04-30-2012, 08:17 AM
#61 |
Riding Nomad™
Oddometer: 12,717
I'll put a rush order to get those fuckers... just need to know what distributor to get...
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
04-30-2012, 10:15 AM
#62 |
SUPPORT THE SECOND
Oddometer: 1,679
Mechanical dist and get rid of the points . Pertronix ?
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog If you don't organize your tools, you're a terrible person.---Aghartha You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02 |
04-30-2012, 10:32 AM
#63 |
Oddometer: 1,772
I'm not sure how the L-Jet system could have fried yoru points. The distributor should be a mechanical with vacuum advance and the points opening and closing are controlled mechanicly by the distro. I used to eat condensers on my bus until i found a short between the condenser and the body of the distributor.
Have you put a voltmeter on your ECU to ensure the thing isn't fried? Swapping to carbs usually requires yanking the gas tank and modifying it to eliminate the high pressure gas return lines.
“I had rather be shut up in a very modest cottage with my books, my family and a few old friends, dining on simple bacon, and letting the world roll on as it liked, than to occupy the most splendid post, which any human power can give.” -Thomas Jefferson Tornado Alley Rally, June 10th, 2011! |
04-30-2012, 11:03 AM
#64 | |
Riding Nomad™
Oddometer: 12,717
As posted on another forum:
04-30-2012, 06:17 PM
#65 |
Riding Nomad™
Oddometer: 12,717
Unfortunate accidents happen, sometimes due to ones own lack of diligence and foresight, and lack of experience.
You always learn the best from personal mistakes. The following is a list of known bad parts: - The Federal ECU - smoked. $100-$499. - Wiring Harness, salvageable - fused pins, melted wires. $20-$350. - 009 Distributor - melted. $100. - Pertronix - melted. $70. - Double Relay - smoked. $79 - Several Connectors - melted. $0.25 Learning from your own mistake - priceless. This afternoon I spent some time cleaning up all this mess, and removing the failed components, and plotting the placement for Microsquirt. ![]()
04-30-2012, 06:36 PM
#66 |
Riding Nomad™
Oddometer: 12,717
I re-tested the rest of the electrical components, and all of the injectors ohmed to spec..
. I will be re-using them. The following will be the new EFI layout: ![]() Microsquirt will be inside the van under the bench away from heat, water, hands, and other things. Pink - Relay 1 - Starter Relay Purple - Relay 2 - Fuel Pump Relay Red - Injectors - 4 individual pairs Orange - Coolant Temperature Sensor - Custom Fit via adapter to CHT Green - Intake AIR Temperature Sensor - Custom Fit into the intake plenum where EGR used to connect. Yellow - GM 3 wire MAP Sensor Blue 1 - Vacuum line from throttle body to MAP Blue 2 - Vacuum line from intake plenum to Fuel Pressure Regulator. The airbox will be replaced with a "cold are intake" piping with a filter from one of the "tuner" cars.
04-30-2012, 07:02 PM
#67 |
Riding Nomad™
Oddometer: 12,717
I'll probably (have to) re-use the AUX AIR REGULATOR for idle. Although idle air stepper motor could be machined somewhere into the throttle body....
The cost: $380 for the microsquirt kit: ecu w/ 4 injector terminals, wide band o2 sensor, coolant temperature sensor, wiring harness, relays, fuse, serial cable... $50 for the MAP sensor, $20 for additional connectors, and shrink tubing. $20 for cold air intake. --------------- Approximate Total: $470.
04-30-2012, 07:08 PM
#68 | |
SUPPORT THE SECOND
Oddometer: 1,679
04-30-2012, 07:18 PM
#69 |
Riding Nomad™
Oddometer: 12,717
Have not been down that path yet, so would not know... What are you thinking?
04-30-2012, 08:28 PM
#70 |
SUPPORT THE SECOND
Oddometer: 1,679
Custom building an FI system ? I see people doing it , but with a lot of pain . Why ?
04-30-2012, 08:52 PM
#71 | |
be a man dodge tree bark
Pain in mapping it... dyno time...
racing is not real till your fighting for the line into the next blind corner,real roads, real trees, real fast, real men rally. be a man dodge tree bark! We’ve said it before, but it bears repeating; the GS handles in ways a two-story building was never meant to. Taking collections for Faye Butler Training please spare some change. www.kmotorwerks.com Remember red and yellow make orange.so to think orange is better means you have to use two steps to get there. ________ |
04-30-2012, 09:02 PM
#72 |
SUPPORT THE SECOND
Oddometer: 1,679
Time is money .
04-30-2012, 10:12 PM
#73 | |
Oddometer: 1,772
05-01-2012, 05:20 AM
#74 |
Riding Nomad™
Oddometer: 12,717
I don't know what caused the original issue, and I can only suspect at this time that the ECU was on its way out. One thing is for certain, it is fried now for sure. I unplugged the ECU cable with the ignition on. It would not have been so bad had the pins not touched.
05-01-2012, 07:01 AM
#75 |
If they have a good starting map... And some seat of the pants tuning.
only about an hour dyno. Wide band O2 will help out a lot. And a good five gas analyzer ... Best thing he can do is find a guy local, who is really good with mega squirt . There is a computer geek here who has quite a few cars running around on mega.. some as high as 800 horse,.. He nails maps out of his head almost dead on...
| Thread Tools | |
