Old 03-07-2012, 03:24 PM   #1
enduroracer3245 OP
Orange Crush
Oddometer: 21
Question 1996 ktm rxc 620 help!
Hello fellow riders! So i got a serious problem on my hand with my beautiful 1995 KTM RXC 620 that i love to ride! So i will tell you from start to end on the information on what i got right now but i need some direction from some wise people being only i am 17 and my father doesn't really want anything to do with the ktm at the moment. I am very mechanical inclined so i can do most engine easy-moderate repair. Ok so now onto the description, my bike just idles but will not accelerate. Now before this happened i was doing some sandy hill climbs with friends on a cool summer day, my bike ran great and never shown any signs of this problem. Towards the end of the hill climb day i stopped to rest for a few minutes on a sand hill with my bike facing towards downhill, i go to start it and it make this sound like something fell into the engine but went away after a few quick seconds so i was like oh crap and just had my friend trailer it home for me. I get it started the next day and it runs fine but here is the scoop towards the end of the day for the road riding the bike would no longer accelerate like a 650cc would but like a little 110cc, like i had to give it full throttle to get off from stop lights. I made it home but by that time it really was running horribly to the point where if i gave it gas it would just shut off. So far the thing i have done to the bike is replace the plugs, cleaned the carburetor, and petcock but no absolute change at all. Also 2 weeks before the hill climbs we had to pull the magneto cover off to replace some oil lines but i moved the magneto back to is original spot and made sure it was in it's original spot, I made a note that it didn't drive any different and was normal as i was riding around town for those 2 weeks after the oil lines and magneto cover were taken off. Only after the hill climbs it started running like crap. I don't even know where to start on fixing it but i am so close to just taking it to the ktm dealership about 120 miles away to have them look at it and fix the problem but i am trying to save money. Thanks to any wise people that answer this to help, i am just lost at the moment and i need to get my hands back on this project so i can ride as spring is approaching and our gas prices are going up :). Good gas mileage for a enduro bike though!
Thanks Adventure Riders!
enduroracer3245 is offline   Reply With Quote
Old 03-11-2012, 02:07 PM   #2
enduroracer3245 OP
Orange Crush
Oddometer: 21
Anyone? I am so stumped on this problem.
Old 03-11-2012, 02:17 PM   #3
mcma111
mcma111's Avatar
Oddometer: 11,901
First off I'd pull the air filter and have a look inside the intake to make sure that sand didn't get in there. If it did it's time for a top end over-haul. You may have damaged the piston either way. Take a compression test to confirm compression.
This is just for starters.
Good Luck.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-11-2012, 02:29 PM   #4
enduroracer3245 OP
Orange Crush
Oddometer: 21
Alright thanks, I will do a compression test.
Old 03-11-2012, 03:24 PM   #5
mcma111
mcma111's Avatar
Oddometer: 11,901
When you do the compression test do it a second time but squirt a small amount of oil in the cylinder and spin the motor over a few times before testing again. If the pressure rises then it's the piston and or rings.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-11-2012, 07:49 PM   #6
rz35027
rz35027's Avatar
Oddometer: 228
Throttle cable still connected?
Gas tank vent?
Check the valves...
rz35027 is offline   Reply With Quote
Old 03-11-2012, 10:44 PM   #7
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
plug fowled?
I'm thinking when you parked it on the hill oil got by the thing-ma-jig and crept into the carb, fowling the plug.
And x2 on checking the valves. I'd pull the cover and check the cams and the whole thing. Oil might have loaded up and when you started pumping more, blew something.
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx is offline   Reply With Quote
Old 03-12-2012, 12:33 AM   #8
bmwktmbill
Traveler
Oddometer: 5,049
What carb?
If it's a CV carb the diaphram is torn.
Or maybe the carb is loose?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 03-12-2012, 06:00 AM   #9
enduroracer3245 OP
Orange Crush
Oddometer: 21
The carb is a Kehin FCR MX 39mm. I think there is just one diaphragm on it but i will check to see if there is more. Thanks for adding to things i can look at to get it running again, it helps alot!
enduroracer3245 screwed with this post 03-12-2012 at 06:29 AM
Old 03-12-2012, 06:01 AM   #10
enduroracer3245 OP
Orange Crush
Oddometer: 21
Thanks everyone for the answers!
Old 03-12-2012, 04:22 PM   #11
enduroracer3245 OP
Orange Crush
Oddometer: 21
Wicked
I am buying diaphragms soon i will let you guys know if it works or not.
Listen to what the spark plug has to say, it has plenty of wise information to show you what the engine is doing!
Old 03-12-2012, 04:39 PM   #12
mcma111
mcma111's Avatar
Oddometer: 11,901
What diaphragms
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2012, 07:55 PM   #13
enduroracer3245 OP
Orange Crush
Oddometer: 21
Cool2
Well there are 2 diaphragms in the Keihin FCR MX 39mm carb. If there is a tear or even just a little puncture on them they make the bike idle fine with no notice but if acceleration is thrown at the carbs they cannot handle it because the diaphragms leak. The one diaphragm is on an accelerator pump for fuel and the second one is for air and if one or both are not working in sync with the carb it will run like crap from what i have seen on the internet and once bmwktmbill had said to check them it got me thinking about it because we just had pulled it off before that hill climb to clean and inspect it and might have left a pin sized hole which went unoticed until the rip got bigger from doing all that acceleration causing a big difference. See after awhile i have heard that these diaphragms get stretched out and when you take the carb apart and put it back together the diaphragm will be bigger than its mounting spot, so when you put the cover back over it it cannot stretch anymore cause it has its full life causing it to rip. I will post pics to tomorrow of the diaphragms if there is any tears or rips. Its hard to explain in text form but pictures will be easier.
Old 03-12-2012, 08:07 PM   #14
mcma111
mcma111's Avatar
Oddometer: 11,901
KISS
Have you even done the compression test yet or are you just going to start throwing parts at the bike in the hope that something you do some how fixes it???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2012, 08:26 PM   #15
enduroracer3245 OP
Orange Crush
Oddometer: 21
Thumb
no i haven't bought parts yet, i get my bike in the shop tomorrow and then i am doing the compression test first and then taking the carb back apart to look at the diaphragms for any rips or tiny holes.
Times are GMT -7.   It's 03:56 AM.
