Old 03-28-2012, 04:07 PM   #46
Bucho
Oddometer: 2,082
Originally Posted by 1Bonehead View Post
Will update Sunday .
awesome, we are anxiously awaiting
Bucho is offline   Reply With Quote
Old 04-01-2012, 05:41 PM   #47
1Bonehead OP
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
I got the subframe built today. I am going to finish it off with a piece of diamond plate aluminum to form a skid plate.
Should be going down the road in two weeks hopefully.
1Bonehead is offline   Reply With Quote
Old 04-02-2012, 04:01 AM   #48
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,637
I like the way you removed the motor to make it easier to work on
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler is offline   Reply With Quote
Old 04-02-2012, 04:26 AM   #49
1Bonehead OP
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Yeah, I would have probably finished if I didn't do that.
Old 04-04-2012, 08:17 AM   #50
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,779
Only see the front mount and that seems low. Are you planning to have the height difference that is common on Kalich-type leaners?
Reference post
The toe in should be able to be adjusted in one way or the other, but with the front mount higher and a small/narrow tyre the leaning shouldn't be of concern. One will need the toe in adjustment to get neutral handling at your touring speed.
Reference post 2
If you put the front pivot higher than the rear one it will tend to make the sidecar wheel steer in the direction that the bike is leaning. The amount of up/down offset will determine the degree of steering effect at different lean angles.
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 05-02-2012, 05:26 PM   #51
1Bonehead OP
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
98% complete
This weekend is test ride weekend
Old 05-07-2012, 06:54 AM   #52
1Bonehead OP
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
I had to put off the test drive until next weekend. I will update more pics this week.
Old 05-07-2012, 04:11 PM   #53
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,637
Old 05-08-2012, 03:54 AM   #54
Pete-NZ
Pete-NZ's Avatar
Oddometer: 784
The 4130 tube will make a dam strong yet still be light..
As for the sidcar wheel steer... On mine I have the front
mount 100mm higher than the rear with 100mm of lead
on the car wheel..
The bigger the diffrent's in the mount point hight , the
more lead you can run on the side car wheel..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ screwed with this post 05-08-2012 at 04:01 AM
Pete-NZ is offline   Reply With Quote
Old 05-08-2012, 03:58 AM   #55
1Bonehead OP
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
I got enough tube for four cars at a price of 86.00. What a steal. I gave home a 100 and said keep the change so I didn't feel guilty .
Old 05-08-2012, 04:06 AM   #56
Pete-NZ
Pete-NZ's Avatar
Oddometer: 784
Originally Posted by Feedback Cycle View Post
I'm betting a leading link or leading leg is in my future.
Show me how it's done.
Thats the good thing about a leanner.. No leading link is required...
Old 05-08-2012, 04:19 AM   #57
Pete-NZ
Pete-NZ's Avatar
Oddometer: 784
How wide should it be?
What is the wheelbase width supposed to be?
What is the weight to be?
I can only go by what I have done on my 2...
XR250 unit had a 900mm track.. 1100 wide from the centre line of the bike...
XT660 will have 900 to 1000mm track.. 1200 to 1300mm wide from the centre line of the bike..
Times are GMT -7.   It's 11:24 AM.
