02-13-2012, 07:04 PM
#121 |
jack of all trades...
Oddometer: 6,587
Nah, it's entirely stress. Too much stress on the gear material and poof! How much stress it takes depends on what the gear material is, heat treat, and the size of the gear.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
02-13-2012, 09:56 PM
#122 | |
Oddometer: 1,422
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community |
02-14-2012, 04:24 AM
#123 | |
Loose nut behind h/bars
Oddometer: 4,509
But short-shifting, in and of itself, doesn't hurt anything. Never has, never will. I miss "car94" ![]() ![]() Chris
http://www.theshining.info/ KTM 950 Adv. "S"...'06 KTM 525 EXC... '76 MV Agusta 750 America S...'84 Honda VF1000... '90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E |
02-14-2012, 04:49 AM
#124 |
Oddometer: 795
I knew this would eventually turn into an oil thread
RandyO IBA # 9560 07 VeeStrom 99 SV650 82 XV920R A man with a gun is a citizen A man without a gun is a subject |
02-14-2012, 07:41 AM
#125 |
Oddometer: 707
i short shift all the time in a car so i keep the rpm down and save fuel.
on my 125cc was the only bike i have ever hit the red line / had the engine reving like hell. on alll other bikes i keep the rev no were near the red line.
bmw r100gs i ride it all year round bmw r100/7 sold bmw r1oo/7 sold road legal stomp pitbike sold |
02-14-2012, 02:16 PM
#126 |
Oddometer: 1,422
I reckon I could write a forum plugin that automatically closes any thread with a reply containing the word "oil".
You think baldy would install it? Could make things a lot more civil around here!
02-14-2012, 02:36 PM
#127 | |
Oddometer: 4,509
12-15-2012, 08:52 PM
#128 |
Asperger
Oddometer: 2,048
I read this entire thread and still am not sure...what is short shifting again and do you do it with or without oil in the gearbox?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
12-15-2012, 10:13 PM
#129 |
Oddometer: 19
Driving any vehicle (car or bike) at the rpm at which max torque is achieved provides the best fuel efficiency. Short shifting doesn't save fuel: not starting the engine saves fuel!
12-15-2012, 11:24 PM
#130 |
Oddometer: 246
True. But you should add: Only IF you actually use (nearly) the full torque.
Into the dark side of our nature to look we all need. The energy, the passion there is. Afraid of that people are. Pieces of us it holds busy denying we are. |
12-16-2012, 03:36 AM
#131 | |
Choosing to be here.
Oddometer: 283
Quite simply, a "short-shift" is a shift that takes place sometime prior to what is necessary, usually defined as prior to the peak in engine output. Not sure what oil has to do with anything; any vehicle in which the operator has direct control over the selected gear can technically be "short-shifted."
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.” ― Terry Pratchett |
12-16-2012, 06:41 AM
#132 |
Oddometer: 162
a n.a. gas engine always has best fuel economy at the greatest intake vacuum. period. your qualifier is correct. i'm just expanding on it. i.e. if your motor makes 150 ft.lbs and it takes only 25 to maintain your desired speed,the best fuel mileage is determined by what gear you can keep the throttle plates near closed and still maintain speed.
12-16-2012, 06:50 AM
#133 |
We're burning daylight...
Oddometer: 3,553
Hi my name is Ken and i'm a short shifter. I have been short shifting for decades. I used too only short shift on weekends, with someone else. Now i short shift all the time. Even when I am alone, sometimes early in the morning I'll short shift, just to get the day started.
12-16-2012, 06:55 AM
#134 |
Oddometer: 3,553
Your suspension works better at low RPMs. Next time you are getting beat up on a rough trail, UPSHIFT (aka as shortshifting) 1 or 2 gears and roll the throttle on. Things will smooth out and you can maintain the same speed.
If you short shift and are off an on the throttle, it is possible to damage your transmission. Keep the rear wheel driving. |
12-16-2012, 07:35 AM
#135 | |
Oddometer: 17,983
edit
If you are worried about MPG on a motorcycle you're doing it wrong.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
