09-03-2012, 10:10 AM
#136 |
Oddometer: 114
A very useful thread, thanks to all the contributors. Having a blast on my new 990 Adv R. Due to the down low location of the battery, looking for advice and suggestions on setting up/cable routing for using Battery Tender. I've always plugged my bikes in at the end of the day.
09-03-2012, 10:52 AM
#137 | |
lost in hood river
Oddometer: 1,145
2011 Dakar 30th Ann. 990 Never, ever, be in the wrong place at the wrong time findLadukebob |
09-03-2012, 12:23 PM
#138 | |
Oddometer: 119
ad astra per alia porci
09-04-2012, 12:40 PM
#139 | ||
Oddometer: 114
Chargers
09-04-2012, 12:57 PM
#140 |
Skiing, not riding.
Oddometer: 5,025
I used to deal with battery tenders all the time...
Recently put a Shorai battery in my 950. HIGHLY recommended! Spin's fast, very slow self-discharge, prices have come down quite a bit. I know they have been discussed elsewhere, but thought it was worth mentioning again with the charger discussion. I have had good luck with a couple of batteries from Shorai, but I think most of the other Lithium iron phosphate (LiFePo4) battery offerings are also quite good!
950 Adventure ✧ 950 Super Enduro ✧ 450 XC-W Six Days |
09-04-2012, 04:29 PM
#141 |
lost in hood river
Oddometer: 1,145
Bought a 12v plug at NAPA and spiced it into one end and the other end has the same plugs as the Battery Tender. They are also the same ends as my small air compressor, so the 12v plug works for both the tender and the compressor. The Tender also comes with clips in case you want to hook onto battery terminals.
09-04-2012, 04:54 PM
#142 |
Back Home
Oddometer: 1,545
Once I installed the Blackdog skid plate I was able to just hook up a standard Battery Tender cable.
09-04-2012, 05:48 PM
#143 |
Oddometer: 114
Easy...
Nothing like keeping it simple moto-treks. Cool thing is I just ordered a BDCW skid plate this am. Although, I can see having a plug in for convenience too.
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, totally worn out and screaming "WOO-HOO, what a ride!!" |
09-04-2012, 06:23 PM
#144 | |
Back Home
Oddometer: 1,545
moto-treks screwed with this post 09-05-2012 at 02:28 PM |
09-04-2012, 09:09 PM
#145 |
on an endless build
Oddometer: 1,210
Cool thread.
On the oil filter front - CJRacer's clutch window cover. I appreciate the paper filter idea but I never seem to have them or plan ahead and order them when I should so I like to use Scotts filters and have for years. CJ's cover is bling but I find that I use it more frequently to assess the condition of the oil and it's nice to see it at the level of the window (understanding it's a dry sump bike and the tank could be low still.) I once flooded the bike and knew from the window that my engine was filled with water. Spare Keys: I always keep a spare key zip tied to the frame (hidden of course) on long trips and another in my luggage. Best 950/990 Party Trick: Has your battery died and you don't relish the idea of laying on your back to undo the skid plate to get to the battery? If you're traveling with another 950/990 owner put both bikes on the center stands with the rear wheels touching and use the running bike to spin the bejezus out of the other bike. Dead bike in second, running bike in second or first. Can't say why I like this so much but I really do. It feels like cheating. I'm sure I'll think of more... Gregor
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks |
09-04-2012, 10:49 PM
#146 |
Oddometer: 119
Great thread! Thanks guys. +1 subscribed.
09-08-2012, 02:39 PM
#147 | |
Oddometer: 1,076
Proud to be supporting Pyndon ![]() ![]() ![]() ![]() www.lyndonposkittracing.com ![]() ![]() ![]() ![]() www.bikersjersey.com for all your KTM parts A 2,400 KM ride around Egypt by Scooter - ride report here |
09-16-2012, 07:09 PM
#148 |
Oddometer: 114
Shift Lever Problem /Question?
Pilfered diagram below from another thread. Was out today, 3rd time on my new 2012 990 ADV R, having a blast practicing/playing in the dirt. Went to downshift and the shift lever while initially engaging and completing the gear change continued to rotate down way past normal. Stopped bike to check out. The lever would now rotate all the way up and/or down way past normal range. Only thing stopping it is contact with some other part. Not a free swing, it will stay wherever you stop rotating it but still it would move to the extreme ends way beyond normal range and no longer engages the gears. So ok, must have come loose - right, and slipped off the splines/teeth of the shaft. I tried to tighten the nut (#19), it was pretty tight already and I didn't want to over torque and break it, but the little bit of tightening I did made no difference. Other problem, after removing bolt #19 and washers #17 & 18, I am unable to remove the lever, I've pried it, tapped it, but no in or out movement, I cannot slide it any further off or on, although it still rotates as described above. I'm thinking it was lose or loosened while riding and slid of the teeth a little and is no longer engaging the teeth on the shift shaft (say that 5 times fast). The space between the back (engine) side of the lever (13) and washer(?) #12 is ~ 3/8 to 1/2 inch, should it be closer or flush? Is it a tapered shaft? WTF? I am under warranty, it's new but it's also a 75 mile trailer trip to take the bike in, so....any ideas or suggestions from those of you experienced with the 990 would be greatly appreciated.
09-17-2012, 10:04 AM
#149 | |
I SAID! Woo Hoo!
Oddometer: 914
You might want to put your question in it's own thread in the OC forum. This thread is more for what new owners need to know about the 950/990, not to ask questions.
09-17-2012, 10:29 AM
#150 | |
Oddometer: 114
I hear ya.
I would say though that questions are valid here, if related to a 'legit' post.. Agreed this one doesn't purely fit that criteria. Do I need to rewrite and post or is there a way to move my existing post to start a new OC thread or add to an existing thread other than this one? ![]() Moved to new thread: http://www.advrider.com/forums/showthread.php?t=826991
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, totally worn out and screaming "WOO-HOO, what a ride!!" elron screwed with this post 09-17-2012 at 01:41 PM Reason: moved to new thread |
