Old 02-24-2012, 09:05 AM   #16
kajj OP
kajj's Avatar
Oddometer: 192
Originally Posted by Bart1 View Post
It is a few mm longer, but has more travel, the spring needs changing and the holes need boring out.
Lots of info here http://www.kawasakiversys.com/forums...ead.php?t=4958
Ok, thanks.
kajj is offline   Reply With Quote
Old 02-24-2012, 09:18 AM   #17
kajj OP
kajj's Avatar
Oddometer: 192
Originally Posted by SilentRay View Post
Well done sir. Let us know if it helps eliminate most/all the buffeting. Yes, just like the Strom, the V has it too.
Wish i had the balls/skill to tackle turning my Strom into a street fighter and lose 20-25 pounds of ugly fairing.
I haven't ridden the V with the original windscreen but with the one from Vario I can't say I notice any buffeting at all.
Old 03-24-2012, 11:01 AM   #18
kajj OP
kajj's Avatar
Oddometer: 192
First ride of the year
Got the new tire mounted up and could finally take the ADVersys for a test ride
I must say, the 19" front wheel just eats those potholes on the gravel roads.
next thing to do is to find a r1 shock and maybe tweak the front suspension.
can barely wait until tomorrow for another ride.
kajj screwed with this post 01-11-2015 at 07:26 AM Reason: Resized images
Old 03-25-2012, 10:57 AM   #19
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,555
Good job.
Murphy Slaw is online now   Reply With Quote
Old 05-14-2012, 02:46 PM   #20
aiMhi
Now with Titanium
aiMhi's Avatar
Oddometer: 686
Ha! Found you Anton and subscribed
Very creative using the plastic to close up the cowlings.
Looks like you are a hands-on guy unlike many of the others out there.
Post up a pic of what you are going to use for the headlight.
aiMhi - Honda XR650R - AMA- RMAR
aiMhi is offline   Reply With Quote
Old 05-15-2012, 09:28 AM   #21
kajj OP
kajj's Avatar
Oddometer: 192
hehe. Thanks for checking out my build.
Will posts some updates in a couple of days when I hopefully have the new rear shock back from the workshop.
I will use one of the two round lights seen above mounted on the bike. Because one of them have both high beam, low beam and parking light and are approved for street use.
But i will need one more light to use together with the high beam.
I am thinking of a LED-light, but haven`t decided which one yet. Or how and where to mount it.
Maybe you have some ideas?
The diameter of the light is 10.8cm. So a hole with 11.3-11.5cm should be enough for allow some adjustment of the light.
Maybe you could check if there is room left on the fairing for one of your LED-lights?
I now I said I would skip them for now. But if there is room to mount one on the fairing then why wait.
I saw that you have to different lights on your website. One was more expensive then the other. Whats the difference between them? Will the shipping cost increase if I add one light?
It is ok to post pictures of the fairing whit the mock up for the light (lights?) in this thread if you want to.
Old 05-15-2012, 01:06 PM   #22
kajj OP
kajj's Avatar
Oddometer: 192
Ride reports and mods update
Thought I should post some pics from some adventures with the ADVerys.
For about a month ago I did find a muddy gravel road, and also a small forest road covered with hard packed snow.
I am not that experienced in riding such a heavy bike in these conditions. And I must say, when I got to the mud (and the snow) I could really feel the weight of the bike.
Riding on the snow covered forest road was really interesting and very fun
You really need to keep your speed up and let the bike go where it wants.
Well, I tried the forest road again.
Thought that if I had a little more speed I should be able to get further before I get stuck again.
But more speed also meant more wheel spin and the rear wheel was all over the place until she got sleepy and decided to take a napp.
No harm done this time (The OEM handlebars was allready bent from a previus little chrash). The Zeta handguards did their job and absorbed the impact.
A friend of mine finally bought a bike after some time searching for one.
And the day after the purchase it was time to try here out.
So we left quite early that morning in search for some fun gravelroads.
It was so fun to ride that day. So there where not mouch time to take pictures. But I`ll manage to get a few.
Finally got the Rox risers this friday so that I could mount the new handlebars (Renthal fatbar). Wow what a difference. The standing position improved dramatically.
Some pictures from this saturday when we actually did some real offroad.
I must say, the new tires works really well. There was a lot of mud and I even got some scratches on the gravel guard when riding through some narrow puddles.
First obstacle
The conditions soon got worse, or better depending on how you look at it
we decided to turn around
I did notice the need for a gravel guard for the radiator as a rock had deformed a few cooling fins.
So I fabricated one from a cheep trashcan and some plastic "something" (a plastic grid that you put under the tires of the car when you get stuck in the winter).
It turned out pretty good.
Will post some more updates as soon I get the R1 shock mounted.
kajj screwed with this post 01-11-2015 at 08:23 AM
Old 05-15-2012, 03:19 PM   #23
aiMhi
Now with Titanium
aiMhi's Avatar
Oddometer: 686
Anton - You guys are adventurous, same out here - cant wait for the snow to clear out already!!!
Since I have your permission I will post this up here to cover your questions on your project;
Here is the mock-up adding one LED Spot light. Since your main light is round it would look out of place to add a square light and there is not enough room anyway. I sent you details on this light.
Common practice is to add two Rigid Dually lights and attach to your fork clamps on the bottom using a simple flat piece of aluminium. The different prices are for (1) and the other is for (2) lights. If you go with (2) Rigid (SPOT RIG20221 or FLOOD RIG20211) it is $189.99. These are shock proof, waterproof etc. and have themal protection and limited lifetime warranty with Rigid. The kit comes with everything you need, wiring harness, inline fuse, heavy duty mounting brackets and waterproof
aiMhi screwed with this post 05-15-2012 at 03:58 PM
Old 05-15-2012, 08:20 PM   #24
pilot
Slacker Moderator
pilot's Avatar
Oddometer: 31,495
What rear tire is that?
The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them.
-Furious D
pilot is offline   Reply With Quote
Old 05-15-2012, 11:29 PM   #25
kajj OP
kajj's Avatar
Oddometer: 192
I`ll go with the round LED spot light then. And the mock up in the first picture looks good.
If you could cut out holes for both lights that would be awsome.
Is the blue cirkel 11.5cm diameter? If it is then go for it.
I have sent you an email about the LED spot light.
Old 05-15-2012, 11:30 PM   #26
kajj OP
kajj's Avatar
Oddometer: 192
Those on the versys is the heidenau k60 scout.
Old 05-16-2012, 07:51 PM   #27
aiMhi
Now with Titanium
aiMhi's Avatar
Oddometer: 686
Kajj - Holes came out way nice. I will include the disks that came out of the holes so you can test paint on it ok.
She will be shipped out at the latest by Friday - over the big blue to Sweden
I will send you details.
Later Bern
Old 05-17-2012, 12:04 AM   #28
kajj OP
kajj's Avatar
Oddometer: 192
Wow, that looks awesome.
Can`t wait to mount it on the ADVersys.
Old 05-17-2012, 10:36 PM   #29
atravlr
atravlr's Avatar
Oddometer: 204
Great!
Keep us posted!
atravlr is offline   Reply With Quote
Old 05-17-2012, 11:07 PM   #30
rlbowers03
rlbowers03's Avatar
Oddometer: 148
I'm setting aside money waiting to see what it looks like mounted on a Versys
2008 Versys
83,500 miles and counting
rlbowers03 is offline   Reply With Quote
Times are GMT -7.   It's 07:38 AM.
