Old 02-11-2012, 07:30 AM   #1
Orangecicle OP
Orangecicle's Avatar
Oddometer: 2,562
Replacing old-style front brake line
I have an original 2005 front brake setup with the brake line that crosses over the low fender. I want to switch that to the modern setup with separate lines that joint together under the triples. Does anyone have the list of parts that works for this conversion? I know I want to avoid the ABS lines, but does one year of standard lines work better than another? I think the mounting bracket that goes under the triples should work fine, but I'm really not sure about the right lines to use.
Orangecicle is offline   Reply With Quote
Old 02-11-2012, 07:33 AM   #2
booger1
booger1's Avatar
Oddometer: 843
check out the HOW for the high fender.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 02-11-2012, 07:43 AM   #3
Orangecicle OP
Oddometer: 2,562
Nope. Not that setup. I'm looking for the setup that creates the brake line loops that stick out of the front of the bike.
Old 02-11-2012, 07:59 AM   #4
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,376
I have 2004 S model and have been contemplating the same mod so I can go from low to high fender when I want. I have the Touratech high fender kit but did not like the brake line routing and large loop at the master.
I looked around in all the posts some time back and never found that parts list. I plan to go through the exploded parts view of a newer S model that uses this setup and simply write down the part numbers and order everything. Given the length of time KTM parts have been delivered I should have this accomplished in a year or so. Ha !
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 02-11-2012, 09:24 AM   #5
Orangecicle OP
Oddometer: 2,562
Let's stay in touch. I'm thinking I'll order 2010 or 2011 parts and try to make it work. I can't wait to get rid of that big brake line loop that sticks right up in line with my gauges. Oh, I've also had pretty good luck with Powersports Warehouse.
Old 02-11-2012, 09:36 AM   #6
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,291
How did you twist your brake line? I've never even noticed mine let alone had it block the instruments
Old 02-11-2012, 10:08 AM   #7
Orangecicle OP
Oddometer: 2,562
Mine doesn't have the loop, so it just sticks up. Came that way.
Orangecicle screwed with this post 02-11-2012 at 01:56 PM
Old 02-11-2012, 10:32 AM   #8
Orangecicle OP
Oddometer: 2,562
I'm going to do this. My biggest issue in trying to figure out what length of front brake line to get -- the standard (non-ABS) or the "R" version. I think I need the "R" height. My June 2004 (i.e., 2005) KTM has always seemed much taller than the newer standards. Have a look at the axles in comparison to the bash plates.
A 2010 "R".
My bike:
I think they look comparable, so I'm going with the "R" length line for my bike. Here are the part numbers that I'm ordering
  • 6011301200033 -- the front line (1)
  • 60101078000 -- the triple bracket (1)
  • 0603100141 -- banjo washers (6)
  • 50213025000 - new banjo bolts. (2)
  • 60101077000 - brake line guide for triples. (1)
  • 60101079000 - another guide (1)
  • 0012060164 - screws to mount the plastic guides (3)
I may not need the banjo bolts, but they aren't expensive. Total costs at PSW looks to be may $110 before shipping. I still need to track down the screws that hold the plastic bracket on the bottom of the triples.
Orangecicle screwed with this post 02-11-2012 at 11:12 AM
Old 02-11-2012, 11:44 AM   #9
Douf
Limey Bitch
Douf's Avatar
Oddometer: 771
I vaugely remember someone mentioned that the 990 tee pipe wasn't really wide enough to clear the high fender without some fit compromise. It seems like the only viable option would be a custom piece (like the one Pyndon made); an excellent opportunity for one of our more industrious inmates...
Douf
Douf is offline   Reply With Quote
Old 02-11-2012, 11:48 AM   #10
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,098
I'm also thinking doing this... 2010R being the model with the bigger travel, I guess I'll go this way
(the S between wheel and triple clamp may be a little bit bigger)
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 02-11-2012, 11:51 AM   #11
Dusty
Dusty's Avatar
Oddometer: 1,287
Douf
A couple plastic spacers will give enough clearance for the high fender.
on the 990 anyways.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 02-11-2012, 11:55 AM   #12
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,098
Douf
Nice!
Old 02-11-2012, 03:36 PM   #13
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,291
A 2010 "R".
My bike:
Your bike is on the centerstand (suspension unloaded).
Old 02-18-2012, 09:15 AM   #14
Orangecicle OP
Oddometer: 2,562
Question
So, I got all of the parts to switch out the front brake line. However, I can't tell from the schematic how I am supposed to mount these two little guides. Does anyone with a 990 have a picture or can you explain to me what I am supposed to do with these two guides?
Old 02-18-2012, 09:22 AM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
These two bolt on the lower side of the upper steering triple clamp.
IIRC correcly, there should be threaded holes ot the lower surface of the upper triple clamp.
Cheers.
Times are GMT -7.   It's 02:01 AM.
