Old 02-12-2012, 06:32 PM   #1
header OP
Chris
header's Avatar
Oddometer: 1,743
Header's 525EXC refresh
I've been riding dirt bikes since I was ten but i've never been really into them until I turned 18 three years ago. For whatever reason I started to obsess dirt bikes. Everything about riding off road from the people to the fresh air I love it all and i've been riding most weekends since. Now as I approach my graduation date from college, two major thoughts contend for space inside that magic of the frontal cortex. The future concerns won't be discussed here, however a lack of time has stopped me from riding this winter but has left me with enough time to refresh/rebuild the 04 525 EXC I found in Tennessee last spring break. That on the other hand will be discussed here.
Ever since I learned how to ride i've always had sub par setups on the bikes i've ridden. None of them have been bad bikes but they were never smooth in their operation. Some things are still too expensive, like a revalved shock/fork, but others are simply things that most consider general maintenance, rebuilt forks for instance. This spring i'm going to get to ride a truly fresh bike. Not a fresh engine but everything else I can afford will be replaced. I want that feeling you get when you KNOW every bolt has been torqued and inspected. Solid.
When I was 19 I started my first race, didn't finish, tried another one and wrecked out. But I kept working at it and put in the blood sweat and tears and now I can hold my own with the local B class. I've learned a lot in the last few years and I've found slight differences in setup and suspension or technique mean a huge change in performance. To that end this will be a thread logging all of my maintenance and setup for the following year.
NOTE: I am not a mechanic, nor do I pretend to be one. I do make mistakes and many of these things ill write about will be incorrect so don't take my word for it.
You can see the XR650R behind the KTM. I really liked that bike but as my riding began to be mostly enduro style I had to be honest and get the right tool for the job. I chose the 525 so when I do dualsport riding I can still pull tall gearing without wringing its neck too much. Also I grew up on torque
Here she is in all her glory after I peeled off the stickers and cleaned her up. She had 290 hours but a fresh top end and didn't have too many real problems besides the regular little things.
Next up: some singletrack and a years worth of trails.
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 02-12-2012, 07:01 PM   #2
header OP
Chris
header's Avatar
Oddometer: 1,743
First up: testing and enjoying
From the time I had my XR I learned the manufacturers do know what they're doing. Everything on the bike has a purpose, foot pegs for instance are optimized for a certain size, something like an 8 I think . Wish my feet weren't 14s
So instead of tearing off the stock stuff its worth the time to ride the bike in its original form and find what doesn't work for you as the rider. I found the ergo's work great for my 6'2" frame but the sag numbers don't like my 200lb naked body. I could lose some weight easily enough but i'm very physically active with weights and if I lost any weight most of it would be muscle so stiffer springs are the answer. I needed the bike to be street legal so I wired up the supplied brake light and added some turn signals. I picked up a oversized gastank from an inmate then threw some oil, filters, and tires at the bike and rode it all summer.
I played around on some singletrack.
Did some racing.
Strapped on the giant loop and took it to what passes for sand riding around here.
And just proceeded to enjoy the bike.
I found what I liked and what I didn't. Most things I didn't like were things from the previous owner or things that could be mitigated through a different technique or setup. But I also found things I needed to change. I signed up on KTMtalk and read everything I could about suspension. I bought Neduro's PDF on suspension and race tech's suspension bible. I experimented and made mental notes of things I wanted to learn about.
KTM 530exc
525exc refresh
Old 02-12-2012, 07:19 PM   #3
header OP
Chris
header's Avatar
Oddometer: 1,743
Suspension
I don't have a lot of money. I can only work so much a year before its time to go back to school. I could work during school but my summer work pays literally twice what most college student jobs will ever pay so instead I just save my money and weigh every purchase I make. That combined with working since I was thirteen allows me to afford this hobby while still in school. Though there are limits. This usually keeps me from buying any upgrades I can't get my money out of like bling for the bike . Instead I put a lot into what I wear, I reasoned if I had gear that let me enjoy riding in winter, rain, mud, whatever means I could do what I enjoy more. Isn't that the idea? Me thinks so
After riding with a full tank of gas and the giant loop with the stock springs I didn't enjoy it so I decided to put money into something I didn't plan on getting my money out of. I went from .42kg/mm springs to .48kg/mm springs up front and swapped the 8.8N/m spring in the rear for a P30 progressive spring in the rear.
(can't find any pictures of swapping the spring so here's a XRR)
I liked the feel of the springs up front, they soaked up a lot more of everything and the rear spring being progressive kept me from bottoming on some fast G-outs. Unfortunately its not perfect. The progressive spring still doesn't give me the right sag for the 04/03 model EXC's. It sags too much chopping out the bike which is made worse by having the, now, correct springs up front. The front handles bumps better but now I have to straddle the gas cap to turn the thing
Next up: a lesson in suspension.
KTM 530exc
525exc refresh
Old 02-12-2012, 07:44 PM   #4
header OP
Chris
header's Avatar
Oddometer: 1,743
Suspension: Link less?
When I first contemplated KTM's my riding buddies told me they handled weird but didn't know why. They said it was something with the steering angle or some other geometry thing. I think a lot of the confusion is in the shock. Its not that it is going to handle any different but the way it works is different which causes people to freak out and attack the thing they don't understand. this is why we read books folks.
KTM's use what is called a link-less rear end. This means there is no link system that connects the shock to the swingarm. Instead the shock attaches directly to a heim bearing on the swingarm. This keeps the service down to only one bearing. It also allows trail riders to slide over the tree that is covering their favorite trail and you don't drag the links over the bark...or get the bike stuck on the hitch carrier like I did with the XRR because I didn't want to unhook the ramp and roll it off
Thats not the only function of the link system though. The links provide a very predictable amount of increased damping. This means the linkless system on KTM's has a lower rising rate of compression ie, it bottoms easier. To fix this WP (the suspension KTM uses) uses what is called PDS suspension. This means progressive dampening system. Suspension is affected by the velocity the shaft has to move to get out of the way of say, a rock, but doesn't matter about where the shaft is. Not so much with PDS. When the PDS shock compresses so far it engages a needle into the orifice that allows the oil to flow out of the way during movement. This forces the flow to move into a second circuit with another valve body and valve stack that adds compression. WP also runs a progressive spring that has a soft initial force but uses thicker coils that causes an increase in compression force when further through the stroke.
This all adds up to a very fussy setup that is picky on springs, sag dimensions, and makes for a harder tuning process. But it does still work, and man is it nice to be able to pull the shock off with two bolts
More tomorrow.
KTM 530exc
525exc refresh
header screwed with this post 02-12-2012 at 08:48 PM
Old 02-13-2012, 09:10 PM   #5
sashapave
riders on the strom
sashapave's Avatar
Oddometer: 1,427
Awesome thread! Keep 'er going!
11 250XC: Tweak Bunny
09 TE 610: Gunnar
74 Vespa Rally: Cream Dream
A ship in port is safe, but that's not what ships are built for. -Admiral Grace Hopper
sashapave is offline   Reply With Quote
Old 02-14-2012, 08:47 PM   #6
header OP
Chris
header's Avatar
Oddometer: 1,743
Clean that bike boy!
Alright, next up is how to enjoy wrenching
I am not good enough with a wrench to really enjoy working on things. I do to an extent but it doesn't take too big of a problem before i'm out there cussing and yelling. But it seems dirt bikes will be a part of my life for the unforeseeable future so I better learn to like it. First step in this process is to reduce the amount of problems i'm going to run into. Basic routine maintenance is the best way to keep your bike in working order but also it is important because it allows you to find problems and fix them before they develop. If you look over every bolt after each ride you will only have loose bolts, not missing bolts
To enjoy wrenching it has to be easy. For me the most annoying thing is when i'm working on something and i'm not getting anywhere, a rounded off bolt for instance. To combat this every bolt needs to have something on it, locktite, grease, anti seize, whatever it is they all need something. Heavily cleaning the bike before working on things really helps keep the damages you do to the bike down and having the proper tools helps a bunch too. All of these things help to ease the wrenching process.
Here is Neduro's thread, Spring bike maintenance guide which is really useful and has some good tips in it.
The next step is to remember to learn from what i'm doing wrong. Why is that problem happening, what am I doing wrong and how could I avoid this in the future? Every time I pinch a tube I remind myself its just more practice for the next tire change, then I think what went wrong. I do my best to stay calm and avoid loosing control. Everything I do is better when i'm still in control. There's a reason its called being emotional .
With that in mind I set to work on the rear tire first. I had been limping it along for a while but with winter setting in I decided to pull off the old rubber and swap in some new bearings while I was at it.
I always have a really hard time removing the rear axle and decided to replace the wheel spacers with steel ones that wouldn't wear out and let a bunch of crap into my wheel. I had to make a punch and push out the spacer since it had gotten stuck on the bearing. That worked so well it pulled the bearing out as well, except when I put the new bearings in I found a bunch of material had been removed from the hub . Anyone got a spare hub they don't need?
So I dismissed that and went onto the rear tire. Swapped out the old tube and spooned on a new M12 and proceeded to make swiss cheese out of the tube . But I stayed calm and didn't let it get to me. Instead I ordered a Ultra Heavy Duty tube like I should have done in the first place, and moved onto the forks.
KTM 530exc
525exc refresh
Old 02-14-2012, 08:50 PM   #7
header OP
Chris
header's Avatar
Oddometer: 1,743
Leaky fork seals
I have replaced fork seals before but i've never rebuilt any before so this was a learning experience for sure. I went from a perfectly working pair of forks to this in two days:
I wanted to take the forks apart as far as you can. I have read enough that it was time to see this stuff first hand. I was surprised it isn't as difficult as I thought it would be.
I don't have time to do the fork page tonight so ill save that for later this week.
KTM 530exc
525exc refresh
Old 02-20-2012, 07:30 AM   #8
header OP
Chris
header's Avatar
Oddometer: 1,743
Suspension
Where was I?
I decided earlier this year money put into suspension is never wasted but before that I knew I had to know what the suspension in my bike was supposed to feel like. I doubt any of the internals were still working properly or gave the same plush feel they are supposed to offer when broken in. So I took them all the way down as far as they could go. It wasn't all that hard.
I took the forks out and did all the easy dis-assembly.
Went a little further to get the base valve, spring guide and all the other internals out.
Then started taking apart the base valve to see what the stock valving is.
When you take the valve body and shims off the base valve holder looks like this:
You must be careful when removing though, the top of the threads are penned so you need to carefully file the area down before you remove the stack. Also when you remove them it helps to slide the whole stack onto a wire so you won't get things out of order.
After I had it apart I laid everything out and measured everything to see what the valving is. This is very important and makes the bike what it is. Dirt bikes are not about how much power they make or how fast they are. They are ALL about suspension and tire selection. IMHO of course.
Racetech's suspension bible (get one before opening your bike up) says to lay everything on a piece of glass to check if the steel has been bent. If it has the shims need replacing. They're cheap so once you know what stack is in there you can order a bunch and replace them all and start over with your suspension. This will give you a good base line when you want a revalve.
After the base valve I moved on to the rebound side. I wanted to do the same thing as before but I also wanted to remove the needle that controls the bleed ie. the piece that your rebound clicker presses down on.
Here is the entire assembly:
And when you remove the valving:
The needle resides inside the valve holder. This time called the rebound tap. It is held in with locktite and requires generous amounts of heat to remove. Not a flame, just heat for a long time. When removed and laid out everything looks like this:
After I recorded everything I buttoned it all back up and started assembling everything with the new bushings, seals, and sliders. This is what worn out bushings look like compared to good ones on the outside.
Do it all again and your done!
Next up, the rest of the bearings.
KTM 530exc
525exc refresh
Old 02-29-2012, 07:43 PM   #9
header OP
Chris
header's Avatar
Oddometer: 1,743
Head stem
Earlier this year I tore the front end down to the steering stem bearings and cleaned and repacked them as well as I could, I had never ridden a bike with fresh greased steering bearings. :whoa if you haven't greased them before you are really hampering yourself by not doing it. It makes line selection and adjustment so much better. I figured if I got that much of an improvement from just greasing them I wondered what a new set would do.
About halfway through greasing the lower.
I pulled the old ones out, knocked out the races and pressed all new freshly greased ones in
All finished up waiting on the forks
I figured I should go through all the wiring behind the mask before I put it all together. After taking a long detailed cleaning of all the little stuff up front I cleaned up the wiring a bit and started putting the front end back together.
Here is how the bike was when I stopped working.
KTM 530exc
525exc refresh
Old 02-29-2012, 08:13 PM   #10
header OP
Chris
header's Avatar
Oddometer: 1,743
The next morning I jumped in again hoping to get everything wrapped up and get the bike back together. I should have known better to think I would be able to get the swingarm bearings out without a problem
I still got a lot done, I received my rear tube and the hard anodized wheel spacers from Enduro Engineering so I finished up the wheels.
I then moved back to the front end and finished that up. Then rolled the bike over into the sun where I could see.
With the front end and wheels all done the only thing left was the swingarm. Getting the rod out took all of about ten seconds which is a first. But the bearings had been neglected and were probably the originals so I had to cut them out.
After taking them out I did my best to clean everything up before pressing in the new bearings. I made a simple press out of some sockets and a large clamp. It worked great and I was able to press the new bearings in easily.
After pressing in the new ones I ziptied them so I wouldn't lose anything.
Did it all again and set the swingarm aside. I was feeling ambitious so I pulled the shock off and cleaned it off while taking a preload measurement.
I also decided I wanted a clean muffler. I figured I had the shock, swingarm, and mudflap off so why not take the header and mid pipe off and give them a nice clean.
About halfway through.
I don't have any pictures of it finished but I know there was a lot of mud cooked on there based off of the amount of cleaning I had to do the next day All the vehicles needed a good cleaning and the garage had to be leaf-blown out. Dad was not thrilled
KTM 530exc
525exc refresh
Old 02-29-2012, 08:20 PM   #11
header OP
Chris
header's Avatar
Oddometer: 1,743
After cleaning up the garage I rolled the bike outside, after knocking off all the big bits of dirt, and aggressively cleaned everything under the plastics. After a second detailing I let it dry off and took out the air filter. I oiled up a new one and cleaned the old one, setting it aside to dry and be re-oiled. I went ahead and checked the valves and adjusted the intakes. Then changed the oil and filters and replaced the rusted bolts that were holding the skid plate on. I wanted to pull the carb and give it a good cleaning while I was at it but I decided it can wait.
With everything under the hood adjusted I went back to cleaning it all up again, then added the plastics and put a light coat of armor all on everything to give it a nice sheen
Here is how it sits now with one final looking over the front end for a clicking that is being elusive then its ready for a shake down ride this Friday and Saturday.
KTM 530exc
525exc refresh
Old 02-29-2012, 08:33 PM   #12
header OP
Chris
header's Avatar
Oddometer: 1,743
Not bad for a 21 year old with limited mechanical experience eh?
A list of the things I did:
Bearings including
--Swingarm
--Upper and Lower triple clamps
--Wheel bearings and seals
--Rebuilt forks with new bushings, wipers, and seals
--Hard anodized wheel spacers (front and rear)
--New air filter
--BRP threaded bar inserts
--Oil change and filters
--Lots of lock-tight and antisceze
--Loads of cleaning, checking, and greasing
--Cleaned up any dodgy electrical connections
--Rerouted many wires to avoid future electrical issues
And overall did a close inspection of everything I could. My goal was to give the bike that secure feeling. I knew I would be unsatisfied if I didn't do AT LEAST everything I did here, anything less and I would have felt that I just changed the limiting factor. I could have gone further as well. The heim joint for the shock could have been replaced, the spokes i'm sure are stuck where there at now, i'll need new front brake pads and a front tire soon as well but I did what I felt was necessary right now and I am very excited to try the bike out with fresh components.
Its like getting a new bike, just without any of the problems from the previous owner!
KTM 530exc
525exc refresh
Old 02-29-2012, 09:12 PM   #13
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
It always makes a big difference when I do maintenance on my bikes. I like your approach to it too, I will have to remember some of your sayings.
lstzephyr is offline   Reply With Quote
Old 02-29-2012, 09:47 PM   #14
header OP
Chris
header's Avatar
Oddometer: 1,743
Thanks, though i'm sure any of the good quotes came from other people's threads. There are some good ones out there though!
KTM 530exc
525exc refresh
Old 03-01-2012, 02:42 AM   #15
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,815
a good read
will watch this thread with interest
cheers
Mark
These are the best days
Mark_S is offline   Reply With Quote
Times are GMT -7.   It's 05:06 AM.
