04-12-2012, 08:30 PM
#106 | |
Meh
Oddometer: 15,767
Partially related, when was the last time the clutch master cylinder oil was changed?
COHVCO Member and Blue Ribbon Coalition Member I have a DR problem |
04-13-2012, 12:41 AM
#107 |
..ouch
Oddometer: 1,495
Not sure.. but it's getting flushed tomorrow along with the tranny fluid change.
04-16-2012, 12:34 AM
#108 |
..ouch
Oddometer: 1,495
Got it sorted.. flushed the clutch, changed the oil and slapped on a new rad cap. Not sure which one did it, but it didn't boil once over the weekend.
Also liking the map switch, the difference is subtle, but I think it helps on the loose climbs. |
04-16-2012, 09:34 AM
#109 |
Meh
Oddometer: 15,767
I changed my cap as well and the boil over ended. When running right, the 300 is a dream machine-at least to me. It seems to me there is nothing that cannot be conquered.
04-16-2012, 10:19 AM
#110 | |
Scone Rider
Oddometer: 6,715
Just got my 300 off the bench yesterday. New top end and refreshed the suspension at both ends.
We don't stop riding because we get old, we get old because we stop riding. |
04-16-2012, 10:34 AM
#111 | |
..ouch
Oddometer: 1,495
Mine had the 1.8 cap already, I just think it was worn out. Seems like something good to proactively replace every couple years. I had installed an RLR last week before I figured out the cause of the problem and all it did was redirect so I was spewing steam and fluid out the back.. my own version of a James Bond oil slick dispenser. |
04-16-2012, 11:55 AM
#112 |
Scone Rider
Oddometer: 6,715
Looking fwd to it. I've only had the bike 4 years. I suppose it's time to experiment.
FYI, I developed a neat trick for installing the head gasket O-rings. As anyone who has done this knows, the large O-rings often require some stretching to get into place. Once in place, they are precariously positioned and will snap out of the groove. I tried heating the O-rings in boiling water, thinking they would expand. Didn't work. Then I dipped the O-rings in gasoline. Viola! In fact, they over expanded and I had to hit them with a hair dryer to drive out some of the gas to get them to shrink down to the optimal size.
04-16-2012, 03:05 PM
#113 |
Team Listo
Oddometer: 18,299
I looked (real hard) at my 300 yesterday for something to do it since I have been flogging it a bit lately.
I couldn't think of anything really...... That's it! I'll change the oil. ![]() I gallon of Rotella 15-40= $14.00. I gallon = 3.785 litres Bike capacity= 710 cc Works out to 10 minutes and $2.64/Oil Change. One drain bolt and no filters! I love this bike!!! |
04-16-2012, 04:25 PM
#114 | |
Meh
Oddometer: 15,767
You must mean the semi synthetic rotella as the full synth runs 22 up here in Colorado.
04-16-2012, 04:32 PM
#115 | |
Torque Junkie
Oddometer: 3,548
And to believe some folks say the KTMs are expensive and time consuming to maintain
![]() Quote:
04-16-2012, 04:43 PM
#116 |
Team Listo
Oddometer: 18,299
04-16-2012, 06:09 PM
#117 |
Green Chile Guru
Oddometer: 1,447
Hmmm, that is the same oil I use in my truck!
I was pissed the other day, cause it took me about 11 minutes to change the oil, and install a air filter. Fricken KTM Two Smokes, they are sooo, needy.
Current rides: 1999 KX500 Dez Sled 05 KTM300EXC 2011 KLR650
04-16-2012, 06:16 PM
#118 |
..ouch
Oddometer: 1,495
I got all fancy. Currently running a 50/50 mix of Rotella 15W-40 and ATF Type F as recommended every so often by a number of folks on ktmtalk. The ATF detergents will clean off any glazing on the clutch plates.
Also have to toss in the new springs that came in from Slaven's today. This thing is just a maintenance beast. |
04-16-2012, 06:23 PM
#119 | |
Unpronouncible
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,394
04-23-2012, 08:45 AM
#120 |
Team Listo
Oddometer: 18,299
I was thinking about taking off my Rekluse Core EXP for a while and trying the bike without it for a while.
![]() Well, last Saturday, I played around with the lever adjustment and got it working just about perfect! I have manual control with a feel that is very, very close to a standard clutch, but I am still getting all the benefits of the auto-clutch. ![]() This was all fast desert single track, so we'll see when the mountain riding opens up. |
