Old 05-22-2013, 09:25 AM   #91
uptwolait
Oddometer: 3
Originally Posted by Foo'bar View Post
Here you are. (reaction photos will follow later). I've put M5x30 inbus bolts instead of the M4 ones and even put some nice plastic covers over them:
I recently got an '05 R1200GS and I'm looking to add auxiliary lights. However, I am a novice regarding the wiring on this bike. Do you have any details on how you wired these LED lights into the GS system, and how you control them? I want to do something very similar to your setup.
Many thanks!
uptwolait is offline   Reply With Quote
Old 05-22-2013, 09:58 AM   #92
Foo'bar
Foo'bar's Avatar
Oddometer: 37
Many thanks!
Here you are.
I've picked the control line from inside the headlight housing. Just grab it from the high beam line (56a) by using a posi tap branch. Drill a small hole into the housing cap and lead the line outside to the switch input line.
Use a rubber seal to tighten the hole and preventing water to get into the housing.
Use a relais with diode for preventing any harm to the sensitive electronics. I've used a BOSCH one but any other with diode will work as well.
Be sure to connect relais' clamp 86 with positive line coming from switch not 85!
R1200GSA | R1100RTP | Foo'blog | Foo'rum
Foo'bar screwed with this post 05-23-2013 at 06:54 AM
Foo'bar is offline   Reply With Quote
Old 05-24-2013, 09:46 AM   #93
uptwolait
Oddometer: 3
Here you are.
Many, MANY Thanks!!!
Old 05-30-2013, 12:22 PM   #94
Hypermotard & Cecil
Oddometer: 13
I am interested in using these lights for high beams on my motorcycle(s). I am not too good with electrical installations though unless it is fairly simple. I was thinking about replacing my current headlight bulb with a xeon bulb and using it for low beam only. I would like to disconnect the headlight's high beam power lead and just run 2 wires off that to power the LED's. Then I would just run a ground to the LEDS. This way when I flip the switch to high beams the LEDS will light up, and when I flip it back to low beams they will shut off. Does this seem like an ok way to wire these lights? It seems like the simplist and most cost effective solution for an electrical noob :)
Also, would I need another mount to mount these to my forks? I plan on mounting them to a Dorsoduro but I may also mount a 2nd pair to my Ninja 500 if i like them.
Any advice is greatly appreciated. Thank you.
Hypermotard & Cecil is offline   Reply With Quote
Old 05-30-2013, 12:35 PM   #95
RDTCU
Oddometer: 2,279
It would work, but you could just connect the ground lead on the lights to the ground lead on the bulb harness.
Just make sure you wire them properly and don't let the magic blue smoke out.
As for mounting, it's up to you if you think whatever you can come up with will be sufficient.
RDTCU is offline   Reply With Quote
Old 05-31-2013, 01:03 PM   #96
Hypermotard & Cecil
Oddometer: 13
Ahh thanks, that sounds like a fairly easy procedure. I am soooo looking forward to having real high beams on my bike(s)! :)
Old 06-06-2013, 09:20 AM   #97
ternus
El Gran Camino
ternus's Avatar
Oddometer: 90
Looks like the site is down - are you still in business?
ternus is offline   Reply With Quote
Old 06-06-2013, 09:33 AM   #98
GHO100 OP
Crazy George
GHO100's Avatar
Oddometer: 1,055
Yep, we're working on it... server redirect issue
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 06-12-2013, 12:18 AM   #99
Foo'bar
Foo'bar's Avatar
Oddometer: 37
Still dead. Can I access the site by IP?
Old 06-12-2013, 05:41 PM   #100
GHO100 OP
Crazy George
GHO100's Avatar
Oddometer: 1,055
The website it back up! Sorry folks!
www.Teslaleds.com
Still shipping out the 3600 lumen lights with waterpack connectors and crash bar mounts
-George
2012 BMW R1200GS
www.TeslaLEDS.com
Old 07-30-2013, 01:31 AM   #101
Pepperjack
Oddometer: 135
Does anyone know if he ships to Australia.. I have emailed but no reply.. is the business still going and have stock etc..?
The ordering form does not have options for anywhere outside of the US :-(
e-mail : Ian@gilian.net
Mobile : 0408 52 88 00
Spot : http://ozadv.com/ian
Rides : '14 BMW R1200GSA
Pepperjack is offline   Reply With Quote
Old 08-01-2013, 02:25 PM   #102
GHO100 OP
Crazy George
GHO100's Avatar
Oddometer: 1,055
Hi Pepperjack,
sorry I haven't had a chance to get back to you. I had a motorcycle áccident recently that's put me on crutches for a few weeks, and family obligations over in Europe as well, so I'm juggling a bit.
Yes, I do ship internationally, and yes, still going strong with inventory in stock. The earliest I'll be able to ship is August 8th.
PM me here, or email to ghoverkamp@gmail.com . Not sure why I didn't get the other message.
All the best,
George
2012 BMW R1200GS
www.TeslaLEDS.com
Old 08-25-2013, 10:54 PM   #103
James Henry
Oddometer: 10
Just got my lights in the mail, I am really looking forward to them.
Thanks George
James Henry is offline   Reply With Quote
Old 08-30-2013, 02:44 AM   #104
James Henry
Oddometer: 10
I installed the lights on my daughter's Dr650 a few days ago, then had the misfortune of riding in front of her on an overcast day...the lights are IGNORANTLY bright in the mirrors. These lights are great, may be ordering a second set in the near future.
Old 08-30-2013, 05:58 AM   #105
RDTCU
Oddometer: 2,279
That's why they are more effective than a little "meep" horn, even in broad daylight.
Did she MEAN to blind you?
Times are GMT -7.   It's 03:57 PM.
