Thread Tools | Search this Thread | Rate Thread | Display Modes |
03-04-2012, 04:56 PM
#31 |
Oddometer: 184
Garmin replied to me with an email suggesting I submit the request for selective pairing to their techies. Here's the link:
http://www.garmin.com/ideas -dan
2009 BMW F800 ST Never let your motorcycle take you where your brain hasn't been five seconds earlier. |
04-03-2012, 08:36 AM
#32 |
Oddometer: 494
Following up: Sena finally released v4.0 of their firmware for the SMH10 today. Per the instructions it is now possible to do exactly what I'd outlined in my first post.
1) Voice control of my iPhone (including Siri, voice dialing, controlling playlist, etc.) 2) Calls to/from my iPhone 3) Music from my iPhone (both iTunes as well as Pandora) 4) Zumo interrupts with nav guidance I opted to go with a Zumo 220 instead of the 660/665, so I should have it in a couple of days to confirm that this works as advertised. Note that it is still not possible to have full control of the iPhone (including Siri, voice dialing, controlling playlist, etc.) and full features of the 665, including XM and MP3.
04-13-2012, 04:41 PM
#33 |
Oddometer: 184
After trying iPhone to zumo 660 to SMH10 (with SR10 on the side channeling radar alerts), I found the phone connection was unreliable and sometimes "crashed" the system, requiring a power cycle on the SMH10 to get back to even GPS audio.
Here, per advice of Dan Kim at Sena, is my newest lashup, due to be tested tomorrow on the road (but works fine so far in the driveway): Dan essentially says forget using multipoint pairing with a zumo 660. Here's his recommendation for my setup: * iPhone to SMH10 as a smart phone (meaning both A2DP and HFP) * Valentine 1 and zumo hardwired to SR10 aux ports * SR10 multipoint paired (HFP) to SMH10 I can use voice dialing without touching my phone, answer and make calls, hear GPS directions and radar alerts. The tradeoff is that I see no caller ID of course, and phone audio shuts down both radar and GPS audio (temporarily), but I don't like to yak on the phone while riding anyway, so conversations will be very short. Tomorrow I have a 4- to 5-hour ride planned, so that will be the real test. I'm skeptical about voice dial at speed, but we'll see. -dan
04-13-2012, 09:02 PM
#34 |
Oddometer: 36
Looking forward to hearing your results. I have the same set up (minus the SR10). I talked to Adam at RocketMoto a couple of days ago and he is also doing some trials to see what works. I was thinking of a BT dongle for the V1 but Adam thinks this will conflict with the A2DP from the phone or zumo. Hopefully you will get it figured out
I know others have said it many times but I have to give props to Rocket Moto, just outstanding customer service and continued service after the sale. Doesn't get any better!! |
04-14-2012, 03:31 AM
#35 | |
Oddometer: 184
I think he is correct about the dongle problem. The SR10 is HFP only and so doesn't have this issue. I have already had good luck with the SR10 and the V1. The only really "new" part of the above setup is the zumo being hardwired and the phone paired to the SMH10. The next few hours will tell whether it all works. I'll report back. -dan
04-14-2012, 01:21 PM
#36 |
Oddometer: 184
OK, just back from a nice 220-mile run and all systems worked really well.
The phone stayed paired with the SMH10 the whole way and voice dialing, even at 80 mph in a crosswind, worked fine. The radar detector and zumo 660, both hardwired to the SR10, got along perfectly together and were always connected to the SMH10 except when on a phone call (this is due to the SMH10's priority settings, which in a perfect world would be user-selectable). The SR10 does sometimes clip the first syllable of GPS directions, but this did not cause any problems so far. -dan
04-15-2012, 02:19 PM
#37 | |
Oddometer: 84
04-15-2012, 02:23 PM
#38 | |
Oddometer: 184
For example, I believe you can pair a smartphone (A2DP + HFP) and a zumo 550 (selectively using only HFP) to the SMH10 simultaneously. The zumo 660 unfortunately will not do this; it always uses both A2DP and HFP, so the only remaining opening is for HFP only. -dan
04-15-2012, 08:15 PM
#39 |
Riding is my passion
You are correct, there aren't many BT dongles out there that do HPF only, but I do know of two someone might be able to find if so inclined. One is the Jabra A210 and the other is the Cardo BTA II. I own both of these and they were basically designed to add BT to non BT phones before it became standard. Since they are discontinued, best chance is watching ebay for one to pop up, but they are getting harder and harder to find.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
04-16-2012, 04:06 AM
#40 | |
Oddometer: 184
-dan
04-16-2012, 06:29 AM
#41 |
Oddometer: 494
I had the opportunity to put a couple hundred miles on my setup yesterday, and it appears to be working perfectly:
1) iPhone 4S paired to Sena SMH10 via A2DP + HFP pairing 2) Zumo 220 paired to Sena SMH10 via HFP multipoint pairing This retains complete control of the iPhone (voice control, Siri, music, etc.), and the Zumo interrupts with GPS guidance. One of the reasons I ended up choosing the 220 over the 660 is because the 220 uses only an HFP profile, which ended up making this process a lot simpler.
04-16-2012, 07:37 AM
#42 | |
Oddometer: 84
04-18-2012, 05:06 AM
#43 | |
Oddometer: 36
Also, since the Zumo 660 uses both A2DP and HFP and the iPhone uses A2DP there is no way for me to have both going to my SMH10 unless I get the SR10. To me the music sounds better from the iPhone than from the Zumo. My ultimate goal is to remove the Zumo entirely. I soon as I figure out how to do route planning on the desktop and send it to the iPhone, the Zumo will be gone. |
04-18-2012, 05:17 AM
#44 | |
Oddometer: 184
For music (which I choose not to use, so take this with a grain of salt), it seems to me you'd do best to hardwire the zumo to an SR10, eliminating its somewhat flaky BT from the equation, and pair your iPhone to the SMH10 using both profiles. I tested this at home with music as part of experimenting with voice control and it sounded great, plus you get the advantage of being able to use your whole music collection, not just MP3 formatted songs. -dan
04-18-2012, 07:42 AM
#45 | |
Oddometer: 36
Thanks for all the info. This forum provides a wealth of information. |
