Old 01-13-2013, 10:41 PM   #46
lamebrain
Oddometer: 38
Here it is with the front end on for good. The swingarm is on temporarily while I figure out where I'm going to route the shocks remote reservoir and hose.[/QUOTE]
Here is how i routed mine
It's pretty much in the same spot as the XR, but there is no tab for the clamp. I just used a hose clamp to secure it to the frame. The carbs and boots are off in the pic, but there aren't any clearance issues. hope the pic helps you, glad to see you're making progress!
lamebrain is offline   Reply With Quote
Old 01-14-2013, 05:54 AM   #47
brucifer OP
brucifer's Avatar
Oddometer: 2,483
Originally Posted by Rot Box View Post
Really cool buildup. Looking forward to updates
Hey Andrew, how ya doin'?
It's pretty much in the same spot as the XR, but there is no tab for the clamp. I just used a hose clamp to secure it to the frame. The carbs and boots are off in the pic, but there aren't any clearance issues. hope the pic helps you, glad to see you're making progress![/QUOTE]
I'm probably going to mount mine on the left rear frame rail ala Yamaha TT600. I'll have to build a longer hose and mount bracket but it should be a factory looking set up (at least I'm hoping ).
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-14-2013, 06:05 AM   #48
davek181
davek181's Avatar
Oddometer: 917
I used the same shock on my XL and mounted it in the same place. My variation is that I just used one larger hose clamp around the shock body and frame both. It stays put very well and has been mounted that way for years.
I did respring it finally years ago and that made a tremendous difference.
davek181 is online now   Reply With Quote
Old 01-17-2013, 07:11 AM   #49
brucifer OP
brucifer's Avatar
Oddometer: 2,483
Here's the simple but effective bracket I came up with to mount the reservoir.
Please ignore my craptacular tack welds. I'm taking it to work to get it welded right.
The bolt holes are offset because of where it mounts. You'll see later on.
Old 01-17-2013, 07:32 AM   #50
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 241
I think this is the air filter box?
Ivanych is offline   Reply With Quote
Old 01-17-2013, 06:02 PM   #51
brucifer OP
brucifer's Avatar
Oddometer: 2,483
No, nothing to do with the airbox.
Here it is properly welded with a couple coats of Dupli Color semi-gloss black.
Old 01-17-2013, 08:41 PM   #52
lamebrain
Oddometer: 38
[/QUOTE]
Nice!
Old 01-18-2013, 06:34 AM   #53
brucifer OP
brucifer's Avatar
Oddometer: 2,483
On the bike. Sorry for the blurry first pic.
Old 01-18-2013, 07:55 AM   #54
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Sweet Bruce,great job so far..little slow on updates though....so pick it up a little will ya
Cut your collection down to under 20 bikes and maybe you`d have more time
B
techforlife is offline   Reply With Quote
Old 01-18-2013, 01:14 PM   #55
brucifer OP
brucifer's Avatar
Oddometer: 2,483
Lamebrain, thanks.
Brian- LOL. I've actually been thinking of trimming down somewhat but can't decide which ones to turn loose of. They all have a purpose.
Old 01-18-2013, 07:54 PM   #56
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Naw, keep em all if you can says I
So, what is the tool of choice to get the valve cover off the bottom of the external reservoir? My spare shock needs servicing from my parts XR5 and it still has the stock, domed cover press fitted on the end. I've tried to remove it once before, but didn't want to further risk injuring myself with the tool I was using in my lame attempts to pry it off
Ghost_Mutant is offline   Reply With Quote
Old 01-19-2013, 07:50 AM   #57
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 241
It looks great!!
I was wrong, but my frame does not have the bracket.
Old 01-19-2013, 04:57 PM   #58
brucifer OP
brucifer's Avatar
Oddometer: 2,483
I honestly don't know how that end cap comes off. Is there maybe a snap ring in there or something?
It looks great!!
Thanks Ivan.
Old 01-19-2013, 05:01 PM   #59
brucifer OP
brucifer's Avatar
Oddometer: 2,483
Anybody have an extra set of grommets and the steel collars that go in the frame to mount the top of the rear fender? I need a set and they're NLA from Honda.
I'd be happy to buy them from you if you have any you'd care to turn loose of.
Old 01-19-2013, 05:09 PM   #60
mcma111
mcma111's Avatar
Oddometer: 12,404
Bruce,
Post up a parts fich picture and I'll see if I have them or something clos.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 12:24 PM.
