Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 05-05-2013, 11:17 AM   #166
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,500
Originally Posted by MANXMAN View Post
Finding a Toyhauler that can be towed by a Tacoma, fit a big GS Adventure in it and finished inside like a regular travel trailer was a challenge. Decided on this one. It tows great behind the Tacoma.
Bike fits easily inside.
With the bike out. Built a removable table to match the cherry wood cabinets and got a couple of comfy leather chairs for it.
Regular RV trailer amenities including a 3 piece bathroom, entertainment system, queen bed and large fridge.
Going to be spending many weeks traveling and riding out of it. After my wife and I spent so many years camping off the bike, this thing is like a suite at a luxury hotel.
That is a really nice size unit. I wanted to look at that particular model at the Hershey PA show last fall but they "ran out of room" so they didn't bring it with them. :-( I like the queen bed in the front. A lot of haulers that small have some sort of fold out or drop down bed so you can't just stop and sleep while traveling.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 05-05-2013, 07:26 PM   #167
wesplains
Nothing normal please.
wesplains's Avatar
Oddometer: 251
What I meant was a Toy Hauler with its own motor powerful enough to haul two mc in the garage part and pull a Jeep behind it.
Otherwise I would need to sell the jeep and buy a truck to pull one.
I was here.
wesplains is offline   Reply With Quote
Old 05-06-2013, 08:49 AM   #168
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 702
Pulled this 17' hybrid home last week. It has a soft floor that I need to look into but the price was right....FREE!
IBA #33260
cablebandit is offline   Reply With Quote
Old 05-06-2013, 06:34 PM   #169
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: California bound but stuck in NY for a few months
Oddometer: 3,511
How in the hell did you pull that off?
Wanna double your money?
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 05-07-2013, 12:01 PM   #170
cablebandit
Web Adventurer
Oddometer: 702
Its got a soft floor I need to replace. Shouldn't be an expensive repair, but pretty time consuming.
IBA #33260
Old 05-07-2013, 04:45 PM   #171
MANXMAN
Overlander
MANXMAN's Avatar
Oddometer: 1,550
With the restrictions placed on us by a small truck and a big bike, and wanting it to be comfortable for many weeks on the road, this was the only toy hauler that fit the bill. We were pretty lucky that KZ even made something like this when no one else was.
The quality has been good so far with the only problem being a failed C/O detector that has nothing to do with KZ.
One thing to watch out for though is if you like to dry camp like we do, the fresh water tank can't be filled without using the water pump. No gravity fill. It appears that KZ and other manufacturers are deleting this option. Makes no sense at all to have to run a pump for so long at a campground to fill the tank while not plugged in. Sure takes a lot out of the battery and forces you to charge the battery with a generator more often.
MANXMAN is offline   Reply With Quote
Old 05-07-2013, 06:21 PM   #172
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,257
Are you sure you need to run the pump?
I have a new KZ camper and it does not have a direct fill port like my old pop up did either.
However it doesn't need the pump running to fill the tank.
I have a valve near the pump that you simply open and the water pressure from the source pushes it to the tank.
Ogre_fl is offline   Reply With Quote
Old 05-07-2013, 06:59 PM   #173
tommu56
tommu56's Avatar
Oddometer: 1,359
I got mine with a soft floor too make sure you don't have a roof leak.
The floor is.
lauan ply
foam
plastic sheet material
All laminated with white glue.
add water glue lets go
I fixed the roof.
Cut vinyl flooring out at the walls / cabinets
Cut small holes 3/8" in lauan were it delaminated from foam and put liquid nails in holes to re bond it.
Got some glued down bamboo flooring at a big box store and installed it over ply.
The laminated wood helped span the softer area.
Added trim to bathroom (original floor ok there).
Its been fine for 4 years
tom
tommu56 is offline   Reply With Quote
Old 05-19-2013, 03:12 PM   #174
MANXMAN
Overlander
MANXMAN's Avatar
Oddometer: 1,550
You are correct, I didn't word it right.
I should have said that when you are in your "dry campsite" and you want to add water to your freash water tank after a few days of usage, you can't just pour it in from a jug through a gravity feed port. You have to run the pump and syphon from a water jug you filled at the campgrounds water tap so you are using up battery power to run the pump. You can hook up the trailer again and take it to the water supply, but that is a pain to do once you are all set up and leveled.
The old way of just poring in the water from your water jug through a gravity fill is a better way for those who prefer Provincial or State park campgrounds that usually don't have water at each site.
Old 09-07-2013, 08:38 PM   #175
Hodag
native
Oddometer: 22,993
Originally Posted by dirtydeeds View Post
Is there a "normal, not so little camper thread"?
I'm thinking of picking one up. About 18-20ft or so. Don't want to muddle this one up.
that's ok here...
24' I think should be the max...
because that's the size I want
Hodag is offline   Reply With Quote
Old 09-08-2013, 07:37 PM   #176
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
Originally Posted by Hodag View Post
that's ok here...
I'm not set on a size yet. I just don't want to tow a big one into the mountains. Especially in the winter.
Let's start with my first inquiry:
Which brand is known for having the highest head room?
dirtydeeds is offline   Reply With Quote
Old 09-08-2013, 07:53 PM   #177
Big Bird 928
Oddometer: 2,529
Oh, good question! I need to know this, along with one that has a tall shower so I can actually take a shower! I am 6'8" tall, very important to me.
Originally Posted by Smithy View Post
Didn't take me long to sort out the derpapotomous tactic again.
Big Bird 928 is offline   Reply With Quote
Old 09-08-2013, 08:25 PM   #178
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
I'm a petite 6'5".
Being tall is a blessing most of the time. Other times times you can tell that the world was made for small people. Cars and bikes, airplanes, busses, dinner tables, home appliances, the list goes on. Hell, most toilets are like a kids podi. (sp?)
The good part, I can say:
"No, a KTM990 ADV R is not a tall bike."
dirtydeeds screwed with this post 09-08-2013 at 08:31 PM
Old 09-08-2013, 09:15 PM   #179
Hodag
native
Oddometer: 22,993
I have camped all my life and never showered in a camper
Old 09-09-2013, 11:12 AM   #180
DriveShaft
Oddometer: 4,411
Who's going to the RV show in Hershey PA this weekend?
DriveShaft is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:17 PM.
