Old 11-13-2012, 04:50 PM   #1
hisandhers OP
Oddometer: 35
BMW 650 X Country Gas Tank
I have a 650 Cross Country with a newly installed Hotrod Welding auxiliary gas tank. The tank is a work of art!
I apparently have an air leak as it pulls fuel from the bike's tank before the auxiliary tank.
Anyone find and typical air leak areas?
hisandhers is offline   Reply With Quote
Old 11-13-2012, 05:22 PM   #2
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 328
I have an X Challenge with the same tank. When I first intalled it, it took awhile to start drawing down. I was worried, but after filling up again it worked, as it has since.
I used a MityVac to test the main tank for leaks by hooking up to the end of the vent hose and drawing a vacuum. If you can maintain vacuum there, the cap is sealing good.
Hope this helps.
ridepjride is offline   Reply With Quote
Old 11-14-2012, 05:34 AM   #3
hisandhers OP
Oddometer: 35
BMW 650 Cross Country Fuel Tank
That's good advice, will test the vacuum.
I ordered a new gas cap anyway; think mine does have a minor leak. Got the keyless one since it's a little tight under
the HB panniers to get the key in without removing the pannier.
Thanks!!!
Times are GMT -7.   It's 12:38 AM.
