Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 01-29-2013, 05:23 AM   #571
Shaggie OP
Unseen University
Shaggie's Avatar
Oddometer: 2,622
Originally Posted by NordieBoy View Post
Droid or iDevice?
I use SportyPal which has a driving option.
iphone
will have a gander - ta mate
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 01-29-2013, 12:04 PM   #572
igormortis
igormortis's Avatar
Oddometer: 1,301
Try one called Greatest Road. Might be what you're looking for.
igormortis is offline   Reply With Quote
Old 01-29-2013, 12:54 PM   #573
ztaj
jatz
ztaj's Avatar
Oddometer: 933
Originally Posted by cooneyr View Post
Bah - you lot are a bunch of lightweights. I worked 65 hour weeks, did no exercise and ate too much last year - 116kg at the moment. Awesome result - NOT. 110kgs was always my must do something weight - Opps guess I blew past that one!
Went to the quacks the other day about other matters and got told I should be about 86kgs. I've not been that since I was about 15. Rugby, alpine climbing and cycling meant I put on weight not lost it.
Started cycling over the holidays around Nelson. Been for two quick spins down here to try and keep it going.
*rushes to find scales*
Woohoo back to my pre smoke free weight....86kg. I was up around 110 after knocking off the smokes
I wouldn't recomend the weight loss program I followed though
ztaj is offline   Reply With Quote
Old 01-29-2013, 08:08 PM   #574
Padmei
enamoured
Oddometer: 3,604
Yeah it's not the weight that matters to me - it's just the threshold i gave myself knowing that I always hovered below it when doing manual work & regularish mtbing - bugger xmas overeating. Also the fact that it doesn't spread out evenly on my body but concentrates in a nice round baby belly.
Good stuff Bart getting out there running - it's not usually the first run that's the worst but the 2nd & 3rd ones that feel like forever. I reckon there would prob be as many pulled archilles/ hammys in the week after new year as there aer the few weeks before footy season starts.
Anyway it's about 30deg outside so i may as well saddle up & suffer up Bayview rd.....
Padmei is offline   Reply With Quote
Old 01-29-2013, 09:38 PM   #575
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
Do any of you guys know much about concrete drives? The dry weather has made some of the soil shrink away. Now I am concerned that this will cause it to break up. Also of concern is the thickness of the concrete. It looks more like 75mm to me, instead of the 100 mm it should be.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 01-29-2013, 10:01 PM   #576
DLRuapuke
Oddometer: 23
Driveway
Could be any number of problems...................
How old is it - dont look to ancient by the pics !
Has it R-mesh through it at all ?
Has it cracked on the surface ?
Is it one pour - you know from a big rotating drum truck thing ?
Certainly wasnt tamped and jiggled as per normal - the sides / outside edges are a give away !
Yeah probably should have been the 100mm depth - though some have been known to be less !
The cement / shingle brew AKA " concrete " - I use a 6:1 ratio and have never had an issue
this seems to be standard
Some say if its a good brew and 100mm thick / consistant mix and layed as boxed sections - this should suffice
for light vehicle traffic ?
Me - I always use reinforcing mesh
Never had a failure on me drives
Paths - still use 100mm depth but no R mesh - overkill perhaps but sure as shit aint doin it again !
Good luck with it
Gary
DLRuapuke is offline   Reply With Quote
Old 01-29-2013, 10:06 PM   #577
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
Less than two years
It should do, that's what I wanted
There is a hairline crack just to the right of the picture
Yes, it was laid by a concrete contractor
Good luck with it
Gary
Thanks for the quick response.
I was quoted for a 100mm drive with mesh. The question is, do I have to suck it in, or do I have some comeback? Would you try to shove some fine scoria under it?
R1150GS
R80GS Basic
Old 01-29-2013, 10:11 PM   #578
innathyzit
AKA Woodman
innathyzit's Avatar
Oddometer: 981
Looks to me like Padmei has been standing on it. Haven't you noticed he has put on a bit of weight lately?
innathyzit is offline   Reply With Quote
Old 01-29-2013, 10:16 PM   #579
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
He is an internet ghost, I doubt that he can put on weight.
I've put on more than I'd like to have, a year ago I was at 78kg and now it's more like 82kg. Way too much. I am working on it. But in the mean time, I'll stay of that section of the drive.
R1150GS
R80GS Basic
Old 01-29-2013, 10:22 PM   #580
Underground
Underground's Avatar
Oddometer: 282
That looks like a bad concrete job to me,and I know about concrete.
Its full of air -lack of or no vibration.
and its been laid on uncompacted ground.
Tell them to rip it up and do it again properly.
'88 RD03 XRV650... X 2
'88 NX650 Dominator
NX650 Dominator build http://www.advrider.com/forums/showthread.php?t=730473
Dommie by sea http://www.advrider.com/forums/showthread.php?t=843646
Underground is offline   Reply With Quote
Old 01-29-2013, 10:38 PM   #581
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
I'll let them know that I am not happy. Let's hope they stand by their work, even if it's crap. Thanks for your input.
R1150GS
R80GS Basic
Old 01-29-2013, 10:50 PM   #582
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,047
might come up your way for a ride this weekend. do i keep hard left or right coming up the drive
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Old 01-29-2013, 10:57 PM   #583
Padmei
enamoured
Oddometer: 3,604
Funny you should be talking about driveways - I am getting quotes for mine at the moment - all 250m of it
Damn those pies
Old 01-29-2013, 11:17 PM   #584
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
Just come right up the middle. I hope you've been losing some weight, too.
R1150GS
R80GS Basic
Old 01-29-2013, 11:20 PM   #585
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,630
Damn those pies
I've paid $22000 for all my concrete work. The drive is about 30m, the area in front of the garage plus the patio and some paths. Just get a mixer and wheel barrow, that will do wonders for your weight
R1150GS
R80GS Basic
Times are GMT -7.   It's 12:26 PM.
