07-02-2012, 12:51 PM
#121 |
Back Home
Oddometer: 1,546
But that just changed - I've got an appointment this Thursday to get the bike tuned. Now all I have to do is get the filter installed and ride it 280 miles to the dyno
07-04-2012, 06:12 AM
#122 |
AWD please!!
Oddometer: 3,866
A Great 990 CPR filter install posted here:
http://www.advrider.com/forums/showthread.php?t=805370
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
07-05-2012, 07:21 AM
#123 |
Meshuganeh
Oddometer: 414
A few questions for CJ....
I have a 2011 990 Adv Dakar edition with a 2-into-1 Remus TI can (~3,000 miles, stock mapping). I have no issues with the FI map. Bike runs great with no hickups or blips. Gas mileage is probably around 32-35 MGP. I looked at the TuneECU site and found no tunes for the Dakar edition (stock, Remus, or CPR).
So, specific questions about the CPR filter: 1. Must the SAS be removed in order to install the filter? 2. What is the impact if the filter is used without re-mapping the FI (other than not getting the full gain in HP and Torque). In other words, will running the bike without re-mapping cause damage because the mix will be too rich/lean?
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE |
07-05-2012, 09:44 AM
#124 | |
AWD please!!
Oddometer: 3,866
1) - Yes. 2) - You would be running leaning than stock as the bike is getting much more air. Be best to richen the setup. Just b/c you are going richer does not mean you should get worse gas mileage if you keep the air mixture correct. I have gone a lot richer on our 950s and still seeing the same MPG as you with this CPR setup b/c it is getting so much more air.
07-05-2012, 10:13 AM
#125 |
Meshuganeh
Oddometer: 414
Got it. So If I remove the SAS, do I need the Solenoid Emulation Plug? Or is it enough to use the TuneECU to switch off the SAS?
07-05-2012, 10:46 AM
#126 | |
Back Home
Oddometer: 1,546
07-05-2012, 10:41 PM
#127 |
Back Home
Oddometer: 1,546
Just disable the SAS in TuneECU
08-10-2012, 08:36 AM
#128 |
Oddometer: 5
950 install
CJ,
I installed your kit on my '05 950 Adventure and everything went great, until I tried putting the seat back on. It is sitting on the rear side of filter. I did get it to close down, but it is pushing down on the filter. Has anyone else had this problem? On another note, I did jet the carbs - 170 front, 175 rear, needle 3rd position, air mixture screw 1 3/4 and it runs great. Bigmurph |
08-10-2012, 04:16 PM
#129 |
Cranky Old Fart
Oddometer: 2,324
Here's a pic showing the contact on my seat. Not enough to worry about for me.
![]() If you have more than that I suggest looking at your install.
Tom 2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC To Think is to Create!http://my2wheels.com/forum/cmps_index.php |
08-10-2012, 04:34 PM
#130 |
Lost again
Oddometer: 3,520
I have a similar contact to mine as well, 04 950.
Doesn't bother me and I seriously doubt it would be an issue with performance or function
DRCOOL rides with me |
08-27-2012, 03:38 PM
#131 |
Cranky Old Fart
Oddometer: 2,324
CJ-
What about the upgrade base plates? Should we contact you or wait for something from you? I was already looking to get the outer filter. This may be the right time for it. Tom.
08-29-2012, 04:26 PM
#132 | |
AWD please!!
Oddometer: 3,866
More info here: http://www.advrider.com/forums/showthread.php?t=821174 ..... busy doing a valve check on the 950 before I hit the road. I will be gone Sept 1- 25th. Hope to see many of you in Bend, OR. We have the outer Foam Pre-filters in stock. But we don't stock the "Replacement" Bases. If you want the Base sent to you with a new order from us I can do that, but I will need your info and add that to a filter stocking order for the shop. At this time any CJ Designs ordering customers wanting this option will need to wait until I get home unfortunately as I will need to handle this directly. Please email me by Thurs, Aug 30th, if you are interested and also send me your reciept info, or copy so that I can give that to CPR easily to get this taken care of asap. Please call me if you have any questions. I'll do what I can with the time I have left. Very sorry for any inconvenience at this time, but I need to ride too. See you on the trail.thanks, craig
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! cjracer screwed with this post 08-29-2012 at 04:44 PM |
08-29-2012, 06:17 PM
#133 |
Oddometer: 408
I contacted CPR directly about getting a map for my 990 - they let me know about the updated base plate. Sent them an email today about getting one & immediately got a paypal invoice to pay for S&H for the new plate. Seems like great customer service. I will probably buy another kit for my SE sooner or later!
2008 950 SE-R 2000 XR650R 2001 CR250R 1983 ATC200E |
10-05-2012, 08:14 PM
#134 |
AWD please!!
Oddometer: 3,866
We currently have all the CPR Filter kits and pre-filters in stock!
As are finishing up this season riding.... Leaves are falling and snow is just around the corner, I wanted to give a little feedback on this season and the CPR System on our bikes. I have over 20,000 miles on the CPR system so far. It's been great. Servicing the bike on trips and working on it in general has saved me a lot of time. After a weeks worth or dust and trails, I could pull off and install a new Filter skin by poping off the seat. Taking less than 10 min. I love it. Water has been our most asked question of concern. What I have found with camping, letting the bike sit out in storms is: With the seat on, down pours are shedded to the side by the seat and glove box. With a foam pre-filter or filter skins "oiled" this sheds at least 95% of the water off the filter when riding in the rain. I have not had any water related issues. When if comes to deep water holes.... Well take a look at this from our last trail session. The hole was a little deeper than Joe thought. Bike fired up and ran, he was a in 2nd gear getting out of the hole. Rekluse EXP worked great. http://www.youtube.com/watch?v=Q40J6...yer_detailpage At this time I am offering a "CJ Designs CPR Special" Order a CPR Filter system for any bike. 1)Get a set of CJD SAS plates for $19. 2)Get a KTM Tune ECU Cable for $45 3)Get a CPR foam pre-fiter for the standard filters for $25 4)Get a set of 3 Filter skins for the Domed filter for $15 You can add ONE, TWO, THREE or ALL of these promos to your order! And get FREE Shipping in the USA. Special rate for Outside USA. EMAIL me "craig @ cj Designs llc.com" with your ADVrider name and what parts you are interested in. NO PMs. This is through CJ Designs Direct. Have a great Fall!
02-08-2013, 02:42 PM
#135 |
AWD please!!
Oddometer: 3,866
CPR 990 Foam filter setups are on SALE! Get ready for the season with all the parts you need from one shop.
Save $20! http://www.cjdesignsllc.com/about-us...c8-filter-kit/
