Old 03-09-2012, 09:21 PM   #1
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,502
EXC Subframe cracks
I noticed my '06 450 and 300 EXC both have cracks in the upper subframe where it bolts to the main frame. Both bikes may have been like this for years. It looks like a hollow tube, that have a solid plug in the end.
Anyone else observed this? Should I yank the frames and have them welded up, or will the solid plug essentially make this unnecessary?
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 03-09-2012, 09:35 PM   #2
Hayden#69
Oddometer: 254
My friends 2002 400 SX is like that. My 03 450 EXC is like that and my other friends 04 450 EXC is like that. Doesnt slow us down any.
Hayden.
Hayden#69 is offline   Reply With Quote
Old 03-09-2012, 10:06 PM   #3
jrproper
Oddometer: 158
Every KTM sub-frame I've seen looks just like that... wouldn't worry about it.
jrproper is offline   Reply With Quote
Old 03-09-2012, 10:08 PM   #4
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,079
As is my '06 EXC and every KTM I've seen.
I think it's factory for less weight...
... hence the faster bike.
If someone has a pic of one not "cracked" please post.
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is offline   Reply With Quote
Old 03-09-2012, 10:17 PM   #5
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,502
Thanks guys. What a relief. One less thing on the list to deal with this spring.
Old 03-10-2012, 04:34 AM   #6
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,744
Those are ripples from the time warp! Slow down!
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 10-16-2012, 01:18 AM   #7
Safeman
Oddometer: 1
KTM 450 EXC Sub repair
I had the same issue with my sub which I modded so that I could carry more weight on it - take a look here at this link on our local (South Africa) av forum if you are interested:-) This solution works a treat!
http://www.wilddog.za.net/forum/inde...topic=108925.0
Safeman is offline   Reply With Quote
Old 10-16-2012, 05:39 AM   #8
Switchblade315
Switchblade315's Avatar
Oddometer: 5,703
Almost everyone I've ever seen is like that.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 10-16-2012, 05:52 AM   #9
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,502
Thanks! Great fix.
Old 10-16-2012, 05:58 AM   #10
Stphnw8
Oddometer: 3
Nearly all ktm's ( from 65cc upwards) I've seen at my sons moto x club have done the same in exactly the same place.
Most of them have never had any problem with the crack growing or opening up and these kids are jumping very large table tops with no probs at all.
My local ktm dealer says he's never seen it before..........
Ktm----- Sunday = ATM -------Monday
Stphnw8 is offline   Reply With Quote
Old 10-16-2012, 06:43 AM   #11
blake716
nine toes
blake716's Avatar
Oddometer: 12,914
Same here. All of my KTM's have had the exact same cracks.
No worries.
_________________________
blake716 is offline   Reply With Quote
Old 10-16-2012, 08:52 AM   #12
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,300
The metal that's cracked is just the casing. The solid core is what's important. And like others said, every KTM I've ever seen has identical cracks.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 10-16-2012, 12:16 PM   #13
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,502
No worries.
You are missing the point. Some folks have an irresistible urge to fix things like this, making them better, faster, stronger. (present company included)
If I had my own TIG, all three of my EXCs would be getting the same fix.
Old 10-18-2012, 07:36 PM   #14
woodzrider
Oddometer: 592
I had an '06 exc 450 (which I wish I still had). Took it apart at about six months new to check thing out, It was not
cracked then. A year later I had the very same cracks and the plugs were just starting to loosen a bit. Being as I can TIG weld, I cleaned the offending crack, slightly V'd the crack and welded it back as well as ran a bead around the plugs and re-assembled. Never noticed anymore cracks up until I sold the bike a little over a year ago. My observation is that the plugs are slightly pressed into the end of the tube and being as the tube is extremely soft
alum, the press fit fatigues the material enought to cause a stretch crack over time due to vibratioin and riding.
Just my.03..........
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is offline   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
