Old 03-22-2012, 04:43 PM   #91
earwig
Crowbar of Embrayage
earwig's Avatar
Oddometer: 4,726
Originally Posted by Euromad View Post
Working on a Triumph 750 in a '72 650 frame. Looking for a scrambler/desert sled look- stripped down, functional. Really like Earwigs creation and the McQueen ISDE bike. Anyone seen the two into one system he has on his bike?
This looks very close.
earwig is offline   Reply With Quote
Old 03-22-2012, 06:17 PM   #92
Euromad
Oddometer: 285
Thank you Earwig, indeed it does look like the ISDE setup-$170 plus shipping. First set I've seen for sale. Waiting on a sludge trap cleaning before the project can move forward.
Euromad is offline   Reply With Quote
Old 03-23-2012, 07:39 AM   #93
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,482
Thumb rtwDougs'
...see what Doug's got? Nice.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 03-25-2012, 08:08 PM   #94
Euromad
Oddometer: 285
Such a beautiful bike. I like the purple/white paint scheme.
Old 03-31-2012, 07:12 AM   #95
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,763
scrambler in process
plugeye is offline   Reply With Quote
Old 03-31-2012, 07:44 AM   #96
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,341
Cool , I want another big bore Yamaha thumper but my old-guy back and knees keeps telling me no.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 03-31-2012, 09:26 AM   #97
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,799
FWIW, I didn't read everything.
Low pipes get flattened unless reinforced or placed between frame tubes. Old time remedy was to get them close together under the engine and weld some angle iron on them to use as a bit of reinforcement and skit plate.
High pipes keep pipes out of danger, but not your leg! Here's my high pipe I made for the SR500, but it can burn a hole in a pair of jeans if the rider isn't careful, as my brother learned.
Made using mandrel bent tubing from JC Whitney (about $27 worth of U bends and a 45 deg bend and about 3 hr of cut, tack, modify, and TIG) It got chromed by mistake, was to be just nickle plated. The pipe looks gunky in the photo due to oil preservative sprayed on it from a long period of storage. The project is afoot now and due for a May finish date. The pipe gets really hot and will burn through clothing. A piece of a Harley pipe shield kit was added, but it's still hot. I hate the look of exhaust wrap and it was never used in the 60s-70s by flat trackers, so I'll just have to keep my leg away from the pipe - although I never did ruin any pants or burn my leg.
If I did a similar pipe again I'd get it ceramic coated, as I did with my KLX650 pipe. Good stuff with minimal care needed. Aesthetic Finishers in Piqua Ohio do good work and turn it around fast. They do coating for Supertrapp and just redid my pipe after the JetHot coating had rust bubbling on the megaphone from what appeared to have been poor cleaning when done ten years ago. I hope AF did a better job, it certainly looks good. The KLX pipe is an old BajaDesigns reverse cone megaphone pipe that is irreplacable unobtainum now.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 04-03-2012, 08:55 AM   #98
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,716
I made a high pipe for my Ducati 450 vintage racer and melted the threads on my boot. I had wrapped the pipe with pipe wrap and that cut the heat some , not enough. So I made a small heat sheild from aluminum and that does the trick. But the problem is it pushes my foot out further.
I need to remake the pipe to tuck in behind the frame tube.
It never ends.
Old 04-04-2012, 04:21 PM   #99
Euromad
Oddometer: 285
Anyone have a closeup of modified footpegs for a Triumph? Trying to come up with a lighter mounting system. Hope to have some pictures soon of the Triumph I'm building-just got the bottom end back.
Old 04-04-2012, 07:59 PM   #100
mikem9 OP
Wanderer
Oddometer: 1,233
Hope to see some updated photos of your project.
mikem9 screwed with this post 04-04-2012 at 08:06 PM
mikem9 is offline   Reply With Quote
Old 04-06-2012, 12:04 PM   #101
oldroadie
Two wheel addict
Oddometer: 468
1972 r75/5
Always a work in progress...
oldroadie is offline   Reply With Quote
Old 04-07-2012, 07:59 PM   #102
DiabloADV
Semi-Occasional
Oddometer: 2,313
OEM single seat...?
Also...what exhaust is that?
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV screwed with this post 04-07-2012 at 08:11 PM
DiabloADV is offline   Reply With Quote
Old 04-08-2012, 04:49 AM   #103
oldroadie
Two wheel addict
Oddometer: 468
No brand names on the seat but it did come from Germany via inmate bmweuro. I'm told the 2-1 pipe is a Luftmeister, I cut off the rotten flared end and installed a Supertrapp disc for easy tuning and the built in spark arrestor.
Old 04-09-2012, 01:27 AM   #104
timolgra1
timolgra1's Avatar
Oddometer: 501
My baby.
timolgra1 is offline   Reply With Quote
Old 04-09-2012, 05:37 AM   #105
Euromad
Oddometer: 285
Beautiful bikes guys! Nice /5! I like the fender choices-used to have a '72 SWB. I'm looking for a muffler for my 2-1. Think Supertrapp may be the way to go for my /6. I bought wider sidecar bars for my project. What bars and tires?
Tasty Triumph- I really like the paint scheme.
Times are GMT -7.   It's 03:30 AM.
