04-23-2012, 06:20 PM
#106 |
Unbunch yer panties!
Oddometer: 1,103
Stock 2010 is 16/42.
16/45 is the sweet spot for me... Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
04-23-2012, 06:56 PM
#107 |
Oddometer: 35
I think it is 17/42 rather than 16/42, but I can't find it in the manual to back that up. I think a popular change is to go 16/45.
04-23-2012, 06:59 PM
#108 |
Oddometer: 220
Front brake lines rubbing on inside of forks
Wrap your front brake lines with electrical tape where they contact the inside of the fork, as the cables will constantly free themselves from the lower fender guides, and as a result rub on the forks. This can lead to the outer (black plastic) jacket wearing away, exposing the braided lines beneath, as well as eroding the finish on the forks ! |
04-24-2012, 07:32 AM
#109 | |
Trail Jester
Oddometer: 1,006
I can see myself riding woods roads (jeep roads), logging roads and maybe some double track trail. But, I do not intend to ride this bike like an "overgrown enduro" ... I have my berg and a new KTM 350 exc-f for those days.
'11 Husaberg FE570S '12 KTM 990 '13 Husaberg FE350 Berkshire Trail Riders on Facebook or follow me on Twitter |
04-24-2012, 09:15 AM
#110 | |
Oddometer: 1,103
P. 198, 2010 Adventure Manual: Secondary drive ratio 16:42 Fetch me a sammitch.... S Edit: OK, that was harsh. Here's a smilie.... ....and I need a beer..... ![]()
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. Alleycatdad screwed with this post 04-24-2012 at 09:28 AM |
04-24-2012, 09:25 AM
#111 | |
Needs to ride!
Oddometer: 2,065
Sammitch!16/45 is what I run all the time now (on the suggestion of many OCers here), even with the 19/17 street wheels. Yeah, it is a bit low for the hwy, but wheelies are fun!
WHHHAAAAT!?!?! ![]() 5 Star RR: VIOLA-TING AMERICA - Chasing the dream of music and motos |
04-24-2012, 08:45 PM
#112 |
Oddometer: 35
Yeah, I found it after I posted, but didn't bother to go back and correct my post since someone else had posted correctly. Thanks for clearing it up! What kind of beer?
04-25-2012, 06:14 AM
#113 | |
Oddometer: 1,103
You'll do...welcome to the asylum. ![]() S
04-25-2012, 03:44 PM
#114 |
Skiing, not riding.
Oddometer: 5,022
Exhaust:
The stock exhausts are freakin' heavy! I prefer to dump them in the trash and replace them with your choice of can's. The FMF Q4's are a good reasonably priced option. ![]() Some people have had good results with 'de-catting' the stock pipes (cutting/smashing out the heavy catalyst inside the pipe), but not my preference. Another option is to use Ned's Two-into-one pipe and just run a single aftermarket can.
950 Adventure ✧ 950 Super Enduro ✧ 450 XC-W Six Days |
04-25-2012, 03:57 PM
#115 |
Skiing, not riding.
Oddometer: 5,022
Mirrors:
If you stick to the street and easy dirt roads, OR if you never dump your bike ( ), the stock mirrors are fine.Otherwise they snap off easily when you crash, sometimes taking the master cylinder mounting boss with it. If you want to ride the 950 where it was intended, replace the mirrors. My choice is Ned's doubletake mirror. . Tuck them down when off road, up for on road. ![]() Highway Dirt Bikes also makes a cool mirror, integrated into the HDB hand guards.
04-25-2012, 04:13 PM
#116 |
Addlepated
Oddometer: 2,058
FYYFF! http://www.youtube.com/watch?v=NtpUv4VBDhA Bikes 2012 BMW K13S | 2009 KTM 990 Adventure (SOLD!) | 2003 Suzuki DRZ400E |
04-26-2012, 07:23 AM
#117 | |
Green Cantern
Oddometer: 6,499
![]() Second, I purchases a new FMF pipe for another bike I had and wasn't happy with several things. 1st was the fit. One of the mounting holes was about 1/2" off and I couldn't use it. The pipe was secure enough with the clamp connection and the rear mounting hole, so that wasn't a huge deal. Another issue was that the pipes exit tip was too close to the stock blinker location and burned off the bottom portion of it. Other issues were - the pipe (on a 250cc bike) was MUCH louder than the FMF that came on my '08 450xcr-w and the finish on the pipe changed over time by fading and forming spider cracks. I had to install a smaller tip to reduce the noise to a reasonable level. Here's a picture of the fit issue and damaged blinker. I put some aluminum tape over the burnt portion, but it didn't last long. ![]() ![]() I documented everything and tried getting some resolution from FMF but they wouldn't do anything. By the time I realized there was an issue with the blinker, it was too late to return. My point is, the FMF pipes are a lot of money and I think there are better pipes out there. I personally won't be purchasing any more pipes from FMF.
950/990 CRASH BAR BAGS, FENDER BAGS, and more. Made with pride. Pachaug Map '08 KTM 450 xcr-w, '10 KTM 990 Adventure '85 Honda CR500 NETRA #24519 |
04-26-2012, 09:05 AM
#118 | |
Getting a grip...
Oddometer: 1,604
The simple facts of the matter are that Rome fell for at least four reasons: A decline in moral values and political civility at home; an overconfident and overextended military; fiscal irresponsibility by the central government; and an inability to control one’s borders. Sound familiar? |
04-26-2012, 03:57 PM
#119 |
Oddometer: 153
For those not familiar with dirt-bikes, the big KTM needs to have it's forks bled. There is a small phillips head screw in front of the rebound adjustment, after a day off road, put the bike on the center stand then loosen the screw until the air pressure bleeds off then put it back in. Don't over-tighten, it's soft!
If when checking your oil you are consistently getting over-full readings even though when the oil is removed it measures correct, a possible cause is a stuck crankcase breather check valve causing over pressurization of the oil tank. Remove, disassemble and clean. Or just remove. Find something coarse to replace the ball and spring that will allow air to flow but will cause oil to hang up and not make it's way to the air filter (roof/ridge vent worked for me). Edit - roof/ridge vent might not be such a good idea, after some time it seems to have "loosened" and I found a few "hairs" of plastic in my oil screen. I have since removed it and have nothing in line for the crankcase breather. Bikes from 09' and up came geared 16/42. 08' and down 17/42. Now who owes me a sammich? The OC is great, it was the driving force in my signing up for advrider. I never posted in forums before here. Thanks to all! MrLebowski screwed with this post 09-04-2012 at 09:52 AM |
04-26-2012, 05:05 PM
#120 | |
ow, my balls!
Oddometer: 4,603
I hook it up to TuneECU for adjusting the throttle cables. Its something I do because of my past experience of blindly dicking with them. Its an injected V-twin with ECU/stepper motor controlled secondary butterflies in the throttle bodies, and a mis-adjusted cable will affect those. Its not an FCR fed thumper. Naturally you can adjust them as you see fit, without a computer, its your bike. But afterwards you could be searching the "my bike is stalling" threads.
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ crashmaster screwed with this post 04-26-2012 at 05:17 PM |
