Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 02-05-2012, 08:22 AM   #1
Tudelum48 OP
Oddometer: 332
Full Size Pull behind RV thread
Well im looking at retiring soon and think I have a need for a Travel Trailer. Tow vehicle will be a 2009 Chevy 1/2 ton extended 4x4. Looks like tow specs for a 373 gear put me in the sub 7500 lb range. I dont even want to get close to that so Im looking at 23-24 foot max on length and would like to have a slide and stay below 5000 lbs.
I went to a dealer yesterday and to say the least im more confused than ever. There are so many models,makes and styles my poor mind went into overload.
Heres how I plan to use it:
1. Probably just the wife and I mostly with the occasional grand kids.
2. Will do some hook up camping at the normal lake camp sites that have electric and water.
3. Primitive camping in the LBL in KY. I'll be using a generator for charging camper and boat.
4. Might get brave enough to drag it to Florida to check into the snowbird environment to see if we like it.
5. Probably be a handme down unit to the kids.
6. Got to keep it short for primitive sites.
7. Dont want one with cloth extensions.
Normally when I buy something I keep it a long time, so im looking for one that has a chance to last several years.
With the chance of this turning into a Tire Thread argument. What are the brands I need to check out? I have already looked at the Coachman lines and would really like the looks of the Forest River. I have never owned a Travel Trailer so i'm in uncharted water. Any direction would be appreciated.
Tudelum48 is offline   Reply With Quote
Old 02-05-2012, 08:50 AM   #2
Hardware02
Hardware02's Avatar
Oddometer: 3,412
We RV shopped ~3 years ago so I know what you're saying about being overwhelmed.
Let me add to your quandary.
Have you considered getting a toy hauler - do you want to bring a motorcycle or two along on the trips?
Are you looking at a receiver hitch or fifth wheel? 5th wheels haul better but you loose bed space. There's also the option of loading a bike in the pick up if towing with a receiver hitch. Loading/unloading won't be as quick and convenient as with a toy hauler however.
There are so many brands and models it's mind boggling. I would just ask the inmates if there's any specific ones to stay away from (and why)?
"These instructions are at our present level of
knowledge. Legal requirements do not exist.
Technical issues subject to change."
Hardware02 is offline   Reply With Quote
Old 02-05-2012, 08:53 AM   #3
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,639
Life long RV'r here, I'll start off by mentioning Jayco.
good luck
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 02-05-2012, 09:18 AM   #4
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,993
Oil threads will have fewer opinions. I've spent a little time looking around here in the past. You may find it to be a decent start for researching owner opinions and experiences.
My research has led me to believe that you will probably be able to find something decent to pull with your truck, but for long term durability (read: built very well), many of the trailers will be quite heavy for that truck. I have always loved the Airstreams, but that is big money and big weight. Sunnybrook have some nicely made models as well.
Get into as many models as possible, preferably hitting a show, and check out how what you can see is put together. If the cabinets and walls are wafer thin, I would expect that theme to carry throughout the beast.
Just my opinion, as usual.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 02-05-2012, 09:22 AM   #5
Motor31
Motor31's Avatar
Oddometer: 1,953
Welcome to the world of RVing. It is confusing at first but then so is any other kind of lifestyle change until you learn whart it's like.
Hardware has some good questions for you to ponder and how you decide that will eliminate a significant portion of the units out there.
If you go with a 5th wheel you will have a significant portion of the weight on the truck, figure about 15% to 20%. Make sure you are not overloading the axle / tire capacity by doing so.
If you go with a "bumper pull" or travel trailer you still have a hitch weight to consider and since it is on the very back of the truck will jack up the front end. That lowers the weight on the steering axle, kicks your headlights way up and screws with the handling unless you get a weight distributing hitch. I'd also look at a sway control hitch as well as trailer sway is not fun o the road. (some of those hitches combine the functions)
You list a half ton PU. You are already ahead of the curve in that you know you are pretty limited in what weight you can tow. Frankly speaking a half ton PU is not much to tow an RV with. Do not forget everything you put in the truck including passengers and payload reduces the towing capacity the same amount. If you have an automatic transmission make sure there is an oil cooler for it and one for the engine is not a bad idea either.
I have had experience with Nash units. Also in the same family is Arctic Fox and Desert Fox. They build both 5th wheel and tracvel trailer style units in various lengths. I can say that they build a hell of a unit, light in weight and long on quality, far far above a jayco product. To me, jayco is at the bottom of the barrel.
Here is an outstanding source of information for all kinds of RVing. If there is a question about the subject those folks do not know, there probably isn't an answer. This link takes you to the escapees RV club forum.
http://www.rvnetwork.com/index.php?
It costs nothing to register for the forum but you can read the threads without registering if you want.
Wherever we go, there we are.
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
Author Unknown
Motor31 is offline   Reply With Quote
Old 02-05-2012, 09:31 AM   #6
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 13,397
Don't ignore aerodynamic drag with your tow vehicle - some of those 5th wheels now have 6'-6" headroom in the front bedroom - damn things look like a tractor trailer at 13'-6" tall! Imgaine the extra drag.
The good news is that you should find some excellent deals either new or used, the RV market is terribly depressed right now.
If you are really going to full-time it, I have to say I'd consider a bigger tow vehicle and a larger trailer, unless you and the wife are really used to close quarters for extended periods.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 02-05-2012, 12:03 PM   #7
Bubwheat
Oddometer: 1,593
+1 I just bought a 2012 Arctic Fox 22H, after doing tons of research. My TV is a 2008 Tundra with just about the same limits as your 1/2 ton. Weight of the 22H is about 4700# with a hitch weight of 595#. The 22H is a 4 season TT, with excellent insulation and cold weather features (holding tanks heated by air ducts from central heater). The H model has a full coach, an almost queen size bed and with the dinette, sleeps 6. Really happy with it! Note: I also discounted a toy hauler, hitch weights were at or exceeded limits for my truck and they just don't have the comfort and amenities/comfort of a TT that was more important for me.
Bubwheat is offline   Reply With Quote
Old 02-05-2012, 12:14 PM   #8
dfwscotty
dfwscotty's Avatar
Oddometer: 3,380
www.rv.net
Enjoy the next few days researching.
Traffick911
1999 BMW 1100GS
2012 Kawasaki Concours
dfwscotty is offline   Reply With Quote
Old 02-05-2012, 12:48 PM   #9
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,679
I will echo what O'Kely said about tow vehicles, you can't have too much truck. I wouldn't tow much more than a Casita type TT with a half ton truck.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 02-05-2012, 01:19 PM   #10
rider1150gsadv
Fl Keys Fishing Guide
rider1150gsadv's Avatar
Oddometer: 5,914
http://www.earthbound-rv.com/ for starters...
rider1150gsadv is offline   Reply With Quote
Old 02-05-2012, 02:36 PM   #11
Tudelum48 OP
Oddometer: 332
Should have added it to the original post but I really dont want a fifth wheel. I know that a fifth wheel is the prefered towing method. I figure to start out with what I have 1/2 ton 4x4. I plan for the Travel Trailer to be a every now and then type of thing so im planning small. I have a building with 10'x14 door way so would preffer one under 10' tall to store inside. Use my truck to pull a bass boat and haul bikes. The 1/2 ton does it fine.
Been looking at a Forest River Surveyor, anyone got one?
Old 02-05-2012, 03:34 PM   #12
PaddedHat
Oddometer: 732
I would have to disagree with this, based on a hell of a lot of personal experience. In the last dozen years I have had four 1/2 ton Chevys and towed extensively with each, often over 20K miles per year. I currently tow a 26' old style, sticks and tin travel trailer that runs about three tons, loaded. The tow rig is a 2003 Tahoe with a 5.3 and 3.73 rears. In well over 100k miles with various trailers behind GM half tons I have had ZERO towing related issues. It's not 1975 anymore. Half ton trucks today have performance and towing specs. that blow the doors off 3/4 T trucks from "back in the day". The OP would do well to spend time on rv.net with particular attention paid to the towing tutorials and searching various manufacturers. Unfortunately, so far this thread has a lot of "opinions" that could easily be misconstrued as facts. Comments like half tons only being suitable for fiberglass egg trailers, or "Jayco is bottom of the barrel" really make it clear that this is a bike forum, and that credible RV knowledge is best found elsewhere. A good start in the search for a quality trailer would include Jayco, K-Z, and Nash products.
PaddedHat is offline   Reply With Quote
Old 02-05-2012, 04:04 PM   #13
tommu56
tommu56's Avatar
Oddometer: 1,386
What ever you look at try the bathroom on for size and
I'm not kidding!!!!
We bough a hybrid because we wanted a bathroom and reasonable kitchen the fold out sides weren't an issue to us.
We found a used one liked the lay out and has a screen room for the awning lots of extra stuff from the PO bough it.
The first weekend we used it went in to the bath room for some buisness dropped my pants went then found I wasn't a contortionist to get the TP and I couldn't bend over to pick my pants off the floor (sink is in the way)
tommu56 is offline   Reply With Quote
Old 02-05-2012, 05:27 PM   #14
Tudelum48 OP
Oddometer: 332
I'm not kidding!!!!
Well they do advertise RVing as an Adventure.
What about the towbars/antisway bars. How expensive are they?
Brake controller,I hooked up some in the old days. Do they have better ways to connect now?
Old 02-05-2012, 06:18 PM   #15
KeithinSC
KeithinSC's Avatar
Oddometer: 1,587
Summit has Curt brand weight distribution hitch $290 and sway control $60, you'll need a ball too, $10
http://www.summitracing.com/parts/CHT-17302/?rtype=10
http://www.summitracing.com/parts/CHT-17200/
Brake controller. I bought a Tekonsha Prodigy $100. Easy to hook up, but my GMC had a wire harness pigtail installed already from the factory. part of the towing package. About 5 wires, easy if you have a little electrical skills.
Ebay and craigslist also,just watch the shipping$$$$
KeithinSC is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:48 AM.
