Old 03-17-2012, 10:58 AM   #61
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,322
All my twins run smooth as crap here is the order.
Valves -> throttle cables -> Sync Throttle bodies -> in the 990 case after sync make the tps back in spec.
Then I typically let it cool down all the way a few times to make sure its spot on. Then i reload the map do a 15 min idle and its pretty smooth.
The ideal condition would be have the bike EXACTLY the same specs as the bike they made the map on at the factory. But we all know the factory maps are pretty much garbage.
Also make sure your map sensor holes are not blocked by maybe getting bad gas. That will make your gas mileage go in the shitter.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 03-17-2012, 11:05 AM   #62
viola-tor OP
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
And where might these be?
viola-tor is offline   Reply With Quote
Old 03-17-2012, 11:25 AM   #63
DirtJack
DirtJack's Avatar
Oddometer: 1,452
Since you re-loaded the Akra map (to turn the O2 sensors on) you need to do the 15 minute idle dance.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 03-17-2012, 11:34 AM   #64
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
Originally Posted by viola-tor View Post
Thank you Jack,
Yes, I've checked the O2 box and downloaded the map again (computer -> bike). I've also turned the TB sync screw and made the operating cylinder values match (engine running). It was only a small turn, 1/2 turn maybe was enough.
Will button her up and test ride then report back, but I'm skeptical that it will be much better... We'll see!
Yep. The air temp sensor error will get turned off as soon as you plug it back in.
It looks good. Good ride it!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-17-2012, 11:55 AM   #65
viola-tor OP
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
I'm on it! 15 min idle completed, leaving for test ride (and getting new taillight bulb, and printer ink... It's always something )
Where are these map sensor holes that I want to clean out???
Old 03-17-2012, 01:40 PM   #66
viola-tor OP
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
50 mi test ride complete, bike runs pretty well, still some "searching" in the 4500-5500 RPM range.
Mileage is up to 30 MPG (from 23), which was a little bit of urban hooliganism and 40 miles slab at 70-80, same route I did on last test. Still not wonderful, but I'll take it for now. Looks like something did something in the right direction... I still suspect problems, probably mapping.
Time to pack!
Old 03-17-2012, 04:29 PM   #67
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,833
Alright! Little bit more work and you're good to go.
The MAP holes are the ones that come off of front-right and rear-left cylinders and go up to those funny looking black things. Basically, opposite of the S-hose we run.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 03-17-2012, 07:39 PM   #68
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 2,989
After all that, I'm keeping my carbs. Here I thought they were a pain to work on when I find the FI may well be more of a pain .
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 03-17-2012, 07:40 PM   #69
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,132
Time to pack!
Sir Viola-tor.
For what dost whenst thou pack?
Pray. Where dost thou goeth?
Dost a fair maiden needest rescuing from the claws of a bloodthirsty dragon?
To calm the savage beast withst thou musical arts perchance?
God Speed upon you and your mighty KTM.
Q~
Questor screwed with this post 03-17-2012 at 07:46 PM
Old 03-17-2012, 11:50 PM   #70
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,322
Yep those things. They can get covered over with crap (happened to me) if you get bad gas. Then the bike freaks out and you get in the 20s and I had a surge around the rpm you talk about too.
I pulled them out and cleaned them out really good and cleaned the throttle bodies. Then put teflon around the threads and put them back in.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 03-18-2012, 11:30 AM   #71
DirtJack
DirtJack's Avatar
Oddometer: 1,452
Originally Posted by Questor View Post
Sir Viola-tor.
Q~
Diek is on his way for 2 weeks that starts and ends at Big Bend. Just received a text from Viola-tor at a fuel stop in Del Rio, 27.7 mpg. His range is about 200 miles (2.1 gal Neduro tank at the rear). I think he also has a fuel bladder he can fill if there is a leg of more than 200 miles.
2008 KTM 690 Enduro
Old 03-18-2012, 11:37 AM   #72
bikyto
bikyto's Avatar
Oddometer: 2,160
Hum... So it improved but didn't get fixed.
I wonder if he has time to clean his map sensors.
Old 03-18-2012, 11:40 AM   #73
DirtJack
DirtJack's Avatar
Oddometer: 1,452
I sent him a text with the suggestion that it was something he could easily check and clean in camp.
2008 KTM 690 Enduro
Old 03-18-2012, 12:58 PM   #74
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
I got 28 with the factory Akro map and dual Q4s. Wouldn't surprise me if it's about as good as it gona get with the 2-1 he's running.
Now the fun begins...
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-18-2012, 01:13 PM   #75
bikyto
bikyto's Avatar
Oddometer: 2,160
Steve
I get 37-39 with the akra map and 2-1
If I nurse the bike, I get up to 42. So something is off.
The map sensors are easy to clean but with the stock air box, not fun to access unless he doesn't mind taking the tanks off again
Times are GMT -7.   It's 02:07 PM.
