Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 01-27-2013, 07:08 PM   #421
Wannabeeuro
Tuner chic
Wannabeeuro's Avatar
Oddometer: 1,979
Upside down, like maybe off the sweet kicker (840) for busting a Knack-Knack superman backflip.
"Build a man a fire and you will keep him warm for a day, set the man on fire and you will keep him warm for the rest of his life"
Find Me with SPOT http://share.findmespot.com/shared/f...kUQSskMiIucMuB
Wannabeeuro is offline   Reply With Quote
Old 01-27-2013, 07:28 PM   #422
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,288
Nah, I was taking it easy. Just stuck to a little superman tailwhip this time around.
Ride
AMA | COHVCO | Stay The Trail | BRC | TPA | BCTR | NCTR
thump_co is offline   Reply With Quote
Old 01-28-2013, 01:40 AM   #423
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,179
That sounds like linkage, it should shift up and down pretty easily riding it, like you said, no clutch on normal easy downshifts. you mentioned it starting off normally using the clutch which sounds like that is working ok. Haven't had the 300 apart but inkage is usally under the basket accessable from the RH cover (big one). Usally the only thing that happens inside the center cases is bent shift fork which typically causes a problem with one (or two) gears, not all of them. Time to pull the cover
I did something similar a few weeks go, I was cresting a 5' table top ledge and was a gear high, went to downshift just as the momentum went away and caught neutral instead. I tried to ride it out going backwards but of course but it promptly dumped me at the bottom, it was pretty funny.
Here's a pretty cool vid, makes me glad I got the 300, wish I could ride this good though.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak screwed with this post 01-28-2013 at 04:40 AM
RideFreak is offline   Reply With Quote
Old 01-28-2013, 06:54 AM   #424
TheDudeAbides
Sarcasm free11/11/10
TheDudeAbides's Avatar
Oddometer: 7,892
^^^^ Damn good video! My new all time favorite.
Best dualsport mirrors I've ever owned
2001 BMW F650 GS Dakar (Stolen!)
2004 DRZE
2004 BMW 1150 GSA
TheDudeAbides is offline   Reply With Quote
Old 01-29-2013, 06:57 AM   #425
duct tape
Lost
Oddometer: 469
My comments:
Jeez, I sure look good in my new Shift outfit!
My favorite scene is where the four stroker follows the two stroker through the trees but goes right of the line around one tree. A real whoah moment!
Second guy going up the cliff sure has confidence in the first guy making it.
950 SE
300 XC
500 XC-W
Trails Preservation Alliance www.coloradotpa.org
Colorado OHV Coalition www.cohvco.org
duct tape is offline   Reply With Quote
Old 01-29-2013, 06:59 AM   #426
duct tape
Lost
Oddometer: 469
I'm guessing this is Oz? B/c of the opener's accent, the vegetation and the ocean scenes?
950 SE
300 XC
500 XC-W
Old 01-29-2013, 07:06 AM   #427
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,856
yeah video and riders are all upside down i believe.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 01-30-2013, 01:05 PM   #428
cross-country
cross-country's Avatar
Oddometer: 1,672
Originally Posted by thump_co View Post
Yep.. still shifts up through 3rd at least (didn't try more while running).
Typically I can easily up/downshift just by letting off the throttle for a second without even touching the clutch (actually that's what I normally do), but it's not working very well now. When I have it in first, I can still slip and feather the clutch fine and it feels smooth.
When I hand shift the lever while on the stand it's definitely a bit sticky.. it doesn't just click and spring back to center. It'll catch in the up or down position sometimes.
I started up a thread on KTM talk and they're getting my hopes up that it's likely in the shift linkage under the clutch basket. Really hoping they're right and I can avoid pulling it out and splitting cases.
The first thing I would check is the weld on the shift shaft. Tom's 300 broke @ the weld last year. It was a very quick and easy repair as the shaft is removed out the right side of the engine underneath the intermediate cover.
cross-country is offline   Reply With Quote
Old 01-30-2013, 01:22 PM   #429
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,288
Cool.. hoping to have a chance to pull it apart tonight.
House construction is painful.
Ride
Old 02-04-2013, 12:32 AM   #430
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,288
Finally get 'er apart today.. Fortunately it's the linkage. The little allen head bolt holding on the shift selector barrel had backed out so the slot on barrel's backside was no longer catching consistently.
Ride
Old 02-04-2013, 06:14 AM   #431
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,179
Chris
Old 02-04-2013, 06:39 AM   #432
VxZeroKnots
Oddometer: 2,856
Glad you caught it now before it backed out far enough to damage the cases or get sent into the primary drive/clutch basket.
Old 02-04-2013, 09:02 AM   #433
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,288
You and me both.. especially considering we had been coming back down roads at the top of 5th at the end of the day. Coulda been uuuugly..
Ride
Old 02-23-2013, 03:11 PM   #434
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,288
As I've said before.. pretty much maintenance free.
Ride
Old 02-23-2013, 03:35 PM   #435
Olas
the darkness
Olas's Avatar
Oddometer: 4,055
Having a garage sale??
What's the issue?
Sent from my ADR6350
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Times are GMT -7.   It's 02:47 AM.
