Old 12-26-2012, 05:23 AM   #286
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Wow, this thread is dead Got some video for you from the ride we did on Sunday. I know some of you don't like music but too bad
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-26-2012, 05:48 AM   #287
machalooney
machalooney's Avatar
Oddometer: 227
Gas mileage?
I'm close to pulling the trigger on a 500 XC-W, but the one red flag that really put the breaks on my purchase at the moment is the fuel economy with the FI???
I was reading Neduro's thread and it seems he's had very poor gas mileage and seems mystified to date. I've read everywhere between 15 mpg - 30 mpg.
What you say?
machalooney is offline   Reply With Quote
Old 12-26-2012, 09:01 AM   #288
crankshaft
crankshaft's Avatar
Oddometer: 14,005
What you say?
30 in the single track and about 40 ds riding. I'm in the standard map
Just say'IN
Old 12-26-2012, 10:32 AM   #289
machalooney
Oddometer: 227
That sounds better...
Old 12-26-2012, 10:37 AM   #290
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,647
Great video Crankshaft! Riding studded tires?
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 12-26-2012, 10:44 AM   #291
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,899
The one time I paid attention to mileage. I got 50mpg on the nose. This was on a tight singletrack around 10K elevation. My bike is a 2012, stock map.
Soon to be changing the map to one with "mods". (exhaust) and maybe try a 2013 map.
Those who are posting mileage estimates. What year is your bike? And did you change the map?
c.vestal is online now   Reply With Quote
Old 12-26-2012, 12:11 PM   #292
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Thanks Greg! Running car studs, I had 4 boxes in the shop and decided to use them up. They work great, they still allow me to slide into corners enduro style. The other 500 in the video has sheet metal screws in the knobs and the work pretty good also. The sheet metal screws give you better drive but don't slide as well. I'll be making a set of long stud tires soon, using the 19.5 mm rally studs
Just say'IN
Old 12-26-2012, 12:12 PM   #293
crankshaft
crankshaft's Avatar
Oddometer: 14,005
2012 here, standard map. No interest in getting more power, happy the way it is.
Just say'IN
Old 01-18-2013, 06:01 PM   #294
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,209
It hasn’t been much of a secret that I’ve been working on a fairing, in anticipation of finishing the fairing mold I started a new project for my bike. Since it's just over a year old I figured it would be time to do a pretty good once over. I cleaned it up, greased the bearings, changed oil and checked the valves.
First off started thinking about what I’d like to do based on what I’d already had done and all the extra things I never used. I also wanted it to be as flexible as possible to test some new parts and wanted to able to go between the triple clamp mount and the frame mount for the fairing quickly and easily.
Just that parameter meant wiring had to go minimal and need to swap out easily, so pulled the turn signals, heated grips, Powerlet, map switch and stock computer, I like the stock computer and its functionality, but the digits are so small that it takes too much time to register. So for now going with the Trail Tech Striker.
The fairing while being mainly used for roadbook rides, will be made to mount in at least 3 versions, frame, triple and fork mounted.
Circuits I’ll keep, lights, Hi beam, horn, fan override and key switch.
I’ll add a USB port and a spare 12v circuit for the roadbook.
First while tearing the bike down, I put the frame mount back on while doing the head bearing. This is what it looked like, the backing plate always stayed in.
The backing plate,
With the frame mount bolted up,
With the triples and forks back in place,
Next mounting the Scott’s submt/tower bracket, the front bolts get tightened up with the rears in place to line the assembly up.
With that in place I started mocking up the top clamp and how the wiring would work in a limited space.
I Like the Sumitomo connectors, if you notice all the critical electrical on the bike is done with these, the rest done with Molex, I replaced all of them for peace of mind. Here’s the beginning of where the heart of the wiring will live. One of the other things that I made sure could be redundant was the key switch, it can be removed for rides that I don’t have to worry about opportunistic theft.
A few of the other new parts I’m trying are a different way to mount the lamps to the computer housings, this will allow them to be added to all the different ones I have.
Another thing I’ve fought is stripping the hex on the bar end bolts, so I’m trying 10mm which have a hex big enough to handle more abuse.
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 01-18-2013, 06:11 PM   #295
theantipaul
Oddometer: 1,209
With the wiring shaping up it was time to mount it all up on the bike, here’s the bundle high and tight, it needs to be able to swing above the frame mount and still need to tuck into the triple tower. Also with all the little connectors for the lamps, temp, kill, speedo and computer, I went ahead and color coded them with shrink tube.
Next comes a trip to the molders for test shots, 3mi away, he wouldn’t let me take any pics of him, but here’s the business end,
And back to start building the mounting brackets,
Having had a few months to daydream about the mounts so I already had plans on what to try first,
Old 01-18-2013, 06:13 PM   #296
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,749
kick ass as usual Paul
toddler is offline   Reply With Quote
Old 01-18-2013, 06:21 PM   #297
crankshaft
crankshaft's Avatar
Oddometer: 14,005
I can't wait to get my hands on one of these! Great work Paul!
Just say'IN
Old 01-18-2013, 06:32 PM   #298
theantipaul
Oddometer: 1,209
Thanks guys,
With the wiring sorted out on the frame mounted version it as time to see how the triple mounted tower would mount and if the wiring could all fit in there.
The right hand side plate can be removed while all the components stay bolted to the other side for ease of working.
I’ll be trying a plastic shear bolt for the roadbook mount to allow limited rotation in the event of an impact.
Buttoned up,
We have a volleyball tournament this weekend, so I’ll need to find time to finish the wiring and go for a ride. Up next is the fork mounted version, same brackets, just reversed,
Old 01-18-2013, 07:30 PM   #299
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,848
Wow!
Old 01-19-2013, 07:43 AM   #300
D-Train
Ridin' Dirty
D-Train's Avatar
Oddometer: 1,375
Looks great Paul! Now I just gotta get me one of these 500's
D-Train is offline   Reply With Quote
Times are GMT -7.   It's 10:10 AM.
