02-20-2012, 02:37 PM
#1 |
Purveyor of Light
Oddometer: 3,661
Dualsport Fairing w PnP LED Lighting
Have you ever wanted a little more protection on that long dualsport ride or just finished that gnarly trail and have a long stretch to get back to camp? Didn't plan to ride till dark but will never forget that last trail! Now you don't need to worry about that awesome stock headlight and mask, we've got a replacement in the works.
We've been working with other like minded riders to come up with this prototype. ![]() Mounted on a 08 Husky TE450. Fairing Made of fiberglass, available in black, white and additional color(s) and/or graphics options to be determined. Recessed light wells keep the lights out of harms way. The vertical features make the fairing rigid while keeping the weight down. Lighting The fairing uses our proven led lights, from the Model 30 to the awesome Model 60, aluminum housing, oring sealed, waterproof. You choose the light configuration based on desired amount of light and available stator output. The lower light is dimmable so as not to blind oncoming traffic, once you’ve set the level you like, the light will remain at that same level until you change it, a set it and forget it solution. Not DOT legal, my experience thus far is that it works without annoying others. Want some serious light off road; hit the high beam switch and both lights go to full power. Yep, no additional switches on the bars. FULL power means 7200 lumens if you have 2 model 60s installed. Electrics The Plug n Play option will be available for KTMs and Husqvarna as of now. Want a PnP option for your bike; send me a picture of your headlight connector and the pinouts/electrical connections. Mounting We will offer the fork strap mount as used on the Husky and a KTM mount with 2 straps up top and the pins on bottom. If you have other suggestions on common mounting options, I am all ears. Pricing Yet to be finalized. However as with all our products, it will be a great value. We expect a single light setup to be <$200. And install in 5 minutes , maybe 10 if you ![]() Any and all feedback from YFFs is appreciated. Expected to be available in March 2012.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
02-20-2012, 08:19 PM
#2 |
Oddometer: 1,668
PERFECT! I assume either the lights are adjustable, or the lower one is pointed down more for low beam use?!
I'm interested, and could potentially be the wr250r guinnee pig if you're into it. I've done a bunch Of electriCal/lighting stuff on my other bike (link in signature), and the wrr now needs some attention. |
02-21-2012, 05:14 AM
#3 | ||
Purveyor of Light
Oddometer: 3,661
02-21-2012, 02:23 PM
#4 |
Allergic to Asphalt!
Oddometer: 5,986
I like these mounts. Solid, easy to take the light on & off and gives a bit more space for the wiring and spedometer.
02-21-2012, 02:43 PM
#5 |
Oddometer: 1,446
I would love this fairing with an opening for a 7" round headlight. I want to use the Truck lite LED headlight that is DOT approved. Is something like that possible? It would go on my XR650L.
"I refuse to tiptoe through life only to arrive safely at death" 2009 Buell XB12X(sold), 2006 Triumph Sprint ST, 2006 Tiger 955i, 01 XR650L replaced by a KLR, and now a 2010 Honda NT700V for the wife. |
02-21-2012, 06:02 PM
#6 | ||
Purveyor of Light
Oddometer: 3,661
![]() 7" light with a dakar screen cut to fit.
02-21-2012, 08:51 PM
#7 |
Twisted Throttle
Oddometer: 1,673
in to hear about the progression of this fairing. Looks really good on the Husky TE.
11 Husqvarna TE630 11 Husqvarna SM630 08 Husqvarna TE510- sold 10 Yamaha FJR 1300 |
02-21-2012, 08:55 PM
#8 |
Oddometer: 95
02-22-2012, 03:54 AM
#9 |
Fart Letter
Oddometer: 3,834
I'm in on this---WR250R.
I'll be all over this for my WR250R
When it's ready ---------I'll order it---I want 2 60's in it with the dimmer. If you don't have time Sanjoh to make it plug and play---I can handle the wiring. I'll want a white fairing. Just put a pair of 60's on my KLR---and have been holding off for another purchase cause I just didn't know what to do on my WR ????? Now I guess I do. By the way Sanjoh-----the WR250r has 350 watts of power and I've used my stock headlight, gps, heated grips, and heated vest for a 6 week trip to Alaska---the charging system on this bike is phenomenal for a small bike. The stock wire feeding the stock headlight will be plenty ample in size. BigDog
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" |
02-22-2012, 05:27 AM
#10 | ||
Purveyor of Light
Oddometer: 3,661
Something about a white dirt bike ![]() Quote:
Thanks for the offer on the wiring. 350 watts! I'm jealous, why can all bikes have that?
02-22-2012, 12:15 PM
#11 | |
Oddometer: 57
or maybe a whole new product line? one tall version one shorter version one with the best of both, top half removable
02-22-2012, 03:11 PM
#12 |
Twisted Throttle
Oddometer: 1,673
Are you to the point where you can provide the dimensions of the fairing (lengthxwidth)?
It appears that mounted on the Husky there may be some amount of adjustment either up or down based on where the clamps are positioned on the forks..correct?
02-22-2012, 03:23 PM
#13 |
Oddometer: 602
Great Idea
When can we order???
02-22-2012, 05:24 PM
#14 |
Oddometer: 95
Another WR250X user subscribing. Very impressed with your LED lights. This could be a worthy upgrade as well.
Although an adjustable windscreen would be preferable and easier than putting out models with different heights. Adjustable windscreen is pretty easy. Just drill a few holes. ![]() Cheers Subaru297 screwed with this post 02-22-2012 at 05:36 PM |
02-22-2012, 07:38 PM
#15 | ||
Purveyor of Light
Oddometer: 3,661
Thanks for all the feedback thus far.
Just got back from an evening ride. The low beam works wonderful (currently model 30), plenty of light to see yet not blinding anyone. Local police had a close inspection and approved ![]() Quote:
Next month. The fairing will be offered in any lighting configuration of the model 30, 44 or the 60. Can't wait to to test it with out with two 60s, that is one amazing light. Keep in mind you get full power on high beam so 2 60s will pull just north of 60 watts and make daylight
