03-13-2012, 10:02 PM
#31 | ||
Needs to ride!
Oddometer: 2,065
Isn't that one word?
Believe me, I've thought it... Quote:
We'll get it sorted eventually. Quote:
But wasting fuel for no benefit is, well, wasteful! Not cool. Who is "we" BTW? Are you cooking up something interesting?
WHHHAAAAT!?!?! ![]() 5 Star RR: VIOLA-TING AMERICA - Chasing the dream of music and motos |
03-13-2012, 10:05 PM
#32 |
Needs to ride!
Oddometer: 2,065
I suppose I'm gong to reassemble again and hook up to TuneECU and have a go with the suggestions here, see what happens.
Still seems that the committee is split on "S" Hose VS. Bolts on the intakes... Hmmm. Kinda gotta decide that before I put the airbox back on.
03-14-2012, 05:40 AM
#33 | |
Oddometer: 330
Proud to be supporting Pyndon in the 2013 Dakar ! 2007 KTM 990 Adventure 2008 KTM 300 XC (plated) 2008 KTM 690 Enduro 1998 KTM 400 RXC (sold) |
03-14-2012, 06:42 AM
#34 |
Oddometer: 152
I'll add to the Hose debate... Mine is in "S" configuration (injected bike), works fine. Doesn't seem to effect my mileage, I routinely get mid-high 40's with my setup.
03-14-2012, 09:55 AM
#35 | |
Life is a trip
Oddometer: 3,101
You can always pinch the "S" hose underneath the air filter.
Cheers.
There is always a reason!! |
03-15-2012, 03:11 PM
#36 |
Needs to ride!
Oddometer: 2,065
Bike is back together, charging batt now.
Looks like the O2 sensors are off (unchecked) in my current Akro map. Should I try turning them on? TPS - how do I go about calibrating/testing this? The manual isn't very clear, it says "no, can't test TPS" and then goes on to mention how to do it. I can't tell if engine is supposed to be on, off, or what... I see the "TPS" box in the lower right border of the window, do I manipulate it from there? Please give me very specific instructions.
03-15-2012, 03:46 PM
#37 |
Dans le doute...gaz!
Oddometer: 1,718
It's the tps that you are trying to adjust, right? Not the throttle cable adjustment function.
I'm just trying to be clear.
The race is long and, in the end, it's only with yourself...
03-15-2012, 03:57 PM
#38 |
Unbunch yer panties!
Oddometer: 1,103
HIghly recommend that you change nothing since the mechanical check and go give it another test. Change too much and you'll never know what worked or didn't....
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
03-15-2012, 03:58 PM
#39 |
Needs to ride!
Oddometer: 2,065
Yes, correct. My throttle cable is adjusted properly, I want to calibrate/reset the TPS if possible to eliminate that as a factor contributing to my poor fuel consumption.
03-15-2012, 03:59 PM
#40 |
Needs to ride!
Oddometer: 2,065
Okay, you're right, worth a shot (even though I didn't change anything, just took it apart and put it back together...)
03-15-2012, 04:01 PM
#41 |
Oddometer: 1,718
+1 except if you have your right tank off and/or air box opened
#42 | |
Oddometer: 330
03-15-2012, 04:04 PM
#43 | |
Oddometer: 1,718
The tps adjustments are done on a warm engine. In the off position. After a TBs adjustment preferably. It's easier to do when your airbox is of the bike otherwise you'll need to drill it (easy way to accept the tps). And the value that you are aiming for is 0.60v What do you currently have?
03-15-2012, 08:04 PM
#44 | |
Needs to ride!
Oddometer: 2,065
So then I should warm the engine, plug it in, do a TB adjustment, then a TPS adjustment? Any special instructions for TB and TPS? I'm confused, is the TPS adjustment a manual/mechanical adjustment? Why do I need to be physically in the airbox if my throttle cable is properly adjusted? My throttle cable tension/slack looks good, just a little bit of give at full close. Am I supposed to adjust it with a computer aid somehow? I really am scratching me head, it's a couple simple little nuts...
03-15-2012, 08:32 PM
#45 |
Oddometer: 1,103
Yes. The computer sets the isc servo at a specfic starting place independent of your cable slack.
Under the TESTS tab, under the test&adjust window, use the "adjust throttle cable" button. This zeros the ISC servo so that you are actually adjusting what you think you are adjusting. Under "tasks" on the tuneecu site: http://www.tuneecu.com/TuneECU_En/tasks.html "Adjusting the throttle cable - only KTM The idle speed control stepper motor will be completely retracted and the throttle valves completely closed. Switch the ignition switch off, WITHOUT exiting or disconnecting the software, and adjust the throttle cable clearance." Hope this helps. Steve
