Old 05-19-2013, 11:56 AM   #166
kajj OP
kajj's Avatar
Oddometer: 192
Originally Posted by te hopo View Post
i look forward to seeing more pics and vids of this beast out on the tracks!
Here are a few pics from today`s ride.
And some action shoots at the ADVersys and the Tenere
kajj screwed with this post 01-18-2015 at 06:17 AM
kajj is offline   Reply With Quote
Old 05-19-2013, 04:38 PM   #167
Bambi
Bambi's Avatar
Oddometer: 687
Hello kajj,
looks like you've had fun!
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 05-20-2013, 11:20 PM   #168
Rich667
Rich667's Avatar
Oddometer: 177
This bike is really badass. Nice Job!
Rich667 is offline   Reply With Quote
Old 05-21-2013, 01:40 PM   #169
kwakbiker
kwakbiker's Avatar
Oddometer: 626
Great stuff, loving the build
2007 Versys
More fun being upright
kwakbiker is offline   Reply With Quote
Old 05-24-2013, 08:58 AM   #170
kajj OP
kajj's Avatar
Oddometer: 192
New air filter
Look what I got in the mail today
New air filter from Pipercross. It is much thicker then OEM filter and should offer a much better protection from dust.
I have been running two Pod filters together with the OEM for the last couple of weeks and thou it works fine (slightly different sound but no noticeable different in performance) it will be nice to give the Pipercross a try.
Will post some more pictures comparing the Pipercross to the OEM filter later tonight or maybe tomorrow.
Old 05-24-2013, 01:55 PM   #171
Honkey Cat
Tailights Fade!
Oddometer: 1,090
make me want an adventure spec versus
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 05-25-2013, 03:15 AM   #172
kajj OP
kajj's Avatar
Oddometer: 192
New filter mounted up.
Hope these make it easier to see the difference between the OEM filter and the Pipercross.
The foam edge seems to be thicker on the OEM in the second picture but they have equal thickness in reality.
The Pipercross filter is a two stage filter with the black foam as the first stage. You can see how the black foam sticks out from the filter making it thicker then stock.
I have only ridden it for a few hundred meters yet. Do not know if it only my imagination or if it`s real but it felt more alert on the throttle those few hundred meters.
Seemed to breath easier. I will take it on a longer test ride this weekend and see if there is a difference.
Also I`ll se how it copes with the dust during the summer.
kajj screwed with this post 01-18-2015 at 06:18 AM
Old 05-25-2013, 08:29 AM   #173
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,552
Cool filter I just bought one as the stocker in my case was hammered. Curious if you could take a pic and more info on your pod pre filter setup. Somehow I lost those snorkel tubes you have upfront so I need to come up with something. Thanks
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 05-25-2013, 11:58 AM   #174
kajj OP
kajj's Avatar
Oddometer: 192
I mounted the two pod filters together with the OEM as some dust got past the OEM filter.
The Pod filters are mounted to the intake rubber snorkels and acts as main filters in this case, and the OEM as the pre filter. This is not the best solution as the pod filters compress the intake rubber when tightening the clamps.
Here are some pictures showing how they mount to the intake.
Now when running the Pipercross filter I have removed the two pod filters as the Pipercross should have better dust protection.
kajj screwed with this post 01-18-2015 at 06:23 AM
Old 05-25-2013, 12:41 PM   #175
kwakbiker
kwakbiker's Avatar
Oddometer: 626
Sounds like its worth the cash over OEM, washable as well I believe
2007 Versys
Old 05-25-2013, 04:58 PM   #176
kajj OP
kajj's Avatar
Oddometer: 192
Yes the Pipercross filter is fully washable, but so is also the OEM. But should be worth the cash. Especially if you plan to ride on dusty gravel.
Old 05-26-2013, 07:21 AM   #177
kajj OP
kajj's Avatar
Oddometer: 192
Broken frame
When riding some tough single tracks today i notice that the front fairing wobbled a bit to much.
This is what I discovered!
The lower mount had cracked on both sides and the headlight, fairing etcetera was only supported by the right arm that goes from the headlight frame to the bikes main frame.
Some straps had to due as a temporary fix.
And a safety strap used when going back on the highway
Disassemble .
Close up on the damage!
right side!
Left side!
A friend of mine are going to help with the weld during the week.
Might need to fabricate some extra support for the left side of the frame.
kajj screwed with this post 01-18-2015 at 06:26 AM
Old 05-26-2013, 07:50 AM   #178
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,552
Might be a good idea to double the plates up on each side and weld those to the crossbar too. Just need longer bolts. That's a lot of weight banging around on that stock bracket
Nessmuk
Old 06-08-2013, 03:58 PM   #179
Albin
Albin's Avatar
Oddometer: 48
You better put the bike together..... 5 days to AdventureDays....
Looking forward to see you. ....and your bike....
The Albins
2014 1190 Adv R
Albin is offline   Reply With Quote
Old 06-08-2013, 10:04 PM   #180
k-moe
Oddometer: 2,588
Originally Posted by kajj View Post
That looks damn good naked.
k-moe is offline   Reply With Quote
Times are GMT -7.   It's 12:43 AM.
