02-10-2012, 03:17 PM
#1 |
out4fun
Oddometer: 158
G/S swingarm + driveshaft extension 50mm
I am in the process of upgrading my Front-end of a 1981G/S. The new KTM setup will raise the front by two inches. I might be on the wrong track here and ask those to chime in if indeed I am, but I thought too match that rise in the back as well. Bringing things back in balance. There are three options to my knowledge:
1. a custom shock 2. extending the driveshaft and swingarm 3. or combination of shock and swingarm with driveshaft What I like to accomplish is based on, but might make no sense to some: A. change the ride characteristics of a stock G/S very little, means tight cornering/handling should be the least effected. B. I will not race the bike, so a long wheel base for stability in sand etc. is not necessary. C. easiest maintenance. D. I want the additional clearance = 2", so shortening the forks is not desired. My questions are as follows: Is there an ideal way how to proceed and if there is, please share your thoughts why it is ideal? Is there a non desired/false/wrong way that should be avoided? If you have done a similar conversion, what have you found out (does it work well or not, are your happy)? Does any one have the capability to do a schematic drawing or come up with a formula or might know where one exists, that will explain, what rise I will get in the back with a 50mm extension? I have a Wilbers shock that is currently on the way to the Beemershop/TED and he will look if a shaft extension can be done to extend the shock to reach a measured 38.75cm, measured from eyelid to eyelid of shock. I have found two values that explain the shaft-extension ratio to rise under the motorcycle. 1 to 1:6 or 1 to 2.0, that means, that if the shock is extended 2 cm, I will raise the bike either 3.2 or 4 cm. This shock extension will result in a steeper angle of the shock and require to change the frame cross member above the swingarm, the one that the battery case is mounted too. That can be easily done, by cutting out and re-welding it. No expense for me. It also requires to take some of the inner bell housing off, slight dremel work. I has been done by others and although the angle is steeper for driveshaft, the joints are still fine after 100k. No concern there. Your help is appreciated. Safe riding.
"All animal, except man, know that the ultimate of life is to enjoy it." Samuel Butler cenji screwed with this post 02-10-2012 at 03:25 PM |
02-10-2012, 04:12 PM
#2 | |
airhead or nothing
Oddometer: 7,933
I would think option two would require some re-work of your shock (re-valving and/or re-springing) as the ride characteristics would change due to the increased forces applied by the longer swing arm.
Theoritically, to determine the effect on ground clearance with a 50mm extension you could measure from the center of the final drive to the ground, and then run a straight edge from the center of swing arm pivot point through the center of the final drive and measure 50mm beyond the final drive center the distance from the bottom of the straight edge to the ground. take the difference between the first and second measurements and that would be the increase in ground clearance.
"punkrocks what it's all about" - J. Strummer Quote:
02-10-2012, 04:23 PM
#3 |
OH.THAT'S GONNA HURT
Oddometer: 3,814
Be very careful in lengthening the rear shock as it may result in u-joint problems.
My rear shock (YSS) was adjustable for length and when lengthened there was a noticeable vibration in the drive shaft, so take your chances. I can't tell you how much I lengthened it, but I suspect under 2", probably closer to 1".
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) One Less Harley screwed with this post 02-10-2012 at 04:28 PM |
02-10-2012, 04:29 PM
#4 |
More tacos than you
Oddometer: 5,097
Go look at r-dubb's geometry thread. You could get all the measurements you need and model it in a free CAD program like Sketchup:
More here: http://www.advrider.com/forums/showt...e+trail&page=4
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
02-10-2012, 05:59 PM
#5 |
Tinaversal
Please read the Old's Cool rules when making a new thread.
Thank you. Your mod, Kbasa who just had to move your thread.
IMHO. Fuck Cancer. Ride bikes. - dave + tina |
02-10-2012, 06:13 PM
#6 | |
because I can
Oddometer: 6,056
supershaft screwed with this post 02-10-2012 at 06:18 PM |
02-10-2012, 06:36 PM
#7 | |
More tacos than you
Oddometer: 5,097
02-10-2012, 06:56 PM
#8 | |
out4fun
Oddometer: 158
thanks for the diagram and...
ALL THE OTHER INPUT, VERY APPRECIATED.
BECAUSE I AM LAZY TONIGHT AND HAVE NEVER USED THE FREE CAD PROGRAM, COULDN'T I JUST USE THE NUMBERS PROVIDED IN the DIAGRAM: 100MM EXTENSION IS RAISING THE REAR ROUGHLY 75MM. MEANING THE 50MM EXTENSION WOULD RAISE IT HALF OF 75MM = 37.5MM? That would be close enough. SOLO, WHAT YOU SAID MAKES PLAIN SENSE. I will give that a go tomorrow if I can do it on my own. Finally with have some time to plunk down a whole day on it. Quote:
"All animal, except man, know that the ultimate of life is to enjoy it." Samuel Butler |
02-10-2012, 07:02 PM
#9 |
More tacos than you
Oddometer: 5,097
No. There's a lot more going on there than just lengthening the swingarm. The relative shock length has been increased as well. Notice that the two swingarm configurations shown are not parallel to each other.
02-10-2012, 07:12 PM
#10 |
out4fun
Oddometer: 158
wonderful info...
seems like you have collected some practical and theoretical knowledge that is needed to make this G/S project successful.
Compared to the stock shock, how much would I need to lengthen the stock shock A) with the 50mm extension? B) without the 50mm extension? to match the raise on the front of 2"? Thanks for your feedback and what formula are you using to calculate the missing numbers.
02-10-2012, 07:17 PM
#11 | |
because I can
Oddometer: 6,056
Now I see what the diagram is up to but effective rake and trail all depends on how much sag a setup has. It isn't just about ride height. |
02-10-2012, 07:26 PM
#12 |
More tacos than you
Oddometer: 5,097
Correcto. R-dubb figured in some rough sag numbers in the fork lengths and swingarm angles. I can't remember what exactly, but it's all in that thread in the link.
02-10-2012, 07:43 PM
#13 |
because I can
Oddometer: 6,056
Thanks again for straightening me out on this one AW!
02-10-2012, 07:44 PM
#14 |
More tacos than you
Oddometer: 5,097
I haven't. R-dubb did all this. I don't have access to his CAD file and I don't have my frame around to take measurements from. Sorry. You could always experiment with different lengths of pipe to simulate a longer rear shock with some shims under the front wheel to simulate a longer front end. ...but then a piece of pipe won't give you any sag.
02-10-2012, 07:54 PM
#15 |
Oddometer: 914
Just on a quick break from the shed (from fitting my WP50 front end
)-To address Cenji's question about how much the rear end would be raised from a 50mm swing arm extension- my guesstimate is around 13-14mm- give or take. No way near 37.5mm. I got this by simply looking at the geometry of the bike, particularly the angle of the swing arm- and translating that with a 50mm extension- ie. angle of swing arm to me looks around 20-25 degrees- extend that out by 50mm and it goes up around 13-14mm. This is assuming that rear suspension sag percentage doesn't change. If my 20-25 degree eyeballing of the swing arm is off, then obviously the height would have to be adjusted, but this is just very rough ball park figuring. Does that sound about right, nothing to engineer from, but just an OK guesstimate of increase in height? Back to the shed now, |
