02-20-2012, 07:48 PM
#1 |
Oddometer: 35
SAS Removal, Help
Ok Orange Crush,
I need some help. Thanks in advance. 07 990, 16000 miles. Just took the SAS and the canisters off following the H.O.W. instructions. Bike will not start, FI light is on. Any advice would be a great help before I tear back into it to figure out where I may have gone wrong. Thanks |
02-20-2012, 08:27 PM
#2 |
Master of the Obvious
Oddometer: 1,727
Sounds like something left unplugged. Is the FI light on steady, or blinking a code?
1911fan
Read The Patriot Post -- It's Right. It's Free. http://patriotpost.us/subscribe/ Sometimes the light to see your way forward is provided by the bridge burning behind you. |
02-20-2012, 08:55 PM
#3 | |
MotorcycleMayhem
Oddometer: 2,154
1. can you hear the fuel pump cycle when the ECU does its POST (you see the tach needle swing through)? 2. did you terminate the SAS system plugs with resistors or just leave them unplugged or are they still plugged into the electro-valves?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
#4 |
Needs to ride!
Oddometer: 2,066
Did you do the 22k ohm resistor thing x2? (just double checking, this part is 990 specific)
WHHHAAAAT!?!?! ![]() 5 Star RR: VIOLA-TING AMERICA - Chasing the dream of music and motos |
02-20-2012, 08:56 PM
#5 |
MotorcycleMayhem
Oddometer: 2,154
typically will not cause a "non start", but will throw FI codes unless the SAS is disabled in the ECU
02-21-2012, 06:51 AM
#6 | |
Oddometer: 35
The light is solid. 1. can you hear the fuel pump cycle when the ECU does its POST (you see the tach needle swing through)? Yes, the pump cycles and tach swings, but it will not crank. It just keeps cycling through the start up procedure (tach keeps cycling) 2. did you terminate the SAS system plugs with resistors or just leave them unplugged or are they still plugged into the electro-valves? We plugged the SAS system plugs with 22,000 resistors just like in the H.O.W. Oilburner375 screwed with this post 02-21-2012 at 06:57 AM |
02-21-2012, 07:46 AM
#7 |
Oddometer: 1,727
Electrical problem somewhere. This may sound stupid, but I had a no-start after my SAS-ectomy, which was a low battery. Charge it up for a day and try again. If that's not it, you get to go back and undo your corrections, step by step, and hit the starter button after every step.
I think a connector is unplugged, and not one of the ones you were working on. 1911fan
02-21-2012, 09:02 AM
#8 | |
Oddometer: 35
Yep that what it sounds like to me too. I will charge the battery, and recheck all of the connections. Thanks for tips fellas. |
02-23-2012, 08:23 AM
#9 |
Oddometer: 1,727
Damn, where's that foot-tapping smiley when you need it? Up and running yet?
1911fan
02-23-2012, 06:55 PM
#10 | |
Oddometer: 35
![]() Got it started tonight. Been so friggin busy with work, etc. Turns out it was the battery, I have had it on a battery charger since Tuesday. Fired right up first try. Thanks for the suggestions.
02-23-2012, 09:14 PM
#11 |
Oddometer: 1,727
Good to hear, now go ride!
1911fan
03-28-2012, 04:16 PM
#12 |
Oddometer: 35
Fargin bike!
Needing some insight again. Got the bike running, was running fine, after about 60 or 70 miles things go haywire. Can only twist half throttle, then she cuts out and spits and sputters. We decided it must be the fuel pump, installed this weekend. Ran great, made an improvement, but after 70 miles back to 1/2 throttle madness.
What do you all think, any advice, or lessons from you all would be greatly appreciated
03-29-2012, 05:33 PM
#13 |
Oddometer: 1,727
FI light blinking a code?
1911fan
03-29-2012, 05:41 PM
#14 |
Oddometer: 35
That is a negative on the FI light.
Took it apart to check connections, again. Found a pinched fuel tank vent hose. Fixed that. Ran it 20 miles today, seems to be running fine for the time being. Funny how Gremlins work! Will keep you posted. Hopefully this will be the last post on this project. Thanks 1911fan |
