Old 04-15-2012, 04:47 PM   #136
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by Balsta View Post
I figured out that my CV's actually were shit carbs about 4,5 years and 75000 kms from new. Running the motor with airbox removed evidenced one slide opened much faster than the other. Replaced the slower one by a new and hoppla! the new opened much faster than the remaining best of the two old. Then replaced the second old slide and what do you think occured? Yes Yes Yes!! Both sharp equal and really fast. Conclusion: The rubber diagrams stiffens with time and the slides need to be replaced to avoid poor responding CV's. They are neither any reinvestment of significance.
Yea but, why not spend $1200 instead and blame the CV carbs
Just say'IN
crankshaft is offline   Reply With Quote
Old 04-15-2012, 11:22 PM   #137
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by ktm950se View Post
Not really.
There's been multiple reports of folks with carb problems eventually tracing the fault to cracked diaphragms...
ktm950se
Flash back to my air head days
And the answer.......... Inject it........... So I did. Talk about overkill !!!!
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 04-15-2012, 11:39 PM   #138
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by Gustavo.Ramos View Post
Interesting in a way the rider may not be aware of the lower performance caused by "tired" diaphragms and assuming everything is alright....
That's right as opposed to one with a hole which is more noticeable.
Old 04-16-2012, 01:43 AM   #139
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by crankshaft View Post
The assumption you're making is that I'm doing the dyno work with some fly by night outfit that does pulls for peak HP for bragging rights. Is that what I'm gathering? I do plan on riding the bike in an 1100 mile desert race at the end of this month, so fuel economy is important. I'm also interested in reliability, which means proper fueling is important. I guess I'm interested in something between full rich and full on lean right? I can leave the T-couple sensors on the bike and data log the temps during the race also. I was meaning to do that anyway.
I also own one of these.......
No that's not what I meant. Dynos and there operators serve a very useful purpose, and I would think that it is the relationship between you and the operator that gets the results. I cannot understand why anyone would spend a fortune on a piece of equipment to produce rubbish results, and suspect bad comments about operators are probably not justified. In this world it is best to learn from experience rather from some intolerable AH's comments.
Anyhow ......load is an essential part of tuning. A dyno can not replicate that load 100% .......So you should follow your dyno tune with some road time using that Innovate LM2 of yours. Do you have a Bosch 6066 sensor as in the photo? They are very good.
If I was you I would confirm the temperature on the road, get all that stuff out of the way before you race. You will have enough to think about while there.
If you are doing 20mph, and the air around your carbes is close to ambient that's all you need to know........ that you have a supply of fresh air to your carbes. I'm sure that I can speak for everybody in that we would all like to see the results as it will become an important part of our knowledge base.
Originally Posted by K2m View Post
If you fit FCR's you can "Trumpet" to the air box connection. Experiment with the runner length. HOW COOL WILL THAT LOOK AND HP TO BE FOUND .
This is Dyno teritory. Experimenting with runner lenght and getting results
K2m screwed with this post 04-16-2012 at 01:53 AM
Old 04-16-2012, 12:24 PM   #140
Balsta
Oddometer: 400
Not really.
ktm950se
Well, my slow diaphragms were not cracked. They were obviously just stiff, very stiff.
Anyone who knows about what specific material the diaphragm is? EPDM? Nitrile?
http://en.wikipedia.org/wiki/EPDM_rubber
http://en.wikipedia.org/wiki/Nitrile_rubber
If so can someone google it and findout about deteriation of elasticity over time?
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta screwed with this post 04-16-2012 at 01:57 PM
Balsta is offline   Reply With Quote
Old 04-17-2012, 08:31 AM   #141
crankshaft
crankshaft's Avatar
Oddometer: 14,005
The dyno testing went well this morning the fueling with the insert in the exhaust was perfect. With the insert out, it was really, really lean.
I had a knob mounted on the back wheel, so the high end of the dyno HP numbers are off from the bike hopping around a bit. At this point, I'm only concerned with fueling and it's spot on and when I get back, I'll do another pull with a street tire for peak horsepower numbers. The dyno folks saved my runs from a few years ago, so I can use that as a baseline. My best guess for HP is 90. It pulls really hard
Just say'IN
Old 04-17-2012, 08:50 AM   #142
ktm950se
ktm950se's Avatar
Oddometer: 1,385
And the final jetting spec is???
ktm950se
ktm950se is offline   Reply With Quote
Old 04-17-2012, 09:50 AM   #143
crankshaft
crankshaft's Avatar
Oddometer: 14,005
ktm950se
More testing is in order. When I get back from MX, I'll know more.
Just say'IN
Old 04-17-2012, 03:50 PM   #144
emuooz
Emu
emuooz's Avatar
Oddometer: 433
If he tells you he'll have to kill you
It's NOT a race I just want to get there First
Full Member......Quorn Schnitzel Club
http://share.findmespot.com/shared/f...mUP17SaZA5QYc5
emuooz is offline   Reply With Quote
Old 04-17-2012, 04:25 PM   #145
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Actually, if I gave out the jetting specs, someone would have melted a motor.
I'm sure you would all be crying then 16-17-18 AFR with my starting set up, the dyno guy shut it down real quick. Now I need to ride it with the WB set up and get some real world data.
Just say'IN
Old 04-17-2012, 04:27 PM   #146
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,883
Ok simple question...can I install the CPR filter setup without the proper map? I just completed a valve adjust and it all seems so easy to install at this point.....will the ECU compensate for additional air flow....will I lean it out and do damage...
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 04-17-2012, 04:33 PM   #147
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,192
What you said...
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 04-17-2012, 05:22 PM   #148
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I'm warning you guys you are moving in dangerous territory here. The inserts should not give this result. Readings like this from the rear are unreliable. Dyno results are not accurate. This is a racing motor like a WRC car. A wideband should be mounted properly for such a radical departure from normal.
Wait until Ken (H2W) comes up with a jetting package. He is a professional and will do it properly, and he has the right equipment and knows how to use it. Just be patient. Under normal conditions the exhaust changes on this bike do not affect the tuning (CV carbes).
Old 04-17-2012, 07:31 PM   #149
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Totally disagree with you, the exhaust makes a huge difference. If the engine is an air pump (basically) and running a pre-filter requires a jetting change, why wouldn't an exhaust? Air in (filter) air out (exhaust). Thankfully, I have a low mileage 950 motor sitting in my shop if things go boom
By the way, what oil do you like
Just say'IN
Old 04-17-2012, 07:55 PM   #150
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,590
So far we are learning and moving forward with testing. Initial "best guess" was a smidge on the lean side of life, which could spell danger if pushed hard over a long period of time. Crankshaft has come back with details on his seat of pants, and then O2/dyno information to basically confirm that we need to put a bit more fuel to it, which should get it into a preferred AFR and optimal power delivery. The MX1000 will have two 950 SE running the CPR filter and jetting to support it. One of the bikes will have some system monitoring and logging so we can keep an eye on things. It is proving interesting that a seemingly subtle change of muffler insert or no insert (at least with this bike/exhaust system) resulted in a perceived significant change in AFR on the dyno. This was also "backed up" (?) prior to the wheel dyno by the butt dyno.
Lots of variables, which means we need to knock them down one at a time, but we are running out of time prior to the race.... , typical right?.... nothing quite like pulling a 37hr change/build right before leaving (did that once with the super truck, that was NO fun).. I exaggerate for this situation, but lots of changes getting ironed out in short order for sure.
For those who are asking for spec's, please understand that until the development testing has been completed it is just not wise to suggest anything. I know that I have absolutely no interest in melting down a engine.
I figure that a full 1-2 days of dyno and butt tuning, then real world testing/riding with telemetry will ultimately provide a excellent running LC8 with the CPR filter..... we need time to make that happen. I am sure that another skilled tuner and dyno operator would be able to do this as well, so if you would like to share your findings afterwards, I am sure we would all encourage you to do so.
It comes down to this; progress is being made with the two race bikes and I have hopes of getting the 950 ADV into the mix here soon so we can ensure the changes necessary are similar. We just received a box full of 950 and 990 filter assemblies so we are finally able to begin developing.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 07:03 AM.
