Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 05-10-2012, 10:03 AM   #241
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Originally Posted by wakewop View Post
You got it thump. You will hear the rev if there is a leak. Vrooooom.
Thanks.. I originally had the concept confused. Thought the point of using the liquid was to temporarily plug the leak.
Originally Posted by toddler View Post
I'm sure their are, but I just do a visual and light press. There should be 0 open space when they are closed. Backflow is bad as it takes away crankcase goodies from the combustion chamber.
If the bike is hard to start I would put more suspicion in the reeds, but you have not mentioned that.
That's how I checked.. pressed gently on each, then held it up to a light to look for leaks.
The bike was very hard startng when hot and lean, but that went away when I moved to the richer needle clip.
Ride
AMA | COHVCO | Stay The Trail | BRC | TPA | BCTR | NCTR
thump_co is offline   Reply With Quote
Old 05-10-2012, 05:43 PM   #242
James Adams
A few crayons short.
James Adams's Avatar
Oddometer: 10,219
The impeller upgrade did very little for my hot running bike. I also fought the jetting for an entire summer. This was in a bike that had 0 problems before. I finally gave up and sent the carb to Dave Hopkins in Washington (Ktm talk guru) and had him give it the royall treatment. Full ultrasonic cleaning , jetting and a custom tapered needle. Accelerator pump all tweaked up , squirt duration, and several o rings replaced. Set float height. Basically completely serviced all parts of my carb. Had 2 cracked o rings that I did not know even existed in the carb. Cost was $ 160 and the bike ran amazing after. Temps were never again a problem. Every bit of bog was gone.
...and it's still running great. I make sure to give it plenty of exercise.
Sorry for the interruption; back to 2-smoke talk...
505 XC-F DUKE 690
James Adams is offline   Reply With Quote
Old 05-10-2012, 08:26 PM   #243
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Progress?
Well... sprayed down everything looking for leaks today... no Vroooooms from anything, but did find a way to consistently kill it.
Strangely enough, the WD-40 has no effect, but hitting it with Carb, Contact or Brake cleaner will stall it right out.
The only real difference I can think of is that the WD40 comes out room temp, whereas the cleaners feel cold. Think it's a leak? it only happens by spraying around that particular bolt, not the head/cylinder seal or the plug.
Ride
Old 05-10-2012, 09:41 PM   #244
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,577
That is bizarre.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 05-10-2012, 10:42 PM   #245
silverboy
Bunny
silverboy's Avatar
Oddometer: 544
Cry
Maybe its from that buzzing noise? Oh, it's a 2stroke, that's normal I guess? The solution is sitting alone in your garage feeling neglected, wondering what it did wrong....
Racing is life. Anything before or after is just waiting.
Steve Mcqueen
silverboy is offline   Reply With Quote
Old 05-10-2012, 10:50 PM   #246
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Keep gettin' lippy and I'll send someone around to take out a kneecap.
Oh, wait...
Ride
Old 05-10-2012, 10:52 PM   #247
wakewop
Hucker
Oddometer: 793
OUTSTANDING!!!!
. All I can say is DAMN I MISS THAT SEAT.!!!!!
Was the 1st thing I ordered after riding my new bike for 50 miles of trails.
wakewop is offline   Reply With Quote
Old 05-10-2012, 10:55 PM   #248
wakewop
Hucker
Oddometer: 793
Back to the 2 stroke, I am now at a complete loss. Try this. Spray the carb cleaner or contact cleaner around the air box boot where it meets the carb.. Do the same where on the other boot where it leaves the carb. See if your engine responds to that. Im not pulling this out of my butt, these are all tests that Dave Hopkins had me do before I sent him my carb.
Old 05-10-2012, 11:25 PM   #249
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Ooooh.. plot thickens (thins?).. This pic is from when I pulled the head a few weeks ago. The arrow is pointing to the bolt hole that I'm spraying in the video above. I'm assuming the dark discoloration is from combustion gasses? Thinkin' maybe the stud hole right next to the bolt hole is a little too shallow and the stud post is keeping the head from getting a tight seal on the inner o-ring?
Thinking either file down the post, or bore out the hole a little further?
Ride
Old 05-10-2012, 11:37 PM   #250
wakewop
Hucker
Oddometer: 793
Hummmmmmm. Could be a slightly stretched bolt. I would get a new one so you don't risk buggering up the threads on the case.
Old 05-11-2012, 12:50 AM   #251
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,224
I had one of the head bolts stretch, ended up replacing them all. I'd be surprised if that was the "air leak". Combustion leaks don't typically cause a lean symptom.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-11-2012, 08:06 AM   #252
TooFast
TooFast's Avatar
Oddometer: 1,282
May want to check your head with a straight edge and flashlight, I usually true my heads on a surface plate with fine grit paper to ensure flatness for a good seal. Have seen cylinder tops not flat also.
TooFast is offline   Reply With Quote
Old 05-11-2012, 10:24 AM   #253
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Alright.. going to order new head bolts and washers. I'll check the head edge as well. Maybe order a Slaven's "mule" head.. anyone tried those?
RF - wouldn't this leak also have to be "sucking in" for the spray to be able to kill it like it does?
Ride
Old 05-11-2012, 12:27 PM   #254
silverboy
Bunny
silverboy's Avatar
Oddometer: 544
Is this the bike that did Baja 1000 solo? Did it suck in a bunch of sand?
I'm thinking it may have been run hard and put away wet or in this case put away dry....
Steve Mcqueen
Old 05-11-2012, 01:11 PM   #255
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,577
Wouldn't that be in the intake stroke?
Times are GMT -7.   It's 01:51 AM.
