Old 10-29-2012, 06:49 AM   #241
empedrado
Oddometer: 372
Where to buy
Cannot seem to find the fairing on your website, where should I be navigating to? Any experience mounting with a KTM roadbook holder?
empedrado is offline   Reply With Quote
Old 10-29-2012, 04:07 PM   #242
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,267
Originally Posted by marcwestbmw View Post
OK,one last question. I have a Touratech DE/Xenon on my KTM 950 Adv S. Have you guys mounted any lights in one of these setups? The combo is great on the road. But, I need more light offroad.
We have not mounted lights in that setup. Looking at the kit pictures, it looks like it would be a very easy install. Is it the high beam that is lacking or ?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-29-2012, 06:55 PM   #243
marcwestbmw
Walkin' Mans Friend
marcwestbmw's Avatar
Oddometer: 491
Both the high and the low offroad. The spread isn't wide enough. Btw, this after I pulled the grill. It made nasty shadows. On the road the high is fine. The low is lacking.
"Where the Hell's Major Kong?"
marcwestbmw is offline   Reply With Quote
Old 11-10-2012, 01:11 AM   #244
espressodrinker
Cape Town Wanderer
Oddometer: 201
Ktm 525 exc '06 with crap triangular headlight
Would it be possible to drill out the back of the existing headlight and mount a 60 light with it's face up against the existing lens?
I suppose that I would have to drill a few other holes to allow airflow as well.
I don't want to mess with the existing look of the front.
espressodrinker is offline   Reply With Quote
Old 11-10-2012, 01:41 PM   #245
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,267
The light needs air to stay cool so if you could add some venting, it would probably work. Otherwise you could try our 08-12 KTM dropin headlight replacment and update the looks of your bike.
Old 11-14-2012, 03:00 PM   #246
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,657
Just picked mine up at the PO for my DRZ400E. This is a quality piece of gear! I am impressed with the workmanship and finish. I ordered the model 60/30 combo as I'm trying to conserve wattage.
I did some driveway bench tests on the unit tonight. Although Sanjoh strongly recommended mounting two model 60 lights, I think this combo will be fine! It puts out so much more usable light than the 35 watt halogen headlight I currently have there is no comparison. Obviously, I haven't had the chance to put it side-by-side with my HID set-up on the KLR, but I am very pleased with what I see.
The color temperature appears to be good. I assume it's around 6000 kelvin, which is a little blue, but a few yellow lens guards should get it near 5500 k -- natural sunlight.
The glass is thick enough to support reasonable accessories, but it would be great to offer a dash panel for the fairing as an accessory.
It's obvious that this fairing was designed by dual-sport riders. There's attention to rounding the corners and breaking sharp edges. If you go over the bars, this one's not going to cut your throat or rip your spleen out. That's a significant bonus.
Thanks, John.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 11-14-2012, 03:30 PM   #247
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,267
Glad to hear you are happy with it
The color temperature is actually 5500k. I highly recommend trying them before using any filters.
Thanks again for your business, much appreciated.
How about some pics when you get it mounted?
Old 11-14-2012, 04:53 PM   #248
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,657
Glad to know that about the color temp, John. I will purchase the clear lens protectors. I was going to ride it in any event before attempting any fiddles.
This is why it's important to purchase gear from real ADV riders. I was in a rather involved conversation with inmate AtlasEXP last night on this very subject. While lights that go into the blue spectrum may look cool on a bling mobile, they are not very useful in the woods. Our eyes are adapted to sun light.
Thanks for the good product and fine service.
The Rock 2013 RR
Old 12-09-2012, 06:50 PM   #249
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Have you ever wanted a little more protection on that long dualsport ride or just finished that gnarly trail and have a long stretch to get back to camp? Didn't plan to ride till dark but will never forget that last trail! Now you don't need to worry about that awesome stock headlight and mask, we've got a replacement in the works.
We've been working with other like minded riders to come up with this prototype.
Mounted on a 08 Husky TE450.
Fairing
Made of fiberglass, available in black, white and additional color(s) and/or graphics options to be determined. Recessed light wells keep the lights out of harms way. The vertical features make the fairing rigid while keeping the weight down.
Lighting
The fairing uses our proven led lights, from the Model 30 to the awesome Model 60, aluminum housing, oring sealed, waterproof. You choose the light configuration based on desired amount of light and available stator output.
The lower light is dimmable so as not to blind oncoming traffic, once you’ve set the level you like, the light will remain at that same level until you change it, a set it and forget it solution.
Not DOT legal, my experience thus far is that it works without annoying others. Want some serious light off road; hit the high beam switch and both lights go to full power. Yep, no additional switches on the bars. FULL power means 7200 lumens if you have 2 model 60s installed.
Electrics
The Plug n Play option will be available for KTMs and Husqvarna as of now. Want a PnP option for your bike; send me a picture of your headlight connector and the pinouts/electrical connections.
Mounting
We will offer the fork strap mount as used on the Husky and a KTM mount with 2 straps up top and the pins on bottom. If you have other suggestions on common mounting options, I am all ears.
Pricing
Yet to be finalized. However as with all our products, it will be a great value. We expect a single light setup to be <$200. And install in 5 minutes, maybe 10 if you
Any and all feedback from YFFs is appreciated. Expected to be available in March 2012.
Hideous
Cobain is offline   Reply With Quote
Old 12-10-2012, 06:10 AM   #250
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
Originally Posted by Cobain View Post
Hideous
Care to do better?
Critics are, well, not productive ;-}
MAKERS, on the other hand, well, DO stuff . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
bomber60015 is online now   Reply With Quote
Old 12-10-2012, 03:08 PM   #251
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Hideous
well this certainly explains your story
Im 18 and bought my dr last summer. First vehicle actually in my name.
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 12-24-2012, 02:41 PM   #252
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,267
Originally Posted by bomber60015 View Post
Care to do better?
Well put
Old 12-26-2012, 04:41 PM   #253
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
Wr250r
Sanjoh... Is there a WR250R fairing yet? I didn't see any photos of one so I'm guessing not yet??
Hit me!!!
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 12-28-2012, 06:24 AM   #254
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,267
Hit me!!!
It is on the short list. I expect to have one mounted in January.
Old 12-28-2012, 11:31 PM   #255
BanhXeo
BanhXeo's Avatar
Oddometer: 337
Is this the same fairing offered at www.globetrottin.com?
2013 KTM EXC-F SOLD
2013 BMW F8 GS FOR SALE
SmugMug: http://ktmrider.smugmug.com/
This is my WIFE, here are my BIKES, and these are my STORIES: http://www.advrider.com/forums/showthread.php?t=897188
BanhXeo is offline   Reply With Quote
Times are GMT -7.   It's 07:06 AM.
