Old 02-11-2013, 08:42 PM   #346
team ftb
Befuddled Adventurer
Oddometer: 1,210
ergonomics Q
So comparing felt thickness between the legs can someone comment on the differences felt between the RFS bikes and the new 500 model? Is it thinner or thicker when standing? I always felt my RFS bikes were nice and thin and the 08-11 bikes were a lot thicker through the middle. Where does the 500 stack up in comparison?
Has anyone with the HardParts 3.4 gallon tank pictured above on Geeks bike ridden an RFS bike with the same style tank? How does it feel through the middle (between your legs), contrast the two if you've ridden both. I felt on the RFS bike it kept the bike nice and narrow between your legs standing and the width was only felt when putting your leg forward near the radiator shrouds for turns. How is it in comparison on the 450/500 frame?
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 02-13-2013, 03:18 PM   #347
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 523
fingering the bean..
I just came off a great relationship with my 07 RFS 450exc to a 500 this past October. Having ridden the 08-11 generation with my buddies bikes the 500 is a different animal. While the chassis of the previous generation was great the new one is even better which you can only tell riding them back to back. The new 500 feels lighter and to me the same ergos as my 07 in the tank, seat to pegs etc.
Something interesting is how much lower the center of gravity is on the 500 than a 530. Sitting side by side it looks 1.5" lower under the skidplate, the swingarm looks to go in a bit higher on the frame than a 530 also. I have drug bottom twice creeping over an obsticle that my 450 would have cleared on the 500, but generally this is just an observation not a biggie.
The thing that got me on the new bike is the motor. Sweeeeet! Smooth and controllable, one sump system with more oil capacity than ever on a under 600 cc KTM. Bike gets super mileage, build quality of the engine is awesome, new die cast case is high quality.
I weigh 172 and the suspension is perfect for me.My buddies 530 is super firm and it is stock. Power hit on the 500 is there just more easy to "meter", 530 seems to have more low end grunt but comes on with more authority. If I had a 530 i would want a throttle cam.
I put a Scotts on my 500 and it is rock stable, wide open in sand or on the pavement. No head shake.
Give one a ride if you can
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 02-13-2013, 03:45 PM   #348
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,979
So what kind of MPGs are you guys getting out of the 500s?
Sent from my Nexus 7 using Tapatalk HD
Old 02-13-2013, 04:03 PM   #349
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,390
26-55mpg so far. Depends on the riding. That probably didn't help
55 on road just coasting.
26 on high speed desert singletrack.
toddler is offline   Reply With Quote
Old 02-13-2013, 05:01 PM   #350
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
The big difference is that I always felt like I was sitting in the RFS frames but the new bike has you sitting on top of it. The 500 feels smaller than the RFS bikes for sure.
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-13-2013, 11:01 PM   #351
PatrickM
Oddometer: 169
Originally Posted by Geek View Post
I had a couple of lenses with me yesterday and took an arseload of pics (thanks to Paul & Derek for their patience and letting me play with my camera )
Some more random ones:
Here's Paul's current cockpit setup:
Okay, what are all the buttons?!? I'm counting 11!
And geez, it reminds me I need to order myself another set of HDB guards!
PatrickM is offline   Reply With Quote
Old 02-14-2013, 05:10 AM   #352
Danger4u2
KX & CR 500 Rider
Danger4u2's Avatar
Oddometer: 311
I count 21.
Go faster than everyone.
Only worry about what's in front of you.
'08KX500AFC(my favorite) '07KLR650
'04KX500(street legal) '97CR500R
'06KLX250(351cc kit) '08KFX450R quad
Danger4u2 is offline   Reply With Quote
Old 02-14-2013, 06:38 AM   #353
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,739
...and there are some you can't see
www.motogeek.com
Old 02-14-2013, 06:47 AM   #354
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,120
It would look way cooler with an I-PAD instead of the roll chart.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 02-14-2013, 01:14 PM   #355
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,739
...that can easily be arranged
What are you doin' slummin' in this thread Indy? Time for another toy?
www.motogeek.com
Old 02-14-2013, 01:48 PM   #356
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 862
OK, the 3 button switch on the left is a Trail Tech computer switch, they can be wired up to also work with the KTM computer for all the same functions as the KTM switch.
Push buttons on the guard are for the roadbook holder for/rev, usually lives on the clutch lever.
IPhone/IPod remote, 2 on the brake perch are Squadron spot and horn.
The Baja Designs key switch powers up the computer and the top clamp push buttons and they are lights, fan over ride and then 2 open.
Kill on the clutch lever and and start on the brake lever.
Crankshaft has put an IPad up there.
Geek, it's snowing, we should go riding.
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 02-14-2013, 01:55 PM   #357
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,964
My bike's getting closer!! I should stop seeing these pictures.... I'm gonna spend way too much!
oh wait.... I got paid today!
Ben
My Photo's
Motorfiets is online now   Reply With Quote
Old 02-14-2013, 05:37 PM   #358
KrustyKustom
Lets Go....
Oddometer: 523
Well put. My RFS felt very rigid also.
My 07 handled like a dumptruck compared to my new 500. Hard to imagine the difference.
I have yet to get less than 46mpg on mine, high of 56 in Moab.
Krusty Kustom,
Houston Texas
2013 KTM 500exc
Old 02-15-2013, 09:28 AM   #359
trailjammer
trailjammer's Avatar
Oddometer: 175
nope.. no studs. Lots of slip-sliding
The extra wind protection of the HDB fairing was well appreciated when we got going fast as it was waaaaaay below freezing.
cheers,
Edward
Damn Edward! Those are some awesome pictures! ...now where's the tow rope and the snowboard you can pull around?! LOL You need a case saver on that bike before it finds a rock in the snow. That's some skill riding in the snow!
TRAILJAMMER DESIGNS -KTM PROTECTION! www.facebook.com/trailjammer408
trailjammer is offline   Reply With Quote
Old 02-15-2013, 08:47 PM   #360
The Wolf
The Wolf's Avatar
Oddometer: 32
anybody have a part number on the baja designs keyed ignition? is it specific to the 12/13 500xcw?
The Wolf is offline   Reply With Quote
Times are GMT -7.   It's 12:50 PM.
