Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 02-09-2012, 06:23 PM   #16
mcnut
Oddometer: 1,377
Originally Posted by abhibeckert View Post
Beware sometimes your computer will only show you part of the name, maybe the real name is "blah.gpx.xml" and all it shows is "blah.gpx". Usually you can see the full name in properties, to verify if this is happening.
Ok, that is exactly what is happening, I have to do a "Properties" and then go to the "Details" tab to even see this and then I'm not able to edit it there. Seems like this used to be easer to do, I think MS is trying to protect us from ourselves.
Win 7, Window Explorer, IE9
I'm not using MotionX, just curious how to change an extension you can't see in an editable box.
Bruce
mcnut screwed with this post 02-09-2012 at 06:35 PM
mcnut is offline   Reply With Quote
Old 02-09-2012, 07:15 PM   #17
abhibeckert
abhibeckert's Avatar
Oddometer: 1,724
Looking up microsoft's official documentation, there are two steps. First you need to make extensions visible: http://windows.microsoft.com/en-AU/w...ame-extensions
Then whenever you rename a file, you will be allowed to change the extension. It will prompt you with a "do you really want to do this?" alert, which will help prevent any accidental changes.
Yep! In theory changing a file extension should only be done by programmers like me, and even then rarely. But when something goes wrong (for example, this website that isn't configured properly) you do need to do it.
Technically challenged users changing the extension of a file leads to all kinds of problems.
Still, it is harder than it should be! That's why I use a mac, where a proper UNIX command prompt is a keypress away.
abhibeckert is offline   Reply With Quote
Old 02-09-2012, 10:06 PM   #18
mcnut
Oddometer: 1,377
Thanks, now I'm armed with some dangerous info.
The files from that site seem a little problematic;
Could be opened in MapSource, and after conversion to KMZ, in GE but they were a little weird.
Not a lot lost as the one I did see looked to be autorouted secondary and main dirt roads, not unique as ridden tracks.
Bruce
mcnut screwed with this post 02-10-2012 at 07:16 AM
Old 02-10-2012, 04:43 AM   #19
ducnek OP
Satisfied customer
ducnek's Avatar
Oddometer: 1,015
Bruce
+1
I will make detailed tracks while I am down there and post them here when I get back
Thanks for the help
Calmer than you are.
ducnek is offline   Reply With Quote
Old 02-10-2012, 05:55 AM   #20
WoodButcher
WoodButcher's Avatar
Oddometer: 2,089
Also, It would be a good idea to email whoever made the website and let him know his server is miss-configured (he needs to properly setup the mime type header for those downloads).
He knows. I work with him some. It is an issue with the level of service he is paying for at that hosting company. We've talked about it some already.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 02-10-2012, 03:46 PM   #21
abhibeckert
Oddometer: 1,724
Since the site is running wordpress, I assume he has access to PHP? If that's the case, it's easy to fix the problem. Send me a PM if you want more details.
Old 11-23-2012, 04:53 PM   #22
conkers
Oddometer: 1
Hi..... I just want to say thanks for this thread.... helped me out...
You folks are awesome!
Conk
conkers is offline   Reply With Quote
Times are GMT -7.   It's 03:08 AM.
