 free TB of space.It's like sore dick.Ya can't beat it.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-02-2013, 06:57 PM   #125
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Thanks for all the new destination ideas. I slapped up an imageShack acct real quick to keep the updates coming for now, and I'm hoping that I was the cause of the majority of the bandwith usage.
Anyway, this is where I left off.
Uploaded with ImageShack.us
Old 09-04-2013, 03:10 PM   #126
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Over some of yesterday and a few moments today, I made a little more progress. I thought the little teeny pieces were going to be the most challenging of all, but I'm discovering that I thought wrong. It turns out the little pieces require a lot of attention, but only for a short period of time, and since they're so small there's not much stuff to work around. After cutting out the large white pieces for the lower background, it is safe to say that they were significantly less enjoyable to work with.
I think I mentioned in a recent update that I was going to have to replace the head again…here are several attempts at getting closer to what I envision...
Sewing the white lower base in proved to be equally tedious when compared to the cutting of the shape - having to alternate between trimming on the spot and stretching into place with the thread means paying close attention not just to the stitch that's being sewn at the moment, but also maintaining three stitches ahead to make sure you don't fix something down that will later need to be trimmed. At any rate, the lower background work is done.
I began laying in the upper background today, and as you can see I also changed my mind about even the newest head. I'm just gonna put the entire background together and hope I can draw, cutout and sew down a better head later.
Old 09-08-2013, 05:24 PM   #127
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Old 09-08-2013, 05:30 PM   #128
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Old 09-09-2013, 02:43 AM   #129
DRjoe
DRjoe's Avatar
Oddometer: 5,151
That is the coolest seat I've ever seen and the most labour intensive one as well.
Prety impressive that you had the will power and forsight to make that and have it turn out looking so good.
Well done.
Oh what the hell are the metal things your making?
Old 09-09-2013, 05:04 AM   #130
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,648
Shits about to get interesting around there.
Old 09-09-2013, 08:24 AM   #131
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,774
Flux capacitors ?
bk brkr baker is online now   Reply With Quote
Old 09-09-2013, 12:14 PM   #132
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,648
Originally Posted by bk brkr baker View Post
Flux capacitors ?
Old 09-09-2013, 03:08 PM   #133
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
Well done.
Originally they were intended for use as flux capacitors, but my mom insists that time travel will produce undesired side effects and is urging me to avoid it. So after scratching my head for a bit, I decided that I will make turn signals to replace the stock ones that rattled off recently.
Old 09-09-2013, 03:14 PM   #134
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
I was so stoked about the new seat. I just had to ride. I knew my turn signal had rattled off, and the threads had been ripped out of the housing in the process. As noted above, I had already begun fabricating new turn signals, and can probably have them done in a pretty short amount of time, but that wasn't going to help me at all for today. I decided to chance it and ride, dangling turn signal in tow.
Well, it didn't take too long for the long bolt that passes through the fender and the mounting arm of the turn signal housing to work its way up against the tire...and shortly thereafter, through the side wall. It was like a friggin' can opener had separated the tire along a perfect seam.
...So I will no doubt continue fabrication of the turn signals, but may be down a little longer while I save up for a new tire.
Old 09-09-2013, 03:19 PM   #135
I Am Murphy OP
Vagabond Sportster
Oddometer: 111
I drew up both of these possible schematics for the PCB that will go inside the 2" copper housing. I decided that the above would be best for what I'm doing. The one below would be much better for the space I have to work with, but in that instance, if one LED dies, the current that it once consumed would be dispersed across the others, and since I'm going for a full 32mA to be as bright as possible, it would only take one or two to end up blowing all the rest. The schematic above has a current limiting resistor on every LED so if one should die, the others will be unaffected.
Times are GMT -7.   It's 12:30 PM.
