03-01-2012, 07:23 PM
#16 | |
iRoast Coffee
Oddometer: 1,216
![]() Quote:
"Don't threaten me with a dead fish" 07 Bonnie T100 Gonzo- 08 Ural G/U, 77 R100S, 01 Bonnie, 2x KLR's, Wee, Ninja's, CBR's, yadda yadda... |
03-01-2012, 08:24 PM
#17 | |
Oddometer: 341
03-02-2012, 04:20 AM
#18 |
MORE COWBELL!!!
I'll be away this weekend but we're spending at lot of time at Hopkins. If you're around next weekend, I'd like to swing by to check it out. if you're up to it....
Breathe, keep breathing, I can't do this alone |
03-02-2012, 05:18 AM
#19 | |
Mobtown Hacker
Oddometer: 734
The ladies used to check me out...now they just keep an eye on me. MotoJ screwed with this post 03-02-2012 at 07:33 AM |
03-02-2012, 05:20 AM
#20 |
Mobtown Hacker
Oddometer: 734
Sure! Send me a PM and we'll hook up. I'm not too hard to find from Hopkins......
The ladies used to check me out...now they just keep an eye on me. |
03-04-2012, 06:38 AM
#21 |
Oddometer: 33
M72 restore
Oppozit,
Depending on your level of commitment to originality, I can give you a couple of bits of information. Carbs..probably are 26mm. If you can find old Bings, you are lucky. 26mm carbs are not easy to find for these things, but 28's can be made to work ok. You can get "new" carbs for a Chang flathead that will work quite well. You may have to play with jetting, though. You can get three ring pistons (don't bother with original style four ring pistons) from Chang suppliers quite reasonably. The quality will be as good or better than the Russian stuff. Don't believe what you read for piston/cylinder wall clearance. Most sources will say .003". That clearance is for a solo. For sidecar use, go to .006" clearance. If you want to talk to someone who knows how to make the old flatheads run well, contact Chris Jordan at immulmen AT yahoo DOT com. He has a flathead Chang rig that will go 60mph all day long without overheating. He will be happy to help you. Mike Lydon |
03-04-2012, 10:42 AM
#22 | |
Mobtown Hacker
Oddometer: 734
I'm not too interested in originality- I'm trying to build a daily runner. I'm going to keep the crappy Lithuanian paint job and the KMZ mufflers and kneepads. Budget is a concern, so I'm trying to keep to only the necessities. I've been corresponding with Immulman through posts on the RI Forums. He actually gave me a steering damper wingnut rod free! It will probably be the nicest part on the bike. Very nice guy and very knowledgeable!
03-04-2012, 08:21 PM
#23 |
Oddometer: 341
03-04-2012, 08:51 PM
#24 |
Oddometer: 378
I'm liking this thread!
03-05-2012, 12:02 PM
#25 |
Mobtown Hacker
Oddometer: 734
Time to start the tear down...
I was hoping that this bike would be a case of give it a good scrub, new battery, clean the carbs, replace the fluids, etc. but that was not to be. Everywhere I looked was more grime and corrosion, and although the bike would turn over with the plugs out i couldn't get it to stay in any gear, and the kickstarter quit after a couple pokes. The rings made a pop when they broke loose of the rust in the left bore.
I got the bike hoisted up by a come-along suspended from a ceiling beam. My neighbor made a comment that this reminded him of the famous photo of Ed Gein's barn. Yeesh. ![]() I figured i'd start by draining the oil. None at all.
The ladies used to check me out...now they just keep an eye on me. MotoJ screwed with this post 03-05-2012 at 12:14 PM |
03-05-2012, 12:59 PM
#26 | |
Khan!
Oddometer: 1,011
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // BMW R1200GS 30th
03-05-2012, 03:07 PM
#27 |
Oddometer: 381
At the risk of tempering your gusto with cynicism.... ;P
Does it have to be an accurate restoration? From the sound of things, I think I might be inclined to send that engine to the scrapper and put in whatever shaft drive donorcycle engine happens to be available on Craigslist instead. I'd bet you a dollar the compression on that cylinder that was stuck is going to be unacceptable. I mean, /if/ you get that motor running, are you going to be able to find parts in a timely fashion the next time it breaks down? I've heard that none of those russian flatheads except the contemporary Urals are very reliable....... Don't get me wrong. I'm not trying to be critical or anything. Just kinda sipping a beer and making uneducated observations from the peanut gallery. ;3 I've always hoped to find a broken down 650 Ural or 'Neepr somewhere for cheap, to put a CX500/650 powerplant into. :P |
03-05-2012, 04:43 PM
#28 | |
Mobtown Hacker
Oddometer: 734
Like I said, I'm trying to just build a reliable runner. I'm not going to worry about a restoration, period details, OEM parts, and the like. This is more of a "refurb". Parts are actually pretty readily available (but won't be forever) from a few places in Europe, and Chiang Jiang 6 volt models were licensed from the Soviets and many of those parts are interchangeable with the Soviet M72, and still available. From folks I've been corresponding with who own these old flatheads, I hear the quality is many times actually better than the later 650 overhead valve jobs. They aren't fast, but they're built to withstand a lot of punishment and be fixed by uneducated peasant soldiers with the factory tool kit and a big rock. Think tractor instead of performance motorcycle. Stalin was still alive until '53 and his old guard was still running things for awhile after his death, so no worker wanted to be known as an "enemy of the people" or whatever. The Cold War was making people patriotic still and the disincentives of Communism weren't so apparent that the workers didn't give a shit yet. That's what some folks speculate anyway. I mentioned earlier that this project is underway a couple months now, but I've only just started the thread. I'm going to post up the pics I have and get things up to the present... So, I'm using the flathead motor for now, but nothing saying an R60 airhead motor won't find its way in there someday!
The ladies used to check me out...now they just keep an eye on me. MotoJ screwed with this post 03-05-2012 at 04:52 PM |
03-05-2012, 04:53 PM
#29 |
Mobtown Hacker
Oddometer: 734
Ha! Well I haven't cursed you yet- I'm still having fun. We'll see how that goes....
03-05-2012, 05:16 PM
#30 |
Que la Chinga?!
Oddometer: 3,140
This is great stuff!!!!
![]() Thanks for your posts! I'll be watching......
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over |
