Old 05-16-2012, 09:34 PM   #31
villageidiot
Oddometer: 1,620
this thread is delightful, out of the box, and vintage and modern all rolled into one.
villageidiot is offline   Reply With Quote
Old 05-16-2012, 10:26 PM   #32
Boxer Metal OP
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
A good friend of mine gave me a /2 rear fender that looked like it was run over by a truck a few times so I straightened it out and I now have a rear fender.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 05-17-2012, 10:37 PM   #33
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
Machined up the end pieces for the sidecar upper mounts.
.. and bent up some old school beach cruiser style handle bars out of 7/8" tubing with 22mm ends so the BMW throttle will work without any problems.
Made them a little long so I have the option of cutting them down.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-19-2012, 10:52 AM   #34
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
Front disc spacer machined and installed.
Modified the /2 ball mount to fit the later style frame.
Lots of welding done.
Front wheel spacer made and wheel centered.
Front caliper template ready to be traced and plasma cut out.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-19-2012, 06:16 PM   #35
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
Front brake foot pedal and master cylinder are all figured out and tacked together. The floor board moves up and the brake still works. Now it's time to figure out where to route the rear brake cable.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-19-2012, 10:56 PM   #36
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
Front brakes are done and work fantastic. Time to finish welding, grinding........ and figure out what I want the floor boards to look like
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-20-2012, 01:22 AM   #37
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
The left floor board and clutch pedal are tacked together.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-20-2012, 02:46 AM   #38
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
Floor boards are done.
Time for bed.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-20-2012, 03:12 PM   #39
villageidiot
Oddometer: 1,620
what about running a proportioning valve and linking the front and rear brakes together?
looks good chris, thanks for giving us something interesting to read.
Old 06-12-2012, 11:10 PM   #40
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
The rear brake is a cable actuated drum that will be linked to the front brake pedal.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-12-2012, 11:14 PM   #41
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
320mm floating disc and a BMW 4 piston caliper = LOVE.
13mm master cylinder from the rear of an R1150Rt works great for the front brake. Working on sidecar mounts.
I'm looking for a small vintage screw cap bottle for the brake reservoir.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-12-2012, 11:50 PM   #42
villageidiot
Oddometer: 1,620
Mercedes (gasp) 190sl has a nice metal resevoir, though its probably 3x the size of the one pictured, holds about 5 ounces give or take.
Could make somethin neat, but then it wouldn't be vintage, but with. Couple brass freeze plugs (top and bottom) and some brass tubing, a lid outta something, and a fitting for the bottom, you could have a neat piece.
Old 06-13-2012, 03:34 AM   #43
Sanders
Stogiesuckingsinglemalter
Sanders's Avatar
Location: Confluence of the Mississippi and the St. Croix
Oddometer: 665
subscribed! Envious of your mad skillz.
Last edited by Temporal Security Agency: 8-25-2026 at 10:31 AM. Reason: Deleted unlawful reference to future history
Sanders is offline   Reply With Quote
Old 06-13-2012, 09:58 PM   #44
Boxer Metal OP
Mad Scientist
Oddometer: 3,462
The sidecar is leveled out and the bike is in position and measured out with a 1/2" of tow in.
...and temporary upper struts are tacked in place so I can build mounting points and the upper struts. At this point if the sidecar wheel was finished I could roll it around the shop and it would all be in alignment.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-14-2012, 01:18 AM   #45
pops
Oddometer: 1,567
Subscribed. Nice work
pops is offline   Reply With Quote
Times are GMT -7.   It's 04:54 AM.
