Old 03-06-2012, 06:16 PM   #16
KYwoodsrider
KYwoodsrider's Avatar
Oddometer: 241
[QUOTE=MacG;18146896]Thanks for the kind words
That dash is 3 pieces welded together(two sides,one top) ,but could be made using bolts.
Here are pics of a simple one piece I made for a buddy to try a short windscreen on his 07. The dash was simple,just two 90 deg. bends,it just wasn't as wide as the one seen on mine. Without the windscreen,the 4 bolt heads you see would be gone.On this one I was trying out the windscreen,the dash was just an easy way to mount it. The windscreen didn't do much and he sold the DR shortly after so the project didn't go any further.
I bought your buddies DR and I liked the way you made the dash. I finished it out by:
* relocating the indicator lights
* adding the side mounts to the Cycra hand guards
* making a cover plate over the handle bar clamps for my heated grip controller
* made a larger wind screen out of 1/8 Lexan
* added some cheap imitation carbon graphite tape
I would still like to add a 12V outlet, Low beam switch, and some type of digital clock. I also need to drill/tap the handle bar plate and get rid of the wire ties
KYwoodsrider is offline   Reply With Quote
Old 03-06-2012, 06:21 PM   #17
MacG OP
MacG's Avatar
Oddometer: 256
[QUOTE=KYwoodsrider;18154637]
You got nice bike ! I just did the dash while I was experimenting,you have a nicer windshield on now. The dash looks good with the carbon fiber on there.
09 KLR
97 DR650
MacG is offline   Reply With Quote
Old 03-06-2012, 06:22 PM   #18
MacG OP
MacG's Avatar
Oddometer: 256
Tool tube
I replaced the OEM tool box with a tube from Agri Supply. I made a simple bracket from 1" angle and attached the tube with hose clamps.
Redneck fork protectors. I keep about 3 or 4 layers of Gorilla tape strips on my forks. If I need tape to repair broken plastics,tail lights, etc., I just pull a strip from the fork.
09 KLR
97 DR650
Old 03-07-2012, 06:05 PM   #19
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,429
Mac Dash ...
Hey KYw.....
I really like the "Mac Dash" ... since you have one on a newer DR with the updated headlight schroud ... curious to what it looks like from the front since the dash pushes the schroud out a bit.
Do you have any pictures from a front angle ??
Thanks ..
Originally Posted by KYwoodsrider View Post
Honda
GsVs is offline   Reply With Quote
Old 03-07-2012, 08:35 PM   #20
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Did you do the welding on the Mid pipe? And you also made the tool tube brakcet and Dash?
The Mid Pipe welds look to be done by someone who works at GE welding Turbine blades into 747 motors. Space Shuttle quality.
The brackets? looks like my Jr. high school metal shop project!
Old 03-07-2012, 09:10 PM   #21
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Sweet, I've got one of the Agri Supply tubes but haven't tried to mount it yet
That bracket looks like something even I could fab!
Thanks for sharing!
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 03-08-2012, 02:24 PM   #22
MacG OP
MacG's Avatar
Oddometer: 256
I did all of the work myself. I am primarily a machinist,the welding is more of a necessary hobby that helps when I am building things. I really do like to TIG weld though.
Yeah,the bracket is very simple. A hand drill and a hacksaw will do it.
09 KLR
97 DR650
Old 03-09-2012, 08:44 AM   #23
riding machine gene
Oddometer: 6
Good job!
riding machine gene is offline   Reply With Quote
Old 03-09-2012, 09:28 AM   #24
Utah Bones
Gas X ready!
Utah Bones's Avatar
Oddometer: 1,607
This new light was a great addition worth every penny.
Lefthand brew, a weber grill and the rocky mountains,...it all goes away!
Utah Bones is offline   Reply With Quote
Old 11-16-2013, 11:06 AM   #25
Jbw5062
Jbw5062's Avatar
Oddometer: 17
frame paint
I know this is an old thread, but I was wondering how you did the paint job on the frame? Did you take it apart or just tape off everything? Also how did you do the sanding/prep work in the tight areas?
Jbw5062 is offline   Reply With Quote
Old 11-17-2013, 04:06 AM   #26
MacG OP
MacG's Avatar
Oddometer: 256
I took off items that were fairly simple and taped off the rest. For the prep work I cleaned the bike really well with a pressure washer. I removed everything that was simple to get out of the way,taped off the rest. Sanding was done with coarse or medium scotchbrite. The tight spots were done by holding a small piece of scotchbrite in hemostats. It's been quite a while since I painted the frame and it has held up very well. :
09 KLR
97 DR650
Old 02-01-2014, 03:40 PM   #27
clintonroy
Location: Timmins ON-The land of 2 seasons RAINY & SNOWY
Oddometer: 76
Just have to say beautiful fabrication work! I wish I had that kind of skill.
clintonroy is offline   Reply With Quote
Old 02-02-2014, 03:15 AM   #28
MacG OP
MacG's Avatar
Oddometer: 256
09 KLR
97 DR650
Old 02-02-2014, 03:35 AM   #29
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,068
Awesome bike! Gives me some ideas.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 02-02-2014, 11:04 AM   #30
motolab
motolab's Avatar
Oddometer: 2,852
I didn't have a bender for the exhaust so I took a 90 deg. elbow and a few pieces of straight tube. It took a while to get the angles cut correctly but it worked out OK. I welded a support from the tube to the OEM mounting point for more rigidity.
It's probably not the best idea to cheat a bend (i.e. not to have the centerlines tangent) like that.
Regards,
Derek
motolab is offline   Reply With Quote
Times are GMT -7.   It's 04:30 AM.
