Old 10-04-2012, 03:35 PM   #61
Karbono OP
Rookie GSer
Karbono's Avatar
Oddometer: 337
How about one of these?
Karbono is offline   Reply With Quote
Old 10-04-2012, 04:50 PM   #62
mamm
< advertise here! >
mamm's Avatar
Oddometer: 218
I don't trust those CREE-based replacement bulbs. For starters, they don't have the same dimensions that the traditional incandescent bulbs have, so the light source won't be at the optimal position (the position that the reflector was designed for).
Of course, those factory-fitted led bulbs (like the ones in the low beam of the new water-cooled boxer GS, or in some Audi cages) are a whole 'nother thing - those reflectors were designed for them.
2012 R1200GS TB
Enjoy yourself, it's later than you think.
mamm is offline   Reply With Quote
Old 10-04-2012, 04:55 PM   #63
Karbono OP
Rookie GSer
Karbono's Avatar
Oddometer: 337
I see your point... But have a look at some of the videos on youtube. Granted, you can't really tell from the ffootage,, but the lighting sure seems pretty solid. For the price, maybe I'll order a couple so I can try it on the next time wa light fails :)
Old 10-04-2012, 04:59 PM   #64
Karbono OP
Rookie GSer
Karbono's Avatar
Oddometer: 337
Which reminds me, since there's such a large area painted black inside the spotlight, next time I may cover it in tin foil a see if there's a difference
Old 12-12-2012, 03:23 PM   #65
Karbono OP
Rookie GSer
Karbono's Avatar
Oddometer: 337
Givi S310
Old 12-13-2012, 03:54 AM   #66
mamm
< advertise here! >
mamm's Avatar
Oddometer: 218
Karbono, perfect aiming on the Givis: complementing the low beam to the sides.
But... isn't your low beam aimed a little low? Maybe it's the camera angle, but it looks to me that the light pattern in the ground is too close to the front of the bike.
I'm sure you are aware of the "measure bulb distance to the ground, mark this height in a wall, back off the bike 10m from the wall (level surface), climb on the bike, the low beam cutoff line should be at the marked point" alignment procedure?
2012 R1200GS TB
Old 09-17-2013, 04:42 AM   #67
keep it simple!
Oddometer: 147
Everyone still happy with the S310?
keep it simple! is offline   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
