Old 06-20-2012, 07:29 PM   #136
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 769
I'm going down the same route with Paul's new rally tree and and 2 squadrons, so created this little table to help clarify when the total draw (in amps) will go negative and start draining the battery. I have an exc so a couple of the minor draw items may not apply to a xc-w. With both squadron's running and OM stator, one needs to really watch things like the cooling fan and other added accessories...of coarse this will always happen with Murphy on riding on the back in the middle of BF Egypt.
note: 13v used as nominal voltage; amps = watts / 13V
dvwalker is offline   Reply With Quote
Old 06-20-2012, 07:50 PM   #137
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
I plan on running two squadrons also, but intend on getting one Spot and one flood. My set up will use a PWM dimmer with a high beam by-pass for the LED lights. I will run only the flood squadron dimmed (22 Watts) for low beam and the flood at full power, plus the spot at full power for high beam. This should save quite a bit of power.
Old 07-22-2012, 04:46 AM   #138
nzcvlh
nzcvlh's Avatar
Oddometer: 77
Battery function in XC-W
does the electrical architecture of the KTM allow the bike to start (kick) with a dead, shorted, or missing battery. Thought the folks working on the electrical loading damands might have an idea. Battery failed on my F800GS while running and everything shut off dead immediately. Apparently the new WR450 has this capability.... at least it is claimed.
Dave
nzcvlh is offline   Reply With Quote
Old 07-22-2012, 05:52 AM   #139
ABYSS
KTM
Oddometer: 1,198
Easy enough to test
Dave
Disconnect the battery and try it.
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 07-22-2012, 06:49 AM   #140
helotaxi
Oddometer: 380
I can shed a little light on that one, though not provide a complete answer. After installing the Sicass switch housing, I accidentally left the ignition on (headlight off) and didn't discover it until about a week later. Battery completely dead, so dead, in fact that it didn't register on the Battery Tender and showed an open circuit with a DMM. I kicked on it for several minutes and got the FI light to flicker with each kick but it never turned over completely and I never got it started. I can't say that will never start or run with the battery removed but it certainly won't start easily. To make sure that it isn't just me, I'll kick it today with the new, charged battery installed.
helotaxi is offline   Reply With Quote
Old 07-31-2012, 05:56 PM   #141
RenoMoto
Rally Navigator
RenoMoto's Avatar
Oddometer: 226
3.3 (+/-) natural tank available for 2013 500xcw yet?
Inmates:
Vegas to Reno is coming soon....!
I've looked around and haven't been able to find a 3.3 (+/-) gallon tank for my 2013 500xcw.
I would strongly prefer a natural, transparent plastic rather than orange or black.
Any suggestions? I would like to run the stock shrouds and not mess with the 4+ gallon tank set up.
Any help would be appreciated,
Mike Shirley
Double Diamond Athletic Club - Reno - Nevada
500 XCW - 990 Adventure R - 690 Duke
Pics - Moto - Dakar Rally - Rally Mongolia - TAT - F1 - Sports Cars - Crap
Rally Navigator - Create, Print & Share Rally Routes with Google Earth.
RenoMoto is offline   Reply With Quote
Old 07-31-2012, 06:18 PM   #142
ABYSS
KTM
Oddometer: 1,198
Clockworks
Originally Posted by RenoMoto View Post
Inmates:
Is an option but it has seen issues, I am not sure if they are making them again or not.
Maybe = NO
ABYSS screwed with this post 08-05-2012 at 07:07 AM
Old 08-01-2012, 08:51 AM   #143
trailjammer
trailjammer's Avatar
Oddometer: 368
Clockworks
I've been using the Clockworks tank on my '08 530 EXC-R for years and love it. I've had no problems. I'd look into them if they make one for your bike.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 08-01-2012, 08:55 AM   #144
ABYSS
KTM
Oddometer: 1,198
Eh? thats what I said above
they do make they but they have had a few challanges when they were first released. they may be fixed but not sure as I went a different route. Acerbis also makes a 3 gallon i think that is availble in clear and they are really nice tanks.
here is a link to both...
http://justgastanks.com/index.php?cPath=4_78_886_888
Maybe = NO
Old 08-01-2012, 09:51 AM   #145
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
If Acerbis makes it, I'd buy it. Have never had any other tank that's equalled the fit and finish of Acerbis tanks. Can tell that they're not just hand-shaped, adding volume to stock tanks with foam and bondo like a lot of the other companies.
jesusgatos is online now   Reply With Quote
Old 08-01-2012, 01:46 PM   #146
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 643
I like the builds, keep up the good work.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 08-01-2012, 07:04 PM   #147
RenoMoto
Rally Navigator
RenoMoto's Avatar
Oddometer: 226
will 500 EXC tank fit the 500 XCW?
Will this tank fit the 2013 500XCW also?
KTM 500 EXC Acerbis Gas Tanks [Acerbis Fuel Tanks] $229.99
http://justgastanks.com/product_info...oducts_id=2857
Fits: KTM 250/350/450/500 EXC/XCF/XCFW 2011-12
Comes with all mounting hardware and instructions
Note:
5.3 Gallon in Natural on Backorder until 8-8-12
Stock tank compacity is 2.25 US gallons or 8.5 Liters
Available Options:
Part #/Years/Capacity::
2250310147 11-12 XCF/EXC 350-500 3.0GAL Natural
thanks!
Mike Shirley
Old 08-01-2012, 07:48 PM   #148
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,740
Note:
Available Options:
thanks!
I have the 5.3 in natural on my 500 XC-W. So yes it fits.
toddler is offline   Reply With Quote
Old 08-05-2012, 05:33 AM   #149
nzcvlh
nzcvlh's Avatar
Oddometer: 77
Battery Charger
Looking for some insight on battery tender interactions with XCW. I hooked up a tender directly to the battery and the "FI" light and associated relays cycle on and off every 10 secs or so. When I remove the tender all goes back to normal. Its like it is going through a start cycle, without the starter been activated whent the tender does its cycle. Any thoughts or clues appreciated. Dave
Old 08-05-2012, 06:33 AM   #150
toddler
Unpronouncible
toddler's Avatar
Oddometer: 2,740
I believe the manual says not to charge the battery while it is connected to the bike. Kind of a bummer. I still do though.
Times are GMT -7.   It's 11:17 PM.
