Old 09-24-2012, 10:41 AM   #196
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 648
Originally Posted by Geek View Post
I went up a tooth on the back of the 500.
I think with this gear ratio the front tire may last the life of the bike
Geekster, what gearing are you running now?
I got a new 500 coming in mid October...rounding up various parts including sprockets.
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 09-24-2012, 12:14 PM   #197
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,033
Its an XCW.. so stock +1 on the rear (51 teeth).
Geek screwed with this post 09-24-2012 at 12:23 PM
Old 09-29-2012, 03:32 AM   #198
bill1960
Oddometer: 369
As I look at the first dusting of snow on the peaks above us for the season.. I realize we didn't do nearly enough of this this summer
Geek
Another question re the daytrippers.
Could they be mounted further back, ie, around 2-3" back so the rear of the bag is almost level with the rear of the side fender.
Or would that put too much stress on the rear fender
I ask because I'd prefer not to be sitting on the front strap.
bill1960 is online now   Reply With Quote
Old 09-29-2012, 08:01 AM   #199
robothump
Oddometer: 1
Thumb Thanks..
Motogeek..
Thanks.. I just installed my brake switch and horn. Your information was very helpful otherwise I would have hadno idea where to hookup the brake switch. Getting my bike inspected for a plate next wednesday. I will post some pictures afterward.
Rob
robothump is offline   Reply With Quote
Old 09-29-2012, 12:08 PM   #200
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,755
valves at 100 hours, 2500 miles
Just did my valves for the first time.
Intakes are still good and in range(0.10-0.15mm).
Exhausts opened up a bit and were just outside of spec(0.12-0.17mm) so I shimmed them smaller, now on the low end of the spec.(0.12mm).
This bike is really easy to maintain and do the valves on. Let's see what the next 100 hours brings.
BTW, thanks to the person who did the youtube video. Not bad if you turn off the volume
toddler is offline   Reply With Quote
Old 09-29-2012, 05:21 PM   #201
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,230
Tried to find some elevator music, but couldn't find any good stuff. I thought about Barry Mannilo, but..... then thought better of it.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 09-29-2012, 08:23 PM   #202
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,414
Originally Posted by unaweep View Post
It's for the 500. 3.1 gallon. I have been in contact with them.
I really don't care what they do at this point. I'm not returning the tank. I won't put another Clockwork on one of my bikes, ever. I consider this a good lesson that only cost me $250, but could have cost the whole bike- or worse- me! The tank had about 2.1 motor hours of use. The fuel just dumped onto the motor- literally gushing down onto the header and all around the motor on every side. One spark or perhaps a glowing header . . . .
To install this, you need to cut and lengthen the wires that connect the base of the fuel pump to the top electrical connector. Personally, I prefer not to have spliced wires inside a fuel tank. I believe they should let you know about that little tid bit before you plop down cash for it. I bought a new fuel pump and will save this one for spare part. The whole process of replacing the fuel lines on the fuel pump and splicing wires is just a mess. On a component that is absolutely critical to getting home, I prefer not to have it mickey moused.
I already have the Acerbis 3.2 and it is perfect- just like every tank I've ever purchased from them.
That sucks, and you're right - that could have been a serious disaster, but shit happens. Everybody makes mistakes. To me, what's most important is they get handled. And from what I've heard, Clockworks has done just everything they could to clean-up this mess and make it right. I haven't found any tanks that rival Acerbis fit/finish/quality, but hear mostly good things about the Clockworks tanks.
jesusgatos is offline   Reply With Quote
Old 10-01-2012, 08:30 AM   #203
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 21,330
Since I bought this from Just Gas Tanks, Clockwork told me I had to go through them. They couldn't do anything. I rather suspect Just Gas Tanks will point the finger at Clockwork. Which is really just another reason why I'm not going to waste any more time on this.
I've heard a lot of folks say kind things about Clockwork tanks and the customer service from Clockwork. I will never be one of those folks.
unaweep is online now   Reply With Quote
Old 10-01-2012, 08:51 AM   #204
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 719
Before the net if you sold a good product or service your customer would tell 1 maybe 2 people. If the experience was bad they told 10+ people. I guess Clockwork doesn't get it. Now, good or bad, thousands of people hear your story. Customer service can be one of the most important aspects of any company.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is online now   Reply With Quote
Old 10-01-2012, 01:03 PM   #205
guns_equal_freedom
Oddometer: 5,607
I am running a 15 tooth countershaft sprocket.
Works great in the tight woods.
I just want to know what rokit sientist at KTM thought it would be a good idea not to have throttle adjustment at the throttle.
This bike is a blast to ride.
guns_equal_freedom is offline   Reply With Quote
Old 10-19-2012, 08:27 AM   #206
jtmajors
OCD with motorcycles
jtmajors's Avatar
Oddometer: 302
fuse blowing
I have a sicass switch for when I made my 500 xcw street legal. I was out riding the other night and flipped the headlight switch to low from off and no lights! I've had the switch on and has worked fine since June. Problem is it's blowing a fuse under the seat when switching from off to low. I've checked all wires and cannot find an exposed wire. All connections are tight an ground seems to be fine as well.
I called sicass and they blame it on a bad voltage regulator on the bike saying there is a spike in voltage causing the fuse to blow. They say it's not the switch. I haven't called my dealer yet, but what do yall think?
2012 triumph tiger 800xc, 2012 ktm 500 xcw plated, 2010 wr 250x (sold), 2009 Crf 450r (sold), 2007 Crf 250r (sold), 2006 Triumph Daytona 675 (sold), 2001 yz 125 (sold), 2000 yz 250 (sold), 1997 yzf 600 (sold), 1996 cr250r (sold), 1992 rm 125 (sold), 1988 Yamaha Virago (sold), 1986 XR 200 (sold), 1984 cr 80r (sold), 1982 xr 80 (sold)
jtmajors is offline   Reply With Quote
Old 10-19-2012, 08:36 AM   #207
Riding4fun
Oddometer: 13
Can you hook up the old blinker switch and see if it blows fuses too?
If so it's not the Sicass switch, if not it is the Sicass.
Riding4fun is offline   Reply With Quote
Old 10-19-2012, 08:49 AM   #208
jtmajors
jtmajors's Avatar
Oddometer: 302
Its an xcw so no blinkers. With the switch set to off the running bulb comes on just fine as well as the taillight. As soon as I switch to low the fuse blows and then also lose the running lights. Brake light still works though.
Old 10-26-2012, 06:24 AM   #209
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 534
Did it
Picked up a slightly used 2013 500 XC-W last night
Can't wait to hit the durt tomorrow!
See tag line for first ride impressions . . .
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill screwed with this post 10-26-2012 at 10:58 AM
CamelBill is offline   Reply With Quote
Old 10-26-2012, 08:23 AM   #210
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Picking up my brand new 500 XC-W this afternoon and trail riding tonight with some friends Very excited!
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 09:36 AM.
