Old 05-04-2012, 11:24 PM   #121
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,842
Just bumped into this ... fantastic ... im looking for a cheap 900 trumpy twin but not found one yet .. will keep looking
thinking of something like these
http://www.ourgreatescapeblog.com/blog.html
keep the pictures coming please guys
White pig
b0mb3r is offline   Reply With Quote
Old 05-05-2012, 09:47 AM   #122
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,628
Originally Posted by Pablo83 View Post
I'm liking this as a street tracker. I remember the Suzuki twin. That is looking seriously good with the pipes. I take it you did the pipes yourself, no one made them for that bike I'm sure. Good job. The wheels would look good stripped to aluminum finish for a more "dirt" look. I've seen guys running the Yamaha front mags on vintage dirt trackers and even a Honda ComStar on a "flat tracked" CRF 450, so the wheels can work for the look. I like the bend of the bars too. What bend are they?
You want authentic tires look up the Duro HF308 (Pirelli MT53 style tread) and/or the Dunlop K70. Both are authentic 60s-mid70s dirt track tires, pre-Goodyear DTs. If you are running 18 front and rear the Duro has a good 4 ply 4.00-18, unfortunately their 19 is a six ply and quite stiff in the sidewall. The Dunlop has the 4.00-18 and a 3.50-19 that work great. I ended up with a Dunlp 3.50-19 and a Duro HF308 4.00-18 front and rear. I went with the Duro to see how it wears compared to the Dunlop I'd run on my SR500.
I just saw a site that showed the Tempter with spoked rims and using a 16 rear. That would make for a nice platfor to make a set of either 19s (but expensive tires) or 18s (for a better buy on tires). Maybe they're the same as the 1977 range GS spoke wheel models.
It would be nice to see more of this build. Any posts in any other threads, forums, or picture sites?
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 05-05-2012, 10:57 PM   #123
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,808
Yes, thanks. I've got about 30 hours into the pipes.
They are 7/8" Tusk T-10 YZ High Bends.
Thanks for the info. I've been thinking a lot about tires, but haven't found something I'm really in love with yet. I'll look up the tires you mention.
Originally I wanted spoked wheels so I could go with 19" rims, but the more I work with the bike, the more I like the mags. I spaced the rear subframe and fender to accommodate a 19" rim in case I ever decide to change that in the future.
See the GR650 link in my sig line. [Or click here]
Pablo83 is online now   Reply With Quote
Old 05-06-2012, 03:43 AM   #124
waynefj40
Oddometer: 3
Originally Posted by Velocipede View Post
Who makes those 2 into 1 pipes Wayne?I'll be starting a rebuild on my T100 soon and I'd like a set just like them.
John
Got them from lowbrow customs. http://www.lowbrowcustoms.com/index...._detail&p=1904
waynefj40 is offline   Reply With Quote
Old 05-06-2012, 09:28 AM   #125
markk53
markk53's Avatar
Oddometer: 8,628
First, thanks for building a REAL street tracker, not some brat bike that has fat ass tires and no suspension travel. My bet is your 650 could actually pull some decent laps on a track if you wanted to do so. That's how I'm building the SR. A flat tracker first and a streetbike second.
I originally wanted to do the Dunlop K180, the DOT legal modern flat track tread tire that was used in the 883 Sportster flat track spec series. Now those are non-existent and were not cheap to buy anyway. I do have another 19" front SR wheel and could to the 19 conversion to the rear, but the actual flat track tires are WAY expensive, not DOT legal (not that it would matter in Ohio), and really should run on a wider rim than the 2.15 on the front of the SR. The alternative would be the Duro HF308 4.00-19, but it is a SIX ply wall and is far too stiff - real popular for the Ural though.
So I looked at the alternatives. Having run short track in the early 70s I knew the tires of the day were the Dunlop K70, the Pirelli MT53, the Carlisle, and eventually the Goodyear DT. Only the K70 is available now and only in the 3.50-19 and 4.00-18. Then there is the Duro HF308 which is a copy of the MT53 tread. Duro shows a 3.50-19, 3.50-18, and a 4.00-18. I couldn't locate a 3.50-19, but the 4.00-18 and 3.50-18 are available. So the only options for the standard set ups for me were Dunlop K70 both ends or the K70 front and Duro rear.
I had run the K70s before in the early 90s, but the new tread compound and the shape of the tire had them square off rather quickly. On the old short tracker I had a Dunlop front and Pirelli rear so I figured "why not". I did the 3.50-19 front (narrower will work better on the street) and the 4.00-18 Duro rear. If I like the wear of the Duro I will consider finding an 18" RD400 front wheel which is a match for the SR cast wheel. Then I could run Duro front and rear or even run a 4.00 front and rear from either brand if I wanted.
As you can see, I spend far too much time thinking about tires. Just can't see putting the wrong era Firestones on it like all the brat guys. Those were 50s tires run on Indians and Harleys. I think the British 500s introduced the Dunlops and Pirellis to flat tracking, but probably am wrong... gotta quit thinking tires...
Mark - klx678
Old 05-06-2012, 10:36 PM   #126
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,808
That was one of the original goals with the bike: flat track racing looks like a lot of fun and I wanted to give it a try so I wanted a functional racer. Unfortunately I later learned there are no operating tracks in my state (Colorado). I might have to take it ice racing instead.
Old 05-07-2012, 08:05 AM   #127
markk53
markk53's Avatar
Oddometer: 8,628
In Ohio here near me they do some ice racing and riding, that was part of my thought process too. Not racing, but play racing. Been on the ice a few times and it's like the perfect flat track, very consistent when not severely rutted. Other than the cold, it's hard to beat.
Mark - klx678
Old 05-07-2012, 09:11 AM   #128
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,465
Have you guys seen the airhead scrambler thread? Some really interesting ideas
http://www.advrider.com/forums/showthread.php?t=678840
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-14-2012, 06:22 PM   #129
gnuse
Ride to Fly
gnuse's Avatar
Oddometer: 275
Sorry, not very custom.
"God does not deduct from one's time on Earth, that which is spent in the air"
gnuse is offline   Reply With Quote
Old 05-15-2012, 08:27 AM   #130
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Thumb
...who cares. TR6C, one of the best. Burned my legs on those pipes pl-enty!
Rapid Dog is offline   Reply With Quote
Old 05-15-2012, 10:03 AM   #131
earwig
Crowbar of Embrayage
earwig's Avatar
Oddometer: 4,726
Originally Posted by waynefj40 View Post
Stunning.
I've been looking at those pipes for my '63 TR6 for months. Unfortunately they're out of stock at Lowbrow right now and a bit more expensive (with shipping) from Feked. But, eventually I'm gonna have to have them.
She's coming along . . . still a long way to go at this point . . .
earwig is offline   Reply With Quote
Old 05-16-2012, 02:27 PM   #132
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
...coolest pipes are the dual highsides..
Old 06-02-2012, 11:23 AM   #133
johnny moped
learner
johnny moped's Avatar
Oddometer: 155
I agree they look the bomb, and why not burn both legs at the same time instead on one
johnny moped is offline   Reply With Quote
Old 06-03-2012, 08:29 AM   #134
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,411
This is what I drug out of a shed last fall:
I have a pair of high pipes for it - the headers at least. Here it is mocked up:
Unfortunately, they won't work with the motocross fender. So, I've got to decide between the plastic fender and the high pipes.
I've gone with the fender for now. Here's how she looks currently:
gravityisnotmyfriend is offline   Reply With Quote
Old 06-03-2012, 10:06 AM   #135
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,719
yamaha xt500
plugeye is offline   Reply With Quote
Times are GMT -7.   It's 11:25 PM.
