Old 02-03-2012, 07:46 PM   #1
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
New air box
Just wanted to show you guys a new air filtration set-up. Seems like everyone calls them airboxes but there is no "box" to it. This came about at the right time for me because I'm sick of my K&N sucking dirt.
Two 1/4 turn fasteners to remove it.
Glove box clearance
fitment around throttle bodies. All the left over silicone is from attemps to seal my old set-up when the dirt was actually coming thru the K&N.
Nice X-ring used for seal
filter has a cage inside.
Temp sensor and case breather bolt on to bottom plate
Here is the place making them. The owner is also a SuperDuke guy.
http://www.teamcprfab.com/
tahoeacr is offline   Reply With Quote
Old 02-03-2012, 08:13 PM   #2
LAYNFRM
slightly tarded
Oddometer: 68
hell yeah! let us know how it seals and works!
05 Kawasaki KLX110 plated D/S
05 KTM 950 Adventure FOR SALE
LAYNFRM is offline   Reply With Quote
Old 02-03-2012, 08:29 PM   #3
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
Seals great. Took those pics about three weeks ago. Had to make sure it was good stuff before I pass it on to the Crush.
10+hp on the SD. I'll head to the dyno as soon as I can.
Old 02-03-2012, 08:38 PM   #4
LAYNFRM
slightly tarded
Oddometer: 68
awesome. any idea on pricing? didn't see it on their site.
Old 02-03-2012, 09:50 PM   #5
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
$299. So we have our choices of BMC drop in for $100, DNA drop in $140, Moto Hooligan at $359, or DNA MKIII at $700. This one(not sure what he is going to call it) has more filter media than MH or DNA with lower cost.
My previous filters.
First insulate stock box with drop in DNA. 3 to 4 ft lbs gain. Snorkel prooved to be a restriction on the dyno
Next was Mars box. MH took this and added the raised roof.
Next went to a taller K&N and made a carbon fiber raised roof.
So now I'm sticking with the foam and thinking about NACA ducts to bring more air in.
Old 02-04-2012, 12:09 AM   #6
Kenbike
Oddometer: 675
I really like your new filter! Report your dyno findings. Have you been thinking of the carbon throttle body stacks being developed on the SD site?
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 02-04-2012, 03:44 AM   #7
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
Thumb
nice setup and the price is beter than the competitors with a open airbox.
I'm also curious how this setup will perform
'10 990SMT
Spark01 is offline   Reply With Quote
Old 02-04-2012, 08:25 AM   #8
fluff34567
fluff34567's Avatar
Oddometer: 1,054
NACA ducts only work at high airspeeds, any increase in air pressure would be absolute minimal. i assume its air pressure you would like to increase? but then you would need to seal the airbox area to maintain any ( i suspect zero) pressure increase.
fluff34567 is offline   Reply With Quote
Old 02-04-2012, 08:44 AM   #9
Johnf3
Oddometer: 1,046
It should be oiled for off road use, right? Never seen a dry off road foam filter for a motorcycle.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is online now   Reply With Quote
Old 02-04-2012, 10:39 AM   #10
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
Yes, it should. I wondered if anyone would catch that. Only put it on for the pics right then. I took my Throttlebodies off first to clean them.
The bottom of the airbox area is sealed all the way up to the front above the radiator. The stock splash guards are removed and all wiring tied up out of the way. I recommend that on any Adventure. The heat soak from the engine is rediculous. On a 65 degree ambient temp day I could easily record 160+ temps in the stock airbox. With everything sealed they stay within 6-8 degrees above ambient. Even though I ride at high airspeeds, the NACA ducts would just be a way of bringing in more air and look better than a big hole somewhere. Before I go cutting anything up I will do some dyno pulls with the glove box off to make sure the gains would be worth the effort.
Old 02-04-2012, 11:44 AM   #11
Dusty
Dusty's Avatar
Oddometer: 1,269
Nice filter setup..
I was going to ask about that, so thanks. Got mine apart now picking the rocks out of the radiator and was looking at those thinking more cooler air...hmm, so i am going to ditch the guards also.
I also tried a after market serviceable air filter and noticed dust on the insides of my TBs and around the perimeter of the filter on the hard gasket that is supposed to seal. Called for a refund after only a few rides, not what i want for a bike that is in the dirt.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 02-04-2012, 06:13 PM   #12
Johnf3
Oddometer: 1,046
If they had a fitment for a 950, I would be havin' one of those.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 02-04-2012, 09:19 PM   #13
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
Probably the same thing. Both bikes use the same rubber sleeve in the airbox so the carbs and throttlebodies must have the same O.D. Call them and see. Maybe you could be the first fitment.
Old 02-04-2012, 09:24 PM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
990 and 950 are 2 differant sizes and setups.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 02-04-2012, 09:40 PM   #15
tahoeacr OP
tahoeacr's Avatar
Oddometer: 2,210
Are the carbs at a different offset than TB's? Do you know then if the SE is the same as the 950 Adv?
BTW, got a couple of pics of you on the Rubicon I need to post somewhere.
Times are GMT -7.   It's 05:29 PM.
