Old 02-17-2012, 01:17 PM   #1
JohnnieBoy OP
JohnnieBoy's Avatar
Oddometer: 115
$20 for lower shock bolt... thats just stupid
So I have an Ohlins shock on the way as well as one of Dan's Indy kits (thanks Dan!). Anyway, I called BMW of San Diego to most likely order an encapsulated lower rear shock bolt. Well , they actually have 3 in stock.... for $19.95 a piece! Really? $20 bucks for a frikken bolt? C'mon BMW! Shit like that just pisses me off.
So why not just put some blue Locktite (which I have in my garage) on it and call it good?
John Hopkins
2011 F800GS
2009 FJR1300A
2003 XR650R
San Diego. CA
JohnnieBoy is offline   Reply With Quote
Old 02-17-2012, 02:08 PM   #2
johnparjr
johnparjr's Avatar
Oddometer: 203
Just use the old one you will be fine.
johnparjr is offline   Reply With Quote
Old 02-17-2012, 02:51 PM   #3
LukasM
Oddometer: 5,384
Yeah, clean off the old Loctite properly first and then apply fresh before re-installing.
Old 02-17-2012, 03:58 PM   #4
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
worked for me.... never had any problems
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 02-17-2012, 04:17 PM   #5
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,306
Worked for me as well. 30,000 miles on a reused bottom shock bolt and no issues. It is a custom pitch bolt that is impossible to find from any fastener house!
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is online now   Reply With Quote
Old 02-17-2012, 07:19 PM   #6
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
I bought a 10 pack.
johngil is online now   Reply With Quote
Old 02-17-2012, 07:59 PM   #7
JohnnieBoy OP
JohnnieBoy's Avatar
Oddometer: 115
Originally Posted by johngil View Post
I bought a 10 pack.
Sounds like you need it!
Thanks guys. Although I didn't know it was tapered, I was still already planning on cleaning the bolt really well and re-using it with blueLT - Just on general principal. BMW can suck it on that one!
John Hopkins
2011 F800GS
2009 FJR1300A
2003 XR650R
San Diego. CA
Old 02-17-2012, 08:22 PM   #8
nimrod
Pog Mo Thoin
nimrod's Avatar
Oddometer: 666
Knocked the skid plate off my GS. New hardware to reattach included a small SS washer - $5.00 - .25 at any hardware store!
In my dream, the angel shrugged and said if we fail this time it will be a failure of imagination
and then she placed the world gently in the palm of my hand.
B. Andreas
"Betweem two evils, I always pick the one I never tried before" -Mae West
nimrod is offline   Reply With Quote
Old 02-19-2012, 12:54 PM   #9
mrnoitall
Oddometer: 146
In fairness to BMW () There are big differences between bolts. Things like Tensile Yield Strength, Tensile Ultimate Strength, Proof Load Stress,Hardness, Carbon density, Quenched and Temperament effects the price to a great degree. BMW likely uses very high quality bolts.
$20 may be pushing it but the BMW bolt is not a class 5 bolt at home depot.
mrnoitall is offline   Reply With Quote
Old 02-19-2012, 03:27 PM   #10
shelion
Goddess of Fire
shelion's Avatar
Oddometer: 415
I think johngil may disagree with you on that one.
http://www.advrider.com/forums/showthread.php?t=486251
We are healthy only to the extent that our ideas are humane.
shelion is offline   Reply With Quote
Old 02-19-2012, 04:32 PM   #11
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
No more bending anything since Indy came along.
I'll also add a question.
What is the correct torque spec. with the factory applied thread locker? It takes quite a bit of effort just to turn the bolt with that shit on there.
I have had problems with the bottom bolt coming loose. With good old blue Loctite it's easy to tell. With the factory stuff, there is almost no way to tell if the fastener is loose or not.
johngil screwed with this post 02-19-2012 at 04:46 PM
Old 02-19-2012, 05:18 PM   #12
mrnoitall
Oddometer: 146
Wow, obviously that bike has seen major trauma. The frame is bent. No bolt will survive everything.
Old 03-05-2012, 08:57 PM   #13
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,074
The Torque spec for the Upper or lower shock bolt is 100 Nm. (74 Ft lbs.)
Fitted-head screw, M12 x 1.5-10.9.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
