Old 03-11-2012, 02:22 PM   #31
bobobob
badbadbad
bobobob's Avatar
Oddometer: 5,466
Originally Posted by GB View Post
No drifting sideways for me.. It's no more weight than a topcase mounted there, and the weight of the fuel is gone after 100 miles. For commuting, this is working out well. IMO this is the best location that does not compromise luggage capacity for long distance riding and still gives a 500+ km range. If you want to have your cake and eat it too, this is it A side mounted tank precludes mounting panniers. And Touratech is too expen$ive for me, and quite a labor intensive installation and removal. You can be sure the dealer will charge extra for labor to remove and reinstall the tank at valve checks.. It just depends on what you want to do with the bike. This tank fits my needs and I'm delighted that I did not have to bang my head against the wall when installing it. When traveling, the case comes off and a dry bag or Motofizz will go on the seat.
I was asked to show the mounting plate for the topcase:
I wonder if a Givi plate would fit on there to mount a E55 TECH?
bobobob is offline   Reply With Quote
Old 03-12-2012, 12:32 PM   #32
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,373
I wondered that too. You will soon have your answer! I have a universal (flat) Givi plate coming. I know it's too big to fit, but I have an idea or two on how to support the back end of the case. I'm sure it won't be pretty, but it's all about function, not form. Stay tuned.
Old 03-13-2012, 05:51 AM   #33
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
Well I got my package today down here in Oz and it all looks the goods.
Firstly the front bolts where very hard to get in and as others have mentioned they bottom out early. I used some spacers as others have. When mounting the top plate I too had trouble getting the M8 bolts to reach the rear adaptors but with a bit of a push i managed to make it happen. The front bolts though bottom out by approx 2mm before the luggage plate is tight. Anybody else had this problem.
Looks like I will be buying slightly longer M8 bolts for the rear and slightly shorter ones for the front.
I think its a great product but these little issues should not be happening.
Riding
BMW F800GS
OZZY-GS is offline   Reply With Quote
Old 03-13-2012, 10:26 AM   #34
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Considering purchasing~hopefully these minor issues get sorted out.
Please keep up the reviews and photos guys!
modeselector is offline   Reply With Quote
Old 03-13-2012, 01:18 PM   #35
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,373
Btw, I would highly recommend you use anti-seize compound on the threads of the bolts/spacers that mount into the bike's frame.
When I removed the 4 bolts that held my Givi topcase rack on my 8GS, the bolts had signs of corrosion on them, mind you they weren't stainless bolts, but to be on the safe side, I coated the bolts for the adv tank with anti-seize paste.
I'm going to say the rear bolts that screw thru the 2 rubber spacers need to be about 5 mm longer, and the front ones could benefit from spacers between the threads and the long spacer, otherwise the setup is perfect. I'm going to pass this onto the good people at advtank.
Old 03-13-2012, 08:47 PM   #36
FORE!
pretender
FORE!'s Avatar
Oddometer: 51
Hey guys! Thanks so much for your comments here about the tank! Even though we have put this tank thru some serious testing, there is always a possibility that something will pop up that we did not anticipate. This proving process will help us refine the product to its perfect intended use. Be sure that any improvements we make will be made available free of charge to those who have already purchased the tank. Know that this tank is not for everyone, but we see some exceptional uses for it. I come from a racing background and having a tank in this location, that drains first (rather than holding the fuel until you stop, unbolt something, pour it into your stock tank, spill some, bolt everything back together, etc) provides the optimal scenario for expanding our range/route options. I've seen many other companies put together a rack/plate system in the back and ask more than 50% of what the price of this tank AND plate retails for.
We have already sourced longer bolts for the rear mounts, and will be sending a set out to those who have already purchased the tank. These bolts are A-2 grade stainless steel, so rust & corrosion on them should not be an issue. Additionally, after reviewing this thread and others, se have seen some additional mounting uses. We will be including a set of spacers for the front mounts that allow you to use aftermarket grab handles. Again, a set of these spacers will be sent to those who already have the tank.
If you have any other questions or comments about the tank, feel free to post them here or PM me and I will answer promptly (assuming I'm not out riding ).
Scott
AdvTank
FORE! is offline   Reply With Quote
Old 03-14-2012, 01:10 PM   #37
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,702
Scott
AdvTank
Customer service in a nutshell.
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 03-14-2012, 05:04 PM   #38
bobobob
badbadbad
bobobob's Avatar
Oddometer: 5,466
+1
BMW could learn a lesson here about how it should be done.
Btw, any chance of Givi plate adapter? Thanks.
Old 03-14-2012, 05:21 PM   #39
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,373
Scott is a stand up guy. I contacted him and he was on it right away. This is a totally minor issue, as you can see, the tank is on the bike and functioning correctly.
Originally Posted by bobobob View Post
+1
Still waiting for the Givi plate to arrive.. I bought a used one in the flea market and it's coming in the mail... hopefully before summer
Old 03-14-2012, 08:07 PM   #40
jttele
jttele's Avatar
Oddometer: 253
I agree with GB, I love the way the tank works, I've gone thru one tankful so far and it works just as expected. The fitting issues I ran into were minor, and it's great that they are working on addressing those issues so quickly. Not that I think they should mark the price up, but I'd have gladly paid about $100 more for what it is. Couldn't be happier!
Jttele
jttele is offline   Reply With Quote
Old 03-14-2012, 09:09 PM   #41
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
Scott
AdvTank
Cheers Scott,
Great service Mate. I have fitted mine and couldn't be happier. Look forward to getting the new bolts and spacers.
Thanks again for following this up. It doesn't happen often enough.
Riding
BMW F800GS
Old 03-14-2012, 09:28 PM   #42
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
so..... should I buy this tank and have ourselves our own 10G+ thread?
http://advrider.com/forums/showthread.php?t=767390
We would still get twice the mileage right?
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 03-15-2012, 02:26 PM   #43
Happycamper
Have bikes, will travel
Happycamper's Avatar
Oddometer: 624
Paging FORE!
You have a PM regarding issues my dealer is having with the install.
Happycamper
2009 F800GS
2014 KTM 690 Enduro R
Happycamper is offline   Reply With Quote
Old 03-15-2012, 04:21 PM   #44
Happycamper
Oddometer: 624
Thumb Thanks FORE!
Scott responded promptly to my issue. Another + for their customer service
Happycamper
2009 F800GS
Old 03-15-2012, 07:00 PM   #45
scarygary
Drawing blanks
scarygary's Avatar
Oddometer: 379
this thread is seriously lacking photos. Let's see the whole bike from the side.
scarygary is offline   Reply With Quote
Times are GMT -7.   It's 04:42 AM.
