Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 04-05-2012, 04:37 PM   #91
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
Originally Posted by thump_co View Post
My factory manual also mentions a "gelb" spring. I have no fuggin idea what gelb means, but the way the chart is laid out it appears to be the same as the yellow.
http://translate.google.com/#de|en|gelb
You are spot on.
Earlier this week my German boss accidently copied her entire group on a personal message to a friend in German. I deleted, but the language translator sure makes it easy to read.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 04-05-2012, 05:10 PM   #92
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,240
Last ride was using the green spring with the Dolly in 2 threads. Running that setup with the knarly pipe on technical terrain I rarely hit the powerband, the green makes the hit come on pretty late which works pretty good for an old guy like me.
I don't think I got it on the pipe this entire video
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 04-05-2012, 07:18 PM   #93
DirtDad
Green Chile Guru
DirtDad's Avatar
Oddometer: 1,610
I have been running the green spring for over a year now. Works fine for me. It is hard to see some of the colors
on the springs. The red spring is the softest, and you can feel that it is softer then the Yellow spring when you compress them. The green spring is the stiffer of the three. But I am sure you guys already knew that.
Current rides:
2014 YZ250F 05 KTM300EXC 07KTM450EXC
04 GasGas 280, finally, my perfect stable.
DirtDad is offline   Reply With Quote
Old 04-06-2012, 12:24 PM   #94
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
I pulled the spring again & found the color. It was painted onto one of the ends. It was yellow, set about 3 turns in from flush. I backed it out to one turn from flush to get a bit of an earlier hit.
I rebuilt suspension last weekend. Tore down & checked the auto clutch last night. New piston just came in the mail today. Original life-time GPR damper was completely FUBAR, so they are upgrading me to a new style. The bike should be up and running next week so that I can check the new PV settings.
Old 04-06-2012, 02:36 PM   #95
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,240
It should be nice with the suspension, topend and new dampner! To give you an idea of that adjustment's effect, turning the dolly in three turns as opposed to the factorys 2 turns will push the system more towards the green spring. Backing it out should give you a little earlier of a hit. Let us know how it does.
Chris
Old 04-06-2012, 04:34 PM   #96
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
Another tuning tid-bit.
My rear fender has been getting really sloppy. Bouncing up and down. I finally pulled everything apart. The top sub-frame rails that fit into the pockets on the fender were really erroded. Dirt gets in the pocket. Vibration and bouncing grinds the aluminum away. I'll be covering those rails with shrink wrap and/or tape, after filling in the eroded sections with bondo.
Old 04-06-2012, 08:43 PM   #97
DirtDad
Green Chile Guru
DirtDad's Avatar
Oddometer: 1,610
That is good to know. I will take a look at mine.
I installed my Gnarly pipe, and I figured it would not be a very huge improvement. Took the bike out today, and
wow! It was a rather significant improvement on the bottom, and mid-range. My front end was reaching for the
sky coming out of some tight sandy turns. It feels alot different too me. I am still running the green spring, but
it does not feel as mellow now. I think I will have to get a 48 tooth for the rear. Should help take away some of
the hit. Pretty much time to replace my chain and sprockets anyway.
Current rides:
Old 04-06-2012, 09:45 PM   #98
250senuf
250senuf's Avatar
Oddometer: 2,424
Might JB Weld be better, more durable?
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 04-07-2012, 09:07 AM   #99
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
Maybe, but how would you get it to stay on the vertical surfaces while curing? In any event, I will be wrapping with tape .
Old 04-07-2012, 09:13 PM   #100
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
JB Quick stays pretty stiff if you work it in cool weather. You can use some aluminum foil as a form.
Ride
AMA | COHVCO | Stay The Trail | BRC | TPA | BCTR | NCTR
thump_co is offline   Reply With Quote
Old 04-12-2012, 01:34 PM   #101
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Thought I'd include the '09 manual page for folks future reference. Looots of combo options between the PV, exhaust and map switch.
Nice vid.. looks like fun trail. I'm still digging the yellow spring.. and had the chance to hit the pipe several times last week: http://www.youtube.com/watch?v=DdIke_0iyVc&hd=1
Ride
Old 04-12-2012, 02:19 PM   #102
Shuffler
Hommes Grande
Shuffler's Avatar
Oddometer: 1,691
FWIW, I bought a switch from Sicass for my ignition map...it'd flip itself at random times from Off "hot" to On "mild" during rides. I got tired of dealing with it and just took it off and run the 'hot' curve at all times now.
Running the yellow spring & Gnarly headpipe with no complaints. Now I just need to find time to ride
________________________________
AMA | COHVCO | TPA | NCTR | BRC
KTM 950A | KTM 300XCW | BMW R1100RT
Shuffler is offline   Reply With Quote
Old 04-12-2012, 02:38 PM   #103
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Hmmm.. a "KTM/Bauer" brand map switch just arrived at my door from Slavens an hour ago.. hopefully I'll have better luck.. The switch action feels pretty stout at least.
I also think I have a clutch issue to address. I've had quite a few issues with tea-kettling the radiators when climbing steep/loose stuff and felt the clutch action was inconsistent. At first I thought it was traditional KTM hotness combined with rider error, but when doing battle with a climb last weekend I started noticing the clutch slipping as the bike gets hot. It also develops enough clutch drag that the bike can't idle and will die with the clutch pulled in unless I keep on the gas a bit. I'm going to try the oil+ATF mix suggestion that I see on ktmtalk first to see if maybe it's just a glazed plate. If that doesn't fix then I'm guessing I have some warped plates. Anyone else ever experience this?
Ride
Old 04-12-2012, 02:54 PM   #104
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,240
So how'd you like the 2T for that race? It looks like a great place to ride (I need to add it to the list ) Nice job on the vid too, not too jumpy and it gives ya a good feel for the riding out there, I felt like I was along for the ride.
Is that a GoPro cam? I have the same problem down here with riding into the sun, part of the scene is in a dark area (like that wash) and the bright sun is up above, it tends to overwelm the cam.
They sell these little polarizing filters that help diffuse the glare in those situations and don't hurt the picture when it's normal light. They don't fix it completly but help allot, $20 for 3 of them.
Chris
Old 04-12-2012, 03:51 PM   #105
thump_co OP
..ouch
thump_co's Avatar
Oddometer: 2,313
Thanks. The 2t was great for the tight washes.. Those parts were giddy fun (I sound like a dork going "wheeeee" through some of the highside and roost turns in Test 2).. but I was wishing for the longer wheelbase of the 450 through the many miles of whoops sections in between. We did quite a bit of playing on climbing the skinnies and bowls the day before. It gave me a chance to get the feel for long full on-the-pipe climbs. There where a number of the bigger ones that I had to abort when I stalled out 3/4 of the way up (a little sketchy) until I started to get the hang of it.
Yep.. it's a GoPro HD (not the newest GoPro2). I might have to give one of those filters a shot. I think part of the problem was the case being coated in think dust. Didn't matter how many times you wiped it, it was covered again a second later.
Air filter after race:
Ride
Times are GMT -7.   It's 09:01 PM.
