Old 02-21-2012, 04:40 PM   #1
bwalsh OP
bwalsh's Avatar
Oddometer: 11,189
2005 950ADV issues???
It's a 2005 NOT a 2006. I screwed up with the title.
I've been talking with a guy who has a 2005 KTM 950 with 20,250 miles for sale. It is real nice and runs good at normal speeds and RPM's BUT at about 6 grand the engine starts vibrating hard.
Also, if you cut it off then start it back up a few minutes later, the engine sounds starved for oil for about 2 seconds. I didn't get to hear it start up when it was cold as I was filling out a waver while one of the employee's started it. I made a video. You can just hear the clatter for a brief second or two. If you restart immediately it wont do it.
Do you think this is normal? I know BMW's do this but have never heard of a KTM doing it. A buddy who has a 990 said his does not do this.
It's a real good deal(that I've been negotiating) but I don't want to be doing engine work right off the bat if there is something wrong with it.
Any suggestions as to what might be causing it? Causes, cures? Should I get it or walk away?
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh screwed with this post 02-21-2012 at 04:48 PM
bwalsh is offline   Reply With Quote
Old 02-21-2012, 04:58 PM   #2
OtownMike
Electron Pusher
OtownMike's Avatar
Oddometer: 288
Sounds like the cam chains tensioners coming up to pressure. Looks like it stops once your oil pressure light goes off, mine does the same thing, so do most, amount of time varies. I havent payed attention to how long it has to sit before it will do it again. If the paper oil filter is dirty it can take longer to pressurize. I havent noticed hard vibes at any particular RPM, not sure about that.
OtownMike is offline   Reply With Quote
Old 02-21-2012, 05:03 PM   #3
japslap
Japslap
japslap's Avatar
Oddometer: 141
my 07 makes that rattle on startup from cold,pretty sure thats normal....
japslap is offline   Reply With Quote
Old 02-21-2012, 05:07 PM   #4
Orangecicle
Orangecicle's Avatar
Oddometer: 2,468
Sounds pretty normal to me. Some 950s clatter more than others. Wear ear plugs. . If she rus rough at speed, it could be carbs. I've seen that with my bike, which was way over jetted when I bought it.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 02-21-2012, 05:31 PM   #5
vabuckaroo68
Gnarly!
vabuckaroo68's Avatar
Oddometer: 1,169
Sitting still at 6K or running down the road?
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '76 Husky 360WR/CR,
vabuckaroo68 is offline   Reply With Quote
Old 02-21-2012, 05:32 PM   #6
MT950
"OLD" Adventurer
Oddometer: 246
Rattle/vibration!
Cam chain noise at start up is normal,some seam worse than others! However, you also mention it runs smooth too 6,000rpms the picks up bad vibration at higher revs? May want to check valve adjustment? You can check cam chain at same time. It could also be in carb jetting? My 06 950 S pulls hard/smooth( IMO) all the way to 9500rpm which should be normal. Service is the "key word" the big KTM 9xx's are great (I've owned 3) , but need your attention "maint." to get max. performance.
MT950 is offline   Reply With Quote
Old 02-21-2012, 05:36 PM   #7
bwalsh OP
bwalsh's Avatar
Oddometer: 11,189
Tell me more about these cam chain tensioners. Are they adjustable? Why would they be an issue with only 20,000 miles?
It does stop as soon as the light goes off though one time it continued making noise for close to ten-twelve seconds.
I PMed a couple inmates. One mentioned dirty oil filters. It could be. The oil is definitely not fresh.
Would it make the whole bike shake? It runs pretty smooth otherwise. I don't plan on running it WOT but I also don't want to buy someone elses troubles.
Thanks for the replies so far! Keep them coming. I want to decide in the next day or two whether I want to get the bike or keep looking.
2004 XR650L
Old 02-21-2012, 05:37 PM   #8
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,374
I wouldn't worry about the ticking on start, but I would be concerned about the vibration. It could be as simple as a loose motor mount, or as serious as a motor tear down. A friend of mine fought vibes on a used 950 he bought for months, and upon engine tear down found a severely worn piston.
Run, don't walk, unless you can get it cheap and have the mechanical abilities to find the problem.
"The BSC was strong in that one, had to get out !"
dlrides is offline   Reply With Quote
Old 02-21-2012, 05:37 PM   #9
bwalsh OP
bwalsh's Avatar
Oddometer: 11,189
Down the road.
2004 XR650L
Old 02-21-2012, 05:44 PM   #10
bwalsh OP
bwalsh's Avatar
Oddometer: 11,189
It pulls great, just starts vibrating hard at around 6000rpm's. I was too skierd to take it any higher.
What about Valve and carb adjustments like others mentioned? There is no vibration until 6000. If I hadn't gotten into it for the hell of it I never would have noticed the vibes. That was seven miles of 70mph interstate and the rest 35-60 on back roads.
2004 XR650L
Old 02-21-2012, 05:51 PM   #11
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,374
That falls in the range of potential causes.
Do you have confidence in internet forums diagnosing the issue sight unseen ...................... with your money ?
Old 02-21-2012, 06:04 PM   #12
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,771
Vibration: The main jet might be clogged or improperly set for one of the cylinders, a wheel might be out of balance.
Noise: My bike does that when hot after it's been sitting over lunctime, and sometimes when cold. The fix is a new relief valve spring. Higher viscosity oil (10-50 or 10-60 for example) will help until you get the spring replaced.
The noise I'm not worried about. Some vibration is normal with these bikes so your best bet would be to have another 950A owner in the area check it out with you so he can let you know if the vibes are normal or if something's majorly borked. Another more involved option is to take it to a dealer for an inspection and have a compression test done on each cylinder.
If you don't want to go through the trouble tell the guy to give you a break so if there is engine trouble you can somewhat pay for it. Carb's gumming up/improperly jetted, or a shittily balanced wheel are much more common on these bikes then a bad piston as was suggested. Of course I'm about 1700 miles away so take that for what it's worth.
After having my bike for 6 months now I'm so not intimidated by wrenching on it, you'll learn it one way or another when you own one of these
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 02-21-2012, 06:29 PM   #13
crazybrit
crazybrit's Avatar
Oddometer: 8,553
My 06 950 started developing a bad vibration issue at about this RPM. I've owned a 625 SXC (LC4) so I'm used to vibes
Anyways, weird vibe issues do occur. Searching i found a few people who's 950 had suddenly started noticably vibrating more at around 5-6000 rpm.
Here is my horror story. Maybe this thread will give me some motivation to go debug it. I've procrastinated since last June. http://advrider.com/forums/showthread.php?t=697087
crazybrit screwed with this post 02-21-2012 at 11:50 PM
crazybrit is offline   Reply With Quote
Old 02-21-2012, 06:52 PM   #14
bwalsh OP
bwalsh's Avatar
Oddometer: 11,189
UIh...you doubt the mighty Orange Crush? I'm kind leaning towards something a little less harsh then a worn piston though...I hope I'm right.
It does have akra's on it and I don't know if the PO rejetted but it pulls really good down low. It's not a wheel out of balance. I can't ask for any more of a break, see below...
Here's the rest of the story and may clear some things up...
When I found it a month ago it had been sitting on consignment since the end of September. It's in a store that doesn't sell these types of motorcycles hence the reason it's still there.
I asked to hear it run. They pulled it outside and it had a dead battery. Jumped it with another battery and it ran like crap. OK, it's been sitting with ethanol gas in the carbs for 4 months, that's understandable.
They took it into their shop. The mechanics are kind of on the young side and not rained to work on KTM's(remember this)
I made a low offer. The store owner said he would contact the owner of he bike. I didn't want to fool with it or even test ride it until I knew whether I was going to buy it or not. I left.
The store owner finally got ahold of the owner of the bike and he would only come down halfway from what he wanted and what I offered. No deal.
Last week I called to see if it was still there. It was. I made the same offer. The store owner said he would call the owner again and tell him "look, this is the only serious offer you have had. This guy is really interested and I would advise to take his offer."
I call today to see what's up. Still hasn't gotten a hold of the bike owner. I'm riding and not too far away. He says to stop by and ride it anyway.
Get there and he has gotten in touch with the bike owner. Will split the remaining difference. Deal! That's when I take it for the ride and discover these issues.
When they took the bike on commission they did nothing but put a for sale sign on it, which is all that they should have done. Come to find out when they took it back inside to get it running they found a mouse nest in the air box! Yeah, that night prevent it from running right.
They cleaned the carbs(how well I don't know) and put new plugs in(?)
It may still have junk in the carbs. Who knows. I doubt they spent a lot of time with it.
My plan, if I get it, is to tear it down to bare frame and engine, give it a good cleaning, clean the carbs, new oil and filter(s), new air filter(s), check the plugs they supposedly put in, check the water pump, fuel pump and other odds and ends.
I figure I'll have it apart for a couple weeks at least. I'm kind of anal about thing like this.
2004 XR650L
bwalsh screwed with this post 02-21-2012 at 08:24 PM
Old 02-21-2012, 10:51 PM   #15
Sumi
Sumi's Avatar
Oddometer: 1,790
IDLE should be no less than 1400 rpm :) so I'd recommend turning it up a little as yours seems to idle a little low. This will also help the oil pressure to build up faster and probably eliminate the rattling sound when engine is hot. It's normal with a cold engine though. As for the 6k rpm vibes, I'd recommend a carb balance.
Times are GMT -7.   It's 07:58 AM.
